[Geoserver-users] I get the following error: Service Exception: java.lang.IllegalArgumentException: unable to parse 2006-11-30 as Date
I am trying send data to a date field within community mapbuilder to Geoserver which updates PostGIS/Postgres. The field is defined as date within PostGres, but when I bring it within Geoserver as a featureType I noticed that the same field is now defined as dateTime. From Community Mapbuilder I try to update the date field and I get the following error: Service Exception: java.lang.IllegalArgumentException: unable to parse 2006-11-30 as Date
I have also tried 2006-11-30:00:00:00 and Sat, 12 Aug 1995 13:30:01 which works fine when updating PostGres directly and I get similar error when going through Geoserver.
What format will work when the geoserver format is dateTime and the PostGis/PostGres is date?
John J. Mitchell
John Mitchell ha scritto:
Geoserver uses Geotools to do the parsing and turning the object into
a Date, which in turn relies on java.text.DateFormat.getInstance(), the
default date/time parser. Which is, in turn, locale dependent (the default locale of the server you're running onto).
So... it's a guess... we should provide this info somewhere in the
geoserver configuration pages.
The following program, run on your pc, will return _your_ format:
public static void main(String args) throws ParseException, SecurityException, NoSuchFieldException, IllegalArgumentException, IllegalAccessException {
         SimpleDateFormat format = (SimpleDateFormat) DateFormat.getInstance();
         System.out.println(format.toPattern());
         System.out.println(format.parse("20/10/05 10.13"));
On my PC, with Italian locale, the format is: dd/MM/yy H.mm
On yours it will be different.
Andrea,
Thanks for the sample program! I ran it and I was able to get the correct dateTime format for the US locale of M/d/yy h:mm a
John Mitchell
java.lang.IllegalArgumentException : unable to parse 2006-11-30 as Date
default locale of the server you’re running onto).
So… it’s a guess… we should provide this info somewhere in the
The following program, run on your pc, will return your format:
System.out.println(format.parse(“20/10/05 10.13”));
John J. Mitchell
Andrea,
No problem... yet it takes a bit too much of work to guess this even
if you're familiar with the code, so I've opened an issue in jira:
http://jira.codehaus.org/browse/GEOS-811
