Anyway, when you ask for a tiled request without applying a style, each tile is rendered independently with the default raster style and the applied colormap depends on the maximum and minimum values of each tile.
You reported an issue related to an unsupported data type, so which is the data type of your images?
2014-09-05 9:43 GMT+02:00 Nicola Lagomarsini <nicola.lagomarsini@anonymised.com>:
Sorry, I forgot to keep the discussion on the list!
Nicola.
Ing. Nicola Lagomarsini
Junior Software Engineer
Via Poggio alle Viti 1187
2014-09-05 9:33 GMT+02:00 Anas A <anas.24aj@anonymised.com>:
Hi Nicola,
The image format which i used is both tif/img and i published it under imagemosaic datastore, while layer previewing i am getting different colour for different tiles
here by am attaching the file folder screenshot and the preview image which i am getting while publishing
Anas A
Jr.GIS Engineer, Trinity Mobility
+917736368236
Tattamangalam,Palakkad,Kerala
On Fri, Sep 5, 2014 at 12:58 PM, Nicola Lagomarsini <nicola.lagomarsini@anonymised.com> wrote:
Hi Anas,
what is the data format of the images you are using?
Nicola.
2014-09-04 11:42 GMT+02:00 Anas A <anas.24aj@anonymised.com>:
Dear Nicola,
when I tried to set OutputTransparentColor to 000000 i am getting an error like
{Error rendering coverage on the fast path
java.lang.IllegalStateException: Unsupported data type.
Unsupported data type.}
If i remove that and put as default the map is loading without any issue but that ugly black color come in ‘no data’ Area, and if use tiled request the map getting differnt band colour for different area
Anas A
+917736368236
anas.24aj@anonymised.com84…
On Thu, Sep 4, 2014 at 1:49 PM, Nicola Lagomarsini <nicola.lagomarsini@anonymised.com> wrote:
Hi Anas,
you should set OutputTransparentColor to 000000 in order to avoid black color. In the documentation “no color” indicates that OutputTransparentColor is not configured, we will change it.
The available Merge Behaviors are FLAT, which is the default behavior, and STACKED, which merges all the data into a stack.
Nicola.
2014-09-01 13:21 GMT+02:00 Anas A <anas.24aj@anonymised.com>:
Dear Friends,
i am trying to publish Arial imaginary mosaic using image mosaic data store , to avoid black color noice i noticed that it need to set InputTransparentColor and outputTransparentColor to ‘no color’(http://docs.geoserver.org/stable/en/user/tutorials/image_mosaic_plugin/imagemosaic.html) but when i type that in that peculiar field its automatically changing to ‘ffffff’ , is there any hex-value for no color? how to set that value to avoid the black color?
also what are the values available for ‘MergeBehavior’ parameter in the same?
Anas A
+917736368236
Slashdot TV.
Video for Nerds. Stuff that matters.
http://tv.slashdot.org/
Geoserver-users mailing list
