On Fri, Feb 9, 2018 at 11:36 AM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
Same goes for the update of attributes, it is not supported, but the
underlying datastore API has optional support for it (same as above,
database based datastore do support schema update).
Actually, I take it back, remembered it wrong, JDBCDataStore does not
implement updateSchema. One more thing to work on in case Joao wants to
get these new features implemented
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
