[Geoserver-users] Ideas for visualising raster filers
Hello,
we’re still searching for possibilities to filter raster layers. As a fact that raster based layers cannot be queried with a CQL or other filter, we were thinking to use SLDs to apply filters on a raster layer. The scenario is that a user has a (radiation) map in an OpenLayers based client. Now he wants to “filter” the layer based on values, let’s say:
“Don’t show me parts of the map with values below X and values above Y”
We want to transfer this condition dynamically into a SLD wich we send to the server. Now my question is what are the best options for creating such a SLD. many of the layers use ColorMaps with gradients (type=“ramp”). The additional filter rule would only make sense with type=“intervals”.
Is it possible to mix 2 rules with different ColorMap types and have you experience with support by other servers?
So far I had only errors returning - but this is the best way I could think of implementing raster layer filsters…any other solutions which do not involve server side processing?
Thank you very much!
Ciao Thomas,
please, find my answer inline below...
Simone Giannecchini
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Wed, May 1, 2013 at 4:07 PM, <Thomas.Wanderer@anonymised.com> wrote:
Hello,
we're still searching for possibilities to filter raster layers. As a fact
wants to "filter" the layer based on values, let's say:
  "Don't show me parts of the map with values below X and values above Y"
SLD. many of the layers use ColorMaps with gradients (type="ramp"). The
additional filter rule would only make sense with type="intervals".
I have no experience with what other servers can do. But I believe you
can achieve what you are looking for with
SLD and ColorMap. You can actually pass GeoServer the style and modify
it dynamically.
Regardless of the fact that you use ramp or intervals you only have to
fiddle with values at the edges.
As an instance something similar to:
<ColorMap type="ramp">
        <ColorMapEntry color="#EEBE2F" quantity="-0" label="label" opacity="0"/>
        <ColorMapEntry color="#2851CC" quantity="1E-7" label="values"
opacity="1"/>
        <ColorMapEntry color="#211F1F" quantity="50" label="label" opacity="1"/>
        <ColorMapEntry color="#EE0F0F" quantity="100" label="label"
opacity="1"/>
        <ColorMapEntry color="#AAAAAA" quantity="200" label="label"
opacity="1"/>
        <ColorMapEntry color="#6FEE4F" quantity="250" label="label"
opacity="1"/>
        <ColorMapEntry color="#3ECC1B" quantity="300" label="label"
opacity="1"/>
        <ColorMapEntry color="#886363" quantity="350" label="label"
opacity="1"/>
        <ColorMapEntry color="#5194CC" quantity="400" label="label"
opacity="1"/>
        <ColorMapEntry color="#2C58DD" quantity="450" label="label"
opacity="1"/>
        <ColorMapEntry color="#DDB02C" quantity="600" label="label"
opacity="1"/>
        <ColorMapEntry color="#DDB02C" quantity="600.000000000000001"
</ColorMap>
would cut out values below 0 and above 600 (warning, going from memory
here, you'd better checking this yourself :slight_smile: )
of implementing raster layer filsters...any other solutions which do not
I would suggest you share some of the SLD you are playing with as well
as some sample data.
That said, I can probably think about a rendering transformation tha
actually does a simple lookup transform on the data prior
to rendering "cutting out" part of the dynamic for the data (e.g.
setting the values to nodata). This would require
some coding, nothing dramatic though and of course it would require
some moderate coding on the server side.
Introducing AppDynamics Lite, a free troubleshooting tool for Java/.NET
Get 100% visibility into your production application - at no cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap1
Geoserver-users mailing list
Hello,
The way to do this is indeed to change the style parameter in your geoserver call to have an other "visual" without the values in it.
