To the best of my knowledge no external process is changing those files. Also the changed id has the same format, so I would assume it comes from GeoServer.
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Wednesday, December 05, 2012 10:10 AM
To: Felix Mayer
Subject: Re: [Geoserver-users] id changed in style’s XML file
Usually his happens when some manual process outside of GeoServer is modifying the data directory or something like that. Is there any of that going on?
On Tue, Dec 4, 2012 at 10:01 AM, Felix Mayer <Felix.Mayer@anonymised.com> wrote:
I have the problem that occasionally a style’s id is changed in its XML file, leaving many layers without a default style and hence unusable.
For example, I will find that in this raster.xml file:
StyleInfoImpl-4e0b98bf:12475d46fdd:-7fe2
raster
raster.sld
suddenly the has changed for no apparent reason. Since the used in layer.xml does not exist anymore, the layer cannot be displayed.
What triggers the change of the ? Is there any way to prevent that other than making the file read-only?
Thanks, Felix
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-users mailing list
Geoserver-users@anonymised.comet
Justin Deoliveira
OpenGeo - http://opengeo.org
