[Geoserver-users] https with GeoServer
I would like to configure GeoServer to work with https instead of http. IS
configuring tomcat as in here
http://tkurek.blogspot.com/2013/07/how-to-secure-tomcat-7-with-ssl-tls.html
would do that?
View this message in context: http://osgeo-org.1560.x6.nabble.com/https-with-GeoServer-tp5140586.html
Another approach is to use tomcat behind an apache AJP proxy, and have apache do all the SSL. Apache is very fast, very configurable, and this approach allows mixing of different technologies such as mod_python and mod_php with Java servlets on the same host. I expect that you can do the same thing with nginx.
Kind regards,
Ben.
would do that?
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free."
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
GeoServer is running on tomcat and my website is running on apache on the
same server. SSL is already configured on apache but i get the message that
says i have insecure content which i thought they were GeoServer layers. so
now I'm trying to enable SSL for GeoServer but still not sure what's the
best approach to do that.
View this message in context: http://osgeo-org.1560.x6.nabble.com/https-with-GeoServer-tp5140586p5140633.html
Diego,
is apache connected to tomcat using AJP? That is do you have some apache setting like this?:
ProxyPreserveHost On
ProxyRequests Off
ProxyPass /geoserver ajp://localhost:8009/geoserver
ProxyPassReverse /geoserver https://example.org/geoserver
Have you told GeoServer what its externally visible address is by setting its Proxy Base URL to, for example:
If not, some content like openlayers will be at http://example.org:8080/geoserver and thus insecure (they are being accessed directly through tomcat). Please block port 8080 in your server firewall to be sure.
What are the insecure pages? In Firefox, Ctrl-I will show you page information and the media tab may help you to locate insecure resources.
Kind regards,
Ben.
Software Engineer
apache httpd and tomcat are not connected, and yes, these content are not
secure http://example.org:8080/geoserver
so, do you have a clear instructions on how i can do that? Thanks a lot.
View this message in context: http://osgeo-org.1560.x6.nabble.com/https-with-GeoServer-tp5140586p5140678.html
would this do what i need ?
http://docs.geoserver.org/latest/en/user/security/tutorials/cert/index.html
View this message in context: http://osgeo-org.1560.x6.nabble.com/https-with-GeoServer-tp5140586p5140727.html
Diego,
this page describes how a user can authenticate themselves using a certificate (a client certificate) in addition to a tomcat server certificate. A typical secure website is the other way around: a server uses a certificate to identify itself and establish a secure connection.
Which do you want? Best practice is to have your HTTPS services on port 443 as 80 and 443 are likely to be open in firewalls. Do this with apache.
Kind regards,
Ben.
Software Engineer
Diego,
first a few questions:
(1) Is this a test or are you making a production service?
(2) Do you want to use the official HTTPS port 443?
Please tell us a bit more about what you are trying to do.
For example, to make a production service using apache in front of tomcat on port 443:
- obtain an SSL certificate for your host: for a production service buy one for a provider, for test you can make a self-signed certificate
- install your SSL certificate bundle in apache
- configure an apache virtual host for SSL on port 443
- enable AJP from apache for this virtual host
ProxyRequests Off
- turn on ajp in tomcat (often just uncomment that section in server.xml)
- restart all services
Kind regards,
Ben.
Software Engineer
And none of those steps are particular to geoserver. They are standard configuration steps for setting up apache ssl and connecting to tomcat. There are many guides.
Kind regards,
Ben.
On 19/05/14 13:30, Ben Caradoc-Davies wrote:
Diego,
tomcat on port 443:
ProxyRequests Off
Kind regards,
Ben.
available
Software Engineer
