[Geoserver-users] I get an error when Creating a new Coverage using the new ImageMosaic CoverageStore
Below is the screen print from the documentation for creating a new coverage for an image mosaic. I was able to successfully create a coverage store, but when following the below documentation and I get the following error below.
Create a new Coverage using the new ImageMosaic CoverageStore:1. Go to “Welcome | Config | Data | Coverage | New” via the web interface, choose the name of the coverage you just created:
GeoServer - ExceptionThe following exception was thrown:
org.vfny.geoserver.global.ConfigurationException: Coverage dimensions: java.lang.IllegalArgumentException: operation "ImageRead" requires parameter at index 0 to be non-null.
John J. Mitchell
Hi John,
Which version of GeoServer are you using? Also would it be possible to get the entire stack trace. Thanks.
-Justin
John Mitchell wrote:
   1. Go to "Welcome | Config | Data | Coverage | New" via the web
/|org.vfny.geoserver.global.ConfigurationException: Coverage dimensions: java.lang.IllegalArgumentException: operation "ImageRead" requires parameter at index 0 to be non-null.|/
John J. Mitchell
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
