Hello!
I'm trying to build image mosaic from some DOFs. And this is what i get as a
result.
27.2.2008 11:28:17 it.geosolutions.utils.imagemosaic.MosaicIndexBuilder
getNotification
INFO: Progress is at 0.0
attached message is: Now indexing file a230862a_a1.tif
27.2.2008 11:28:19 it.geosolutions.utils.imagemosaic.MosaicIndexBuilder
getNotification
INFO: Progress is at 0.08967391304347826
attached message is: Done with file E:\err_tif\a230862a_a1.tif27.2.2008 11:28:19 it.geosolutions.utils.imagemosaic.MosaicIndexBuilder
getNotification
INFO: Progress is at 0.09057971014492754
attached message is: Now indexing file a230862a_a2.tif
27.2.2008 11:28:19 org.geotools.gce.geotiff.GeoTiffFormat getReader
WARNING: GEOTIFF Module Error Report
GeoTiffMetadata2CRSAdapter::createUserDefinedProjectionParameter(String
name):User defined projections must specify coordinate transformation code
in ProjCoordTransGeoKey
ModelPixelScaleTag: [0.5,0.5,1.0]
ModelTiePointTag: (1 tie points)
TP #0: [0.0,0.0,0.0] -> [381312.5,100000.0,0.0]
ModelTransformationTag: NOT AVAILABLE
GeoKey #1: Key = 1, Value = null
GeoKey #2: Key = 1024, Value = 1
GeoKey #3: Key = 1025, Value = 1
GeoKey #4: Key = 2054, Value = 9102
GeoKey #5: Key = 3072, Value = 32767org.geotools.data.DataSourceException: GEOTIFF Module Error Report
GeoKey #5: Key = 3072, Value = 32767at org.geotools.gce.geotiff.GeoTiffReader.<init>(GeoTiffReader.java:219)
at
org.geotools.gce.geotiff.GeoTiffFormat.getReader(GeoTiffFormat.java:252)
at
org.geotools.gce.geotiff.GeoTiffFormat.getReader(GeoTiffFormat.java:212)
at
it.geosolutions.utils.imagemosaic.MosaicIndexBuilder.run(MosaicIndexBuilder.java:354)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.geotools.gce.geotiff.GeoTiffException: GEOTIFF Module Error
Report
org.geotools.gce.geotiff.crs_adapters.GeoTiffMetadata2CRSAdapter.createUserDefinedProjectionParameter(GeoTiffMetadata2CRSAdapter.java:1101)
at
org.geotools.gce.geotiff.crs_adapters.GeoTiffMetadata2CRSAdapter.createUserDefinedPCS(GeoTiffMetadata2CRSAdapter.java:660)
at
org.geotools.gce.geotiff.crs_adapters.GeoTiffMetadata2CRSAdapter.createProjectedCoordinateSystem(GeoTiffMetadata2CRSAdapter.java:303)
at
org.geotools.gce.geotiff.crs_adapters.GeoTiffMetadata2CRSAdapter.createCoordinateSystem(GeoTiffMetadata2CRSAdapter.java:240)
at
org.geotools.gce.geotiff.GeoTiffReader.getHRInfo(GeoTiffReader.java:271)
at org.geotools.gce.geotiff.GeoTiffReader.<init>(GeoTiffReader.java:198)
... 4 more
Exception in thread "MosaicIndexBuilder" java.lang.NullPointerException
at
it.geosolutions.utils.imagemosaic.MosaicIndexBuilder.run(MosaicIndexBuilder.java:357)
I'm using coverage tools from geotools 2.3.x.
-s E:\err_tif -w *.tif
Every DOF has a .tfw and a .prj file included. Are there some problems with
GeoTiffs?
View this message in context: http://www.nabble.com/Image-Mosaic-Builder-tp15710397p15710397.html
