[Geoserver-users] i18n problem
Hello,
I’ve been trying to create style in geoserver with Multilanguage Title – using this (sample) sld:
<?xml version="1.0" encoding="ISO-8859-1"?>
OCEANSEA_1M:Foundation
GEOSYM
1
main
title
titolo
titre
titre
ogc:PropertyNameGEOMETRY</ogc:PropertyName>
#96C3F5
I tried using geoserver v2.9.0 , v2.9.1, v2.9-beta, v2.10 and on all I receive only one exception:
“line 15: cvc-type.3.1.2: Element ‘Title’ is a simple type, so it must have no element information item [children].”
Even though I tried changing to ‘se’ namespace, the result was the same. I got through xsds’ - on ‘sld’ and ‘se’ to check, but on any version – no Localized tag is found, nor accepted.
Can anyone explain me how recreate the result mentioned here: http://docs.geoserver.org/2.9.0/user/styling/sld-language.html ?
Thanks for the help!
I. Dionisiev
Is there a way to set a colorMapEntry based on two different bands of a raster?
Ciao Devin,
the quick answer is no, however I am curious about what your use case is and what you are trying to achieve.
I don’t see a meaningful use case for creating a single colormap out of two bands
unless you are talking about doing some kind of raster algebra before applyin the coloramp (which is 1D by definition).
Simone.
On Thursday, September 1, 2016, Devin Eyre <Devin.Eyre@anonymised.com> wrote:
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
When you set ChannelSelection tag, you can choose only one band, so to make ColorMap based on its value (quantity). What kind of merge you want? Can you make it on the image, so then you can use that band, or if that is the case – you can duplicate the band number and use RGB channels.
Hope this helps.
Dionisiev
From: Devin Eyre [mailto:Devin.Eyre@anonymised.com.]
Sent: Thursday, September 1, 2016 5:40 PM
Subject: [Geoserver-users] Styling a raster based on two bands
The first band is radar reflectivity, and the second band is precipitation type.
From: Simone Giannecchini simone.giannecchini@anonymised.com
Sent: Thursday, September 1, 2016 10:26 AM
To: Devin Eyre
Subject: Re: [Geoserver-users] Styling a raster based on two bands
Ciao Devin,
Simone.
Simone Giannecchini
@simogeo
Founder/Director
Ciao Devin,
yeah, ok but if you want to get help you need to give some more info.
If you want to be able to style each band separately from the tiff
file, you can do it with two different styles doing a channel
selection before the colormap.
I still don't understand how you want to apply a colormap to a two
bands raster, so, please, let me know more.
Simone Giannecchini
@simogeo
Founder/Director
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Sep 1, 2016 at 5:30 PM, Devin Eyre <Devin.Eyre@anonymised.com> wrote:
type.
From: Simone Giannecchini <simone.giannecchini@anonymised.com>
To: Devin Eyre
Ciao Devin,
I don't see a meaningful use case for creating a single colormap out of two
bands
Simone.
raster?
Simone Giannecchini
@simogeo
Founder/Director
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
We want to use a different colormap for the same radar reflectivity value based on the precipitation type (snow, rain, or mixed).
We were hoping we could get away with only making one layer with two different styles, one of which would show precipitation type, and one would not.
________________________________________
Sent: Thursday, September 1, 2016 10:34 AM
To: Devin Eyre
Cc: Simone Giannecchini; geoserver-users@lists.sourceforge.net
Ciao Devin,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
type.
To: Devin Eyre
Ciao Devin,
bands
Simone.
raster?
Simone Giannecchini
@simogeo
Founder/Director
RIght now,
this needs some coding in GeoServer, alternatively, you can preprocess the second band accordingly.
Simone.
To: Devin Eyre
Ciao Devin,
I still don’t understand how you want to apply a colormap to a two
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
type.
To: Devin Eyre
Cc: geoserver-users@anonymised.comorge.net
Ciao Devin,
bands
Simone.
raster?
Simone Giannecchini
@simogeo
Founder/Director
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
Simone Giannecchini
@simogeo
Founder/Director
In particular, I believe the quickest approach would be to write your own rendering transformation (they are pluggable after all).