Best regards,
Eric Smets
Op 2/05/2013 18:39, Simone Giannecchini schreef:
Ciao Thomas,
Simone Giannecchini
@simogeo
Founder/Director
Hello,
it dynamically.
opacity="1"/>
opacity="1"/>
opacity="1"/>
opacity="1"/>
opacity="1"/>
opacity="1"/>
opacity="1"/>
opacity="1"/>
opacity="1"/>
</ColorMap>
Eric Smets eric.smets@anonymised.com
FKS bvba - Formal and Knowledge Systems http://www.fks.be/
Schampbergstraat 32 Tel: ++32-(0)11-21 49 11
B-3511 Hasselt Fax: ++32-(0)11-22 04 19
Thank you both for the answers. I will post some SLDs I'm working on but first will try to it the way you suggested.
We were thinking that maybe Geoserver's internally "Map Painting" would work in a sequence, thus applying one rule after another.
Therefore we thought we leave the original SLD Color Map and only inject at the end our transparency/masking ColorMapEntry which ultimately sets pixels to transparent that were colore before by the original ColorMapEntries.
Building a new SLD with correct interval edges (not overlapping) is probably not too hard but you need to "understand" the SLD while the first idea could be done by simply injecting a new rule at the end.
>> Hello,
>> OpenLayers based client. Now he wants to "filter" the layer based on
values, let's say:
Y"
>> (type="ramp"). The additional filter rule would only make sense with
type="intervals".
> can achieve what you are looking for with SLD and ColorMap. You can
> actually pass GeoServer the style and modify it dynamically.
opacity="0"/>
> opacity="1"/>
opacity="1"/>
> opacity="1"/>
> opacity="1"/>
> opacity="1"/>
> opacity="1"/>
> opacity="1"/>
> opacity="1"/>
> opacity="1"/>
> opacity="1"/>
> </ColorMap>
>> think of implementing raster layer filsters...any other solutions
> actually does a simple lookup transform on the data prior to rendering
> setting the values to nodata). This would require some coding, nothing
> dramatic though and of course it would require some moderate coding on
> the server side.
>> --------- Introducing AppDynamics Lite, a free troubleshooting tool
>> for Java/.NET Get 100% visibility into your production application -
>> at no cost.
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> -------- Introducing AppDynamics Lite, a free troubleshooting tool for
> Java/.NET Get 100% visibility into your production application - at no
> cost.
Get 100% visibility into Java/.NET code with AppDynamics Lite It's a free
troubleshooting tool designed for production Get down to code-level detail
for bottlenecks, with <2% overhead.
http://p.sf.net/sfu/appdyn_d2d_ap2
It does
ColorMapEntries.
Once a pixel is painted, there is no way to make it transparent again, if
the pixel is, say, red, painting transparent on top of it leaves it red.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Ok,
very good to know! So there is no other option then understanding the “edges” of the intervals and injection transparency intervals in an intelligent way. With Ramp color maps we had the experience that the transparency doesn’t work in a sharp way as intervals.
Von: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Im Auftrag von Andrea Aime
Gesendet: Freitag, 3. Mai 2013 10:23
An: Wanderer, Thomas
Cc: GeoServer Mailing List List
Betreff: Re: [Geoserver-users] Ideas for visualising raster filers
Thank you both for the answers. I will post some SLDs I’m working on but first will try to it the way you suggested.
We were thinking that maybe Geoserver’s internally “Map Painting” would work in a sequence, thus applying one rule after another.
It does
Once a pixel is painted, there is no way to make it transparent again, if the pixel is, say, red, painting transparent on top of it leaves it red.
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Ciao Thomas,
you need to use the trick I put in the sample colormap i sent
yesterday, creating a very steep intervale to go from opaque to
transparent.
Simone Giannecchini
@simogeo
Founder/Director
On Fri, May 3, 2013 at 10:27 AM, <Thomas.Wanderer@anonymised.com> wrote:
Ok,
Andrea Aime
It does
Ing. Andrea Aime
@geowolf
Technical Lead
It's a free troubleshooting tool designed for production
Get down to code-level detail for bottlenecks, with <2% overhead.
