Hi everybody,
I am currently updating my GeoServer instances to version 2.18.0 (thanks
to everybody contributing and making this real!). I am missing the
"imagemosaic-jdbc" extension at
https://sourceforge.net/projects/geoserver/files/GeoServer/2.18.0/extensions/.
Did I oversee anything or has the location changed for this?
Thanks for any hint.
Chris
That module was downgraded to unsupported as it has no maintainer (see https://geotoolsnews.blogspot.com/2020/09/geotools-240-released.html) so you will now need to build it yourself,
Ian
Ian Turton
Morning Christian,
the imagemosaic-jdbc plugin has been moved back to “community” modules.
You will find it in the nightly snapshots download area:
https://build.geoserver.org/geoserver/2.18.x/community-latest/
The direct link:
https://build.geoserver.org/geoserver/2.18.x/community-latest/geoserver-2.18-SNAPSHOT-imagemosaic-jdbc-plugin.zip
Hope this helps.
Best Regards,
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Ian and Daniele,
thank you very much for your help! Taking the community module of “imagemosaic-jdbc” solved this for me.
All the best
Chris
On 07.10.20 09:29, Daniele Romagnoli wrote:
Morning Christian,
The direct link:
Hope this helps.
Best Regards,
Daniele
On Wed, Oct 7, 2020 at 7:47 AM Christian Mayer <ml-cm@anonymised.com> wrote:
Hi everybody,
“imagemosaic-jdbc” extension at
Chris
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Daniele Romagnoli
