I'm getting what looks like the same explosion with a fresh svn update. This
time, though, it occurred when I was adding the CoverageStore. Here's the
stack trace:
GeoServer - Exception
The following exception was thrown:
* class java.lang.NullPointerException:
Details:
at org.geoserver.data.util.CoverageUtils.getParameters(CoverageUtils.java:139)
at org.vfny.geoserver.config.CoverageConfig.(CoverageConfig.java:291)
at org.vfny.geoserver.action.data.DataCoveragesNewAction.newCoverageConfig(DataCoveragesNewAction.java:106)
at org.vfny.geoserver.action.data.CoverageStoresEditorAction.execute(CoverageStoresEditorAction.java:90)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Thus spake Simone Giannecchini (simone.giannecchini@anonymised.com):
Cool,
I am doing some enhancements on the mosaic plugin itself, I have just
committed some code I had around here floating around.
Can you do an update and test it?
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Mon, Apr 20, 2009 at 9:13 PM, Eric W Anderson
<Eric.Anderson@anonymised.com> wrote:
> Yes.
>> Ciao Erik,
>> quick question, you are building GeoServer out of the 1.7.x branc?
>> Simone.
>> GeoSolutions S.A.S.
>> Via Carignoni 51
>> 55041 Camaiore (LU)
>> Italy
>> fax: +39 0584983027
>> On Mon, Apr 20, 2009 at 9:02 PM, Eric W Anderson
>> > Hi All,
>> > I'm trying to create an image mosaic data store, following the tutorial at
>> > http://geoserver.org/display/GEOSDOC/Using+the+ImageMosaic+plugin . My input
>> > files are all USGS digital elevation model GeoTIFFs in WGS84 projection. I'm
>> > using the GDAL route, as I don't have the MosaicImageBuilder installed. The
>> > problem is this: I get to the point of successfully creating the new Coverage
>> > Store, but when I try to create the new Coverage, it explodes with a null
>> > pointer exception.
>> > Any suggestions? I've attached what I'm guessing to be useful information. I'm
>> > using the 1.7.x svn branch of GeoServer.
>> > Thanks,
>> > Eric
>> > Eric W. Anderson University of Colorado
>> > eric.anderson@anonymised.com Dept. of Computer Science
>> > phone: +1-720-984-8864 Systems Research Lab - ECCR 1B54
>> > PGP key fingerprints:
>> > personal: 1BD4 CFCE 8B59 8D6E EA3E EBD5 4DC9 3E61 656C 462B
>> > academic: D3C5 D6FF EDED 9F1F C36D 53A3 74B7 53A6 3C74 5F12
>> > -----BEGIN PGP SIGNATURE-----
>> > Version: GnuPG v1.4.9 (GNU/Linux)
>> > iEYEARECAAYFAknsxtYACgkQdLdTpjx0XxJt0QCdGb5HWVLaB/PTcf/THhxjN6D/
>> > 6AMAoI1YgrJGYjjQrDUvXDJQnCWCWuaL
>> > =SuAu
>> > -----END PGP SIGNATURE-----
>> > Stay on top of everything new and different, both inside and
>> > around Java (TM) technology - register by April 22, and save
>> > $200 on the JavaOne (SM) conference, June 2-5, 2009, San Francisco.
>> > 300 plus technical and hands-on sessions. Register today.
>> > Use priority code J9JMT32. http://p.sf.net/sfu/p
>> > _______________________________________________
>> > Geoserver-users mailing list
>> > Geoserver-users@lists.sourceforge.net
>> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
> iEYEARECAAYFAknsyWIACgkQdLdTpjx0XxKPmwCeLhrt0AFeyadjXmjN75RiVkdS
> 5kIAn1ZN0E0CDrT7REaSFyCAC++cX6rf
> =qZF/
