[Geoserver-users] How to show ARCSDE layer in Geoserver?
Hi Jeong,
maybe it's not such a big problem as you might think. I'm doing geoserver with ArcSDE too in the Versions 1.4.1 and 1.6.3. Both work well. What i discovered is this: If you didn't setup the SLD well when setting up a FeatureType configuration, you won't get a preview with the openLayers mapviewer! Just try to do a GetFeature request with that concerning FeatureType. If that works, its probably a problem of missing or wrong SLD.
HTH
Albrecht
Albrecht Weiser,
E6, GIS Center
Hessische Zentrale für Datenverarbeitung (HZD)
Mainzer Straße 29, 65185 Wiesbaden
Tel.: 0611 340-3113
Fax: 0611 340-5113
Dear list.
I want to see ArcSDE Layers using Geoserver and openLayers.
so, I installed the ArcSDE Geoserver Extension and created an ArcSDE
DataStore(for ArcSDE Vector-data layers)
So, If I clicked New in DataStores, I can see ArcSDE in
Feature Data Set.
Moreover, I can make new Feature Data Set ID using Feature
Data Set Editor.
What I am wondering is that after make new Feature Data Set
ID, I moved Demo
and Map preview. but, I can't see the layer.
How to show ArcSDE Layer such as other layers in Map Preview?
Thanks in advance.
Best regard,
Jeong.
