[Geoserver-users] how users can working whit geoserver in form concurrent?
because when I probed with 3 users concurrent my map was freeze
Thanks
Arturo Juárez Lima
Are you asking how much concurrent load can GeoServer bear?
Obviously, that depends on the specifics of your installation, including your hardware. Since GeoServer is a J2EE webapp, the scalability of a given installation also has a great deal to do with how you've configured your application server or servlet container.
Using appropriate hardware, we're comfortably serving from a catalog of well over a thousand feature types and JMeter load-testing indicates that we should able to support many dozens of concurrent users without difficulty.
So GeoServer can scale.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
Thanks
Arturo Juárez Lima
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________
Geoserver-users mailing list
ok, if my machine are
SO: Centos 5.2 x86_64
host: PowerEdge 2900
RAM: 8GiB
CPUs: 1 x Quad Core Intel Xeon E5430 @ 2.66GHz
DD: 4 x 300 GB SAS 15K
How user concurrent can I receive??
ajs6f escribió:
Arturo Juárez Lima
Thanks
Arturo Juárez Lima
challenge
great prizes
the world
[http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________](http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
[http://moblin-contest.org/redirect.php?banner_id=100&url=/](http://moblin-contest.org/redirect.php?banner_id=100&url=/)
RAM: 8GiB
This cannot simply be preticted, it depends too much on how many layers, what kind of styling you setup, what indexes you have on the database, what kind of database backend you're using, whether you installed JAI and so on.
This is a presentation I put toghether with a well tuned GeoServer (and MapServer) running on a cheap notebook:
http://files.opengeo.org/presentations/WebMapServerPerformance-FOSS4G2008.pdf
If you want to know how much you can scale, you'll have to try similar tests with JMeter but with your own data.
Andrea Aime
OpenGeo - http://opengeo.org
ok, the file is very explicity, but I am working with shapefiles very hard, one of them have 254,715 polygons, I am starting with the extension geowebcache.
Its the better, in my case, the use of the GeoWebCache for these types of shapes?
Andrea Aime escribió:
Arturo Juárez Lima
RAM: 8GiB
This cannot simply be preticted, it depends too much on how many layers, what kind of styling you setup, what indexes you have on the database, what kind of database backend you’re using, whether you installed JAI and so on.
If you want to know how much you can scale, you’ll have to try similar tests with JMeter but with your own data.
Not sure I understand the question correctly, bu GeoWebCache can saturate a 100 mbps connection on modest hardware, so you'll probably be limited by your networking equipment rather than the software or hardware.
-Arne
*//**/ Arturo Juárez Lima/*
RAM: 8GiB
Arne Kepp
