I apologize if this has been answered before, but can geoserver function without installing Apache Tomcat on IIS running on windows server 2008 R2?
Mark,
Yes, that is what I am running. I do not have Apache Tomcat installed.
Jerome Wendell
Sent: Friday, May 03, 2013 5:19 PM
To: geoserver-users@anonymised.comrge.net
Subject: [Geoserver-users] IIS and Geoserver
The requirement is a java servlet/server of some kind, that could be jetty, tomcat, jboss etc. Jerome doesn't mention which one he's using but I see plenty of instructions on how to use Jetty under IIS.
Note that performance may be affected by your choice. Also note that Apache Tomcat is different from Apache HTTP. The latter is the direct competitor for serving regular webpages. Apache Tomcat can also be run behind IIS too.
Enjoy,
Alex
On 05/03/2013 02:31 PM, Jerome A. Wendell wrote:
Mark,
Jerome Wendell
Subject: [Geoserver-users] IIS and GeoserverI apologize if this has been answered before, but can geoserver function
without installing Apache Tomcat on IIS running on windows server 2008 R2?------------------------------------------------------------------------------
Get 100% visibility into Java/.NET code with AppDynamics Lite
It's a free troubleshooting tool designed for production
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap2_______________________________________________
Geoserver-users mailing list
Mark,
Jerome Wendell
On Fri, May 3, 2013 at 4:44 PM, Mark Paulson <markp@anonymised.com> wrote:
Thanks Jerome. I have installed geoserver and can access it at localhost:8080/geoserver/web/
But I am having a heck of a time accessing it at:
http://www.myserver.com:8080/geoserver/web/
Any ideas what I am doing wrong?
Can you access it via http://your.ip.address.here:8080/geoserver/web ?
Mark,
Are you by chance using a proxy? I use OpenLayers to access the data served by GeoServer, and I recall having to make sure my proxy host was setup correctly.
Sent: Friday, May 03, 2013 5:45 PM
To: jawendell@anonymised.com
Cc: geoserver-users@anonymised.comceforge.net
Subject: Re: [Geoserver-users] IIS and Geoserver
From: “Jerome A. Wendell” <jawendell@anonymised.com>
Reply-To: “jawendell@anonymised.com” <jawendell@anonymised.com>
Date: Friday, May 3, 2013 4:31 PM
To: “Mark R. Paulson” <markp@anonymised.com.>, “geoserver-users@lists.sourceforge.net” <geoserver-users@lists.sourceforge.net>
Subject: RE: [Geoserver-users] IIS and Geoserver
Mark,
Jerome Wendell
I am using Oracle JRE 6.43.
-----Original Message-----
Sent: Friday, May 03, 2013 5:37 PM
Cc: 'Mark Paulson'; geoserver-users@lists.sourceforge.net
Enjoy,
Alex
Mark,
Jerome Wendell
2008 R2?
-------- Get 100% visibility into Java/.NET code with AppDynamics Lite
It's a free troubleshooting tool designed for production Get down to
Mark,
Another thought, make sure that the port geoserver uses is not blocked by the firewall on the server.
Hope this helps,
Jerome
To: “Mark R. Paulson” <markp@anonymised.com>, “geoserver-users@lists.sourceforge.net” <geoserver-users@lists.sourceforge.net>
Mark,
Jerome Wendell
No, I cannot access it that way either. I suspect a permission issue, but I am not sure where geoserver/web/ points to on the server
Date: Friday, May 3, 2013 4:57 PM
Cc: “jawendell@anonymised.com” <jawendell@anonymised.com>, “geoserver-users@lists.sourceforge.net” <geoserver-users@lists.sourceforge.net>
Ciao mark,
can you access the logs and check if there are any obvious errors?
I installed the bin locally on my Win box and I can find those files here:
- C:\Users\User\Downloads\geoserver-2.2-SNAPSHOT\data_dir\logs this
contains a file called geoserver.log that contains the log of
geoserver itself
- C:\Users\User\Downloads\geoserver-2.2-ENTERPRISE-SNAPSHOT\logs this
contains the log of the embedded servlet container (jetty)
Notice that IMHO I would recommend using Tomcat together with the WAR
install of GeoServer, especially for production usage.
Simone Giannecchini
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
am not sure where geoserver/web/ points to on the serverFrom: Michael Moore <stuporglue@anonymised.com>
Date: Friday, May 3, 2013 4:57 PMTo: "Mark R. Paulson" <markp@anonymised.com>
Cc: "jawendell@anonymised.com" <jawendell@anonymised.com>,
"geoserver-users@lists.sourceforge.net"
<geoserver-users@lists.sourceforge.net>Subject: Re: [Geoserver-users] IIS and Geoserver
Any ideas what I am doing wrong?Can you access it via http://your.ip.address.here:8080/geoserver/web ?
Finally figured it out, had to open the port in the router. Forgot that I shut most things down when I set up the VPN.
Date: Saturday, May 4, 2013 9:26 AM
To: Michael Moore <stuporglue@anonymised.com>
Cc: “geoserver-users@lists.sourceforge.net” <geoserver-users@lists.sourceforge.net>
