The problem is, its not clear what file I need to edit to put my into. After a bit of searching I decided to stick it into %GWC_CACHE_DIR%\geowebcache.xml:
Problem is, this breaks GeoServer horrifically (tons of error messages at startup, and then any and all GeoServer requests, including to the admin page, give a 404 when its running). I’m surprised how badly GeoServer breaks actually.
So short version: how do I implement this in the GeoServer integrated GWC?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
<expireClientsList> into. After a bit of searching I decided to stick it
<layers>
<!--HTTP Cache tiles - 30 days until expiry for mastermap scale-->
<!--100 days for others-->
<expireClientsList>
<expirationRule minZoom="0" expiration="8640000" />
<expirationRule minZoom="10" expiration="2592000" />
</expireClientsList>
</layers>
page, give a 404 when its running). I'm surprised how badly GeoServer breaks
actually.
Jonathan
Learn Graph Databases - Download FREE O'Reilly Book
"Graph Databases" is the definitive new guide to graph databases and
their applications. This 200-page book is written by three acclaimed
leaders in the field. The early access version is available now.
Download your free book today! http://p.sf.net/sfu/neotech_d2d_may
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Hi Simone,
Thanks for the information. I guess that means the HTTP-Cache headers aren’t configurable with the integrated GWC. Ah well, our internal network can cope.
detailing how to change HTTP Caching Headers for GWC responses.
actually.
Jonathan
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and
