[Geoserver-users] How to set sld parameter in a wms request
I tried to use the sld parameter in a wms request, I hava geoserver1.7.5
installed,and I tried 1.7.2 too.
I set the sld parameter in the request,as below:
http://localhost:8081/geoserver/wms?bbox=-127.61950064999999,23.7351786,-64.08177035,50.592523400000005&styles=&Format=image/png&request=GetMap&version=1.1.1&layers=topp:states&width=800&height=317&srs=EPSG:4326&SLD=http://localhost:8081/sld/polygon.xml
however,it seems it doesn't accept it and still use the default style,why?
besides, i also tried the SLD_BODY parameter ,with no success
please help,thanks.
View this message in context: http://www.nabble.com/How-to-set-sld-parameter-in-a-wms-request-tp24306449p24306449.html
I believe the URL is incorrect. If Geoserver is running on port 8081, then the file can not be served from the url you provided. You have a couple of options
1. If polygon.xml is in the styles directory of your geoserver data directory then you can use the following url:
http://localhost:8081/geoserver/styles/polygon.xml
2. You can copy polygon.xml in to <GEOSERVER_DATA_DIR>/www and then access it via:
http://localhost:8081/geoserver/www/polygon.xml
Hope that helps.
-Justin
please help,thanks.
Justin Deoliveira
OpenGeo - http://opengeo.org
It is appreciated if you can keep your replies on the public email list. Thanks :slight_smile:
So what do you get when you visit the url you supply for the SLD in a regular web browser?
-Justin
coolnanjizhou wrote:
I tried both the two ways you mentioned ,but still not work, then I switched the port to the default 8080,but the result was the same.
ÔÚ2009-07-03£¬"Justin Deoliveira" <jdeolive@anonymised.com> дµÀ£º
Hope that helps.
-Justin
please help,thanks.
Justin Deoliveira
200ÍòÖÖÉÌÆ·,×îµÍ¼Û¸ñ,·è¿ñÓÕ»óÄã <http://count.mail.163.com/redirect/footer.htm?f=http://gouwu.youdao.com&gt;
Justin Deoliveira
