[Geoserver-users] image mosaic custom dimension to select raster images from their footprints
Hello list,
Thanks in advance for your help with the following.
We have a large number of raster images and a shape file (sample attached) with polygons each representing the footprint of each raster image.
The use case would be to display the footprints on a map and give the user the ability to click on a polygon / footprint in order to display the corresponding raster image.
I would appreciate a lot your guidance regarding the approach to take in order to configure Geoserver Image mosaic to serve the above purpose. Which of the below approaches is correct?
  • Configure the indexer and regex properties files for a custom parameter, e.g. location along side the shapefile containing the footprints of the images. Do I need to configurethe footprints.properties file too?
OR
  • Define the indexer.xml
Many thanks
Ivo
footprints.dbf (2.55 KB)
footprints.prj (335 Bytes)
footprints.shp (1.43 KB)
footprints.shx (180 Bytes)
Ciao Ivo,
if the ImageMosaic content changes over time it would be better to use
a real DBMS as the index, like postgis or oracle.
That said, sticking with a shapefile, I would simple add another
attribute ot it (postprocess with QGIS for exmple) with a unique
identifier for each row in the shapefile (e.g. the filename or an
UUID) and expose the shapefile also as an indipendent layer. You can
then send CQL_FILTER vendor option to the imagemosaic layer to filter
individual granules using such attribute.
As an alternative, if this an administrative gui you can use the REST
Interface for ImageMosaic that let's you access the index with WFS
like syntax over REST calls:
http://geoserver.geo-solutions.it/multidim/en/rest/index.html
Another alternative to explore would be to use FIDs to syncrhonize the
polygon layer with the mosaic layer.
Generally speaking I would not rely too much on exposing the location attribute.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Sep 1, 2015 at 12:15 PM, Ivo Gatto <ivo.gatto@anonymised.com> wrote:
Hello list,
OR
Many thanks
Ivo
Geoserver-users mailing list
Ciao Simone,
Thanks for your email.
The image mosaic content does not change, hence no need to use a DBMS at the moment, but thank you for pointing it out as the use case might change in the future.
I will add the unique identifier to the shape file as you suggested and expose the shp file as a layer within geoserver.
I assume I still need to configure the custom parameter for the image mosaic! Shall I need to do so through the properties files (if so, can you please list all the properties files I need to configure? do you have an example of indexer and regex files for the definition of the custom parameter?) or do I need to use the indexer.xml file instead?
Many thanks
Ivo
On Fri, Sep 4, 2015 at 11:01 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Ivo,
Interface for ImageMosaic that let’s you access the index with WFS
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Hello list,
OR
Many thanks
Ivo
Ciao Ivo,
please, read below...
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Fri, Sep 4, 2015 at 6:29 PM, Ivo Gatto <ivo.gatto@anonymised.com> wrote:
Ciao Simone,
the future.
mosaic!
Not really, you can send filters to the imagemosaic using CQL_FILTER
vendor option or via OGC XML Filters and expect this to be applied on
portions of the underlying mosaic index.
Using an additional dimension is another way to do that but requires a
little more config.
The easiest thing at that point would be to use an indexer.properties
to parse as an instance the filename (assuming it is unique) and
putting that into a String attribute.
Many thanks
Ivo
Ciao Ivo,
attribute.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
> Hello list,
> attached)
> user
> Which
> parameter,
> OR
> Many thanks
> Ivo
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Hi Simone,
Many thanks. I’ll try and keep you posted!
In the meantime, have a nice week end.
Ivo
Sent: Friday, September 4, 2015 5:29 PM
To: Simone Giannecchini
Cc: geoserver-users
Subject: Re: [Geoserver-users] image mosaic custom dimension to select raster images from their footprints
Ciao Simone,
Many thanks
Ivo
On Fri, Sep 4, 2015 at 11:01 AM, Simone Giannecchini <simone.giannecchini@anonymised.com1107…> wrote:
Ciao Ivo,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hello list,
OR
Many thanks
Ivo
Hi Simone,
It works using the CQL_FILTER.
Many thanks
Ivo
On Friday, September 4, 2015, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Ivo,
please, read below…
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Fri, Sep 4, 2015 at 6:29 PM, Ivo Gatto <ivo.gatto@anonymised.com…84…> wrote:
Ciao Simone,
the future.
mosaic!
little more config.
Many thanks
Ivo
simone.giannecchini@anonymised.com wrote:
Ciao Ivo,
attribute.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Tue, Sep 1, 2015 at 12:15 PM, Ivo Gatto ivo.gatto@anonymised.com wrote:
Hello list,
attached)
user
Which
parameter,
OR
Many thanks
Ivo
Geoserver-users@anonymised.comurceforge.net