There is no dev doc, but you can find some info here:
http://docs.geoserver.org/stable/en/user/styling/sld-extensions/rendering-transform.html
https://github.com/geotools/geotools/wiki/rendering-transformations
On Thu, Sep 1, 2016 at 6:06 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
RIght now,
Simone.
From: Simone Giannecchini simone.giannecchini@anonymised.comsolutions.it
To: Devin Eyre
Cc: Simone Giannecchini; geoserver-users@anonymised.comsourceforge.net
Ciao Devin,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
type.
To: Devin Eyre
Cc: geoserver-users@anonymised.comsourceforge.net
Ciao Devin,
bands
Simone.
On Thursday, September 1, 2016, Devin Eyre <Devin.Eyre@anonymised.com.> wrote:
raster?
Simone Giannecchini
@simogeo
Founder/Director
Simone Giannecchini
@simogeo
Founder/Director
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
What I have done so far is to make three time-enabled layers (for rain, snow, and mixed/ice), and made a layer group out of them. How hard would it be to time-enable a layer group? All three layers have exactly the same times available.
From: andrea.aime@anonymised.com. andrea.aime@anonymised.com on behalf of Andrea Aime <andrea.aime@anonymised.com1107…>
Sent: Thursday, September 1, 2016 11:19 AM
To: Simone Giannecchini
Cc: Devin Eyre; geoserver-users@lists.sourceforge.net
RIght now,
Simone.
To: Devin Eyre
Ciao Devin,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
type.
To: Devin Eyre
Ciao Devin,
bands
Simone.
raster?
Simone Giannecchini
@simogeo
Founder/Director
Simone Giannecchini
@simogeo
Founder/Director
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Devin,
layer groups at the moment have limited dimension support, in particular, they show up dimensions
only when they are in the special “Earth Observation” mode, in which a “browse” layer is set in the
root position of the group, and is showed directly when the group is requested, instead of
showing the inner layers. This has been done to support the OGC WMS Earth Observation profile.
In that case, and if the root layer has dimensions, the group advertises dimensions in the capabiltiies.
There is currently no logic to go over the nested layers and check if by chance they all have the same
dimensions, and same dimension values. It could be added of course, maybe controlled as a flag,
scanning over an entire tree of layers and compute their dimension values (which could be deep) could prove to be expensive.
Or maybe the flag would be there to tell GeoServer to trust everything is aligned, and just pick the first
layer dimension values as good for the entire tree.
On Tue, Sep 6, 2016 at 7:05 PM, Devin Eyre <Devin.Eyre@anonymised.com> wrote:
From: andrea.aime@anonymised.com <andrea.aime@anonymised.com> on behalf of Andrea Aime <andrea.aime@anonymised.com>
Cc: Devin Eyre; geoserver-users@anonymised.comsourceforge.net
On Thu, Sep 1, 2016 at 6:06 PM, Simone Giannecchini <simone.giannecchini@anonymised.comsolutions.it> wrote:
RIght now,
Simone.
From: Simone Giannecchini simone.giannecchini@anonymised.comions.it
To: Devin Eyre
Cc: Simone Giannecchini; geoserver-users@anonymised.comrge.net
Ciao Devin,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
type.
To: Devin Eyre
Cc: geoserver-users@anonymised.comrge.net
Ciao Devin,
bands
Simone.
raster?
Simone Giannecchini
@simogeo
Founder/Director
Simone Giannecchini
@simogeo
Founder/Director
Geoserver-users@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, that’s exactly what I needed for this.
Sent: Wednesday, September 7, 2016 2:56 AM
To: Devin Eyre
Hi Devin,
On Tue, Sep 6, 2016 at 7:05 PM, Devin Eyre <Devin.Eyre@anonymised.com…7803…> wrote:
From: andrea.aime@anonymised.com… <andrea.aime@anonymised.com> on behalf of Andrea Aime <andrea.aime@anonymised.com>
RIght now,
Simone.
To: Devin Eyre
Ciao Devin,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
type.
To: Devin Eyre
Ciao Devin,
bands
Simone.
raster?
Simone Giannecchini
@simogeo
Founder/Director
Simone Giannecchini
@simogeo
Founder/Director
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
