I've added a WMS store, to get all cascaded layers from a Mapserver WMS Server.
I am unable to find a way to force Geoserver to "refresh" the WMS
harvesting, to get the new/updated layers?
Thank you in advance!
Luca
Luca
On Wed, Oct 22, 2014 at 4:34 PM, Luca Manganelli <luca76@anonymised.com> wrote:
Server.I am unable to find a way to force Geoserver to "refresh" the WMS
GeoServer does not do harvesting, the only way to configure new layers is
to
manually configure them, or use REST config to automate the configuration.
Same goes for picking again all the metadata from the remote server,
the only thing I can think of without changing geoserver code is to
re-create the layer
Of course it shoudl be possible to develop some sort of actual
harvester/automatic
config/automatic configuration, I'm sure there would be interest by some
part of the user community, the trick is finding someone willing to code
it, or to fund it
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
