[Geoserver-users] Image Mosaic JDBC - not working
Hello,
we are using "Geoserver 2.4 RC1" with "tomcat7" on "Ubuntu 12.04". Everything is working fine with the exclusion of the "Image Mosaic JDBC"-plugin.
The .jar-file is at the right place:
user@anonymised.com:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib$ ls -l
total 55928
-rw-r--r-- 1 tomcat7 tomcat7 62983 May 31 2012 activation-1.1.jar
-rw-r--r-- 1 tomcat7 tomcat7 323036 Aug 18 13:06 gt-imagemosaic-10-RC1.jar
-rw-r--r-- 1 root root 112034 Aug 23 16:38 gt-imagemosaic-jdbc-10-RC1.jar
-rw-r--r-- 1 tomcat7 tomcat7 188058 Aug 18 13:05 gt-jdbc-10-RC1.jar
However, in the geoserver web application (localhost:8080/geoserver) there is no possibility to add an Image Mosaic JDBC as a store
Raster Data Sources
  ArcGrid - Arc Grid Coverage Format
  GeoTIFF - Tagged Image File Format with Geographic information
  Gtopo30 - Gtopo30 Coverage Format
  ImageMosaic - Image mosaicking plugin
  WorldImage - A raster file accompanied by a spatial data file
Other Data Sources
We need it for importing postgis raster. Where is our mistake?
Best Regards
Frederik
Hello,
I am sorry to send the request again. However, it is my first time writing to this user-list and I am really lost!
In the geoserver web application (localhost:8080/geoserver) there is no possibility to add an Image Mosaic JDBC as a store. However, the .jar-file is at the right place and everything else is working quite fine.
Best Regards
Frederik
On Fri, 23 Aug 2013 17:13:46 +0200
  "Frederik Haefker" <fhaefker@anonymised.com> wrote:
Hello,
total 55928
Raster Data Sources
Other Data Sources
Best Regards
Frederik
Hi Frederik
I did a quick test on the master branch and anything works fine.
Did you check the file permissions of
/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/imagemosaich-jdbc-.jar
Maybe you copied the jar file using the “root” user and tomact is using the “tomcat” user. In this case, tomcat could have problems opening the jar file.
Summary:
Check if your tomcat user can open the jar file.
Christian
On Tue, Aug 27, 2013 at 3:50 PM, Frederik Haefker <fhaefker@anonymised.com> wrote:
Hello,
fine.
mistake?
Best Regards
Frederik
“Frederik Haefker” <fhaefker@anonymised.com> wrote:
Hello,
we are using “Geoserver 2.4 RC1” with “tomcat7” on
“Ubuntu 12.04”. Everything is working fine with the
exclusion of the “Image Mosaic JDBC”-plugin.
ls -l
total 55928
-rw-r–r-- 1 tomcat7 tomcat7 62983 May 31 2012
activation-1.1.jar
-rw-r–r-- 1 tomcat7 tomcat7 323036 Aug 18 13:06
-rw-r–r-- 1 root root 112034 Aug 23 16:38
-rw-r–r-- 1 tomcat7 tomcat7 188058 Aug 18 13:05
gt-jdbc-10-RC1.jar
Raster Data Sources
information
data file
Other Data Sources
mistake?
Best Regards
Frederik
Introducing Performance Central, a new site from SourceForge and
AppDynamics. Performance Central is your source for news, insights,
analysis and resources for efficient Application Performance Management.
Visit us today!
http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
thanks for the help. However, its not the solution.
Actually you are right and I used sudo cp. But tomcat works quite fine with it (for example the proxy plugin was installed correctly).
Just to make sure I changed the user-rights (sudo chmod -R ugo+rwx /var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/) and restarted tomcat (sudo service tomcat7 restart ). Sadly it changed nothing.
Any other suggestions?
Best Regards
Frederik
On Tue, 27 Aug 2013 16:33:13 +0200
  Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Frederik
/var/lib/tomcat7/
webapps/geoserver/WEB-INF/lib/imagemosaich-jdbc-<version>.jar
Maybe you copied the jar file using the "root" user and tomact is using the
"tomcat" user. In this case, tomcat could have problems opening the jar
file.
Summary:
Christian
On Tue, Aug 27, 2013 at 3:50 PM, Frederik Haefker <fhaefker@anonymised.com>wrote:
Hello,
fine.
mistake?
Best Regards
Frederik
> Hello,
>ls -l
> total 55928
>activation-1.1.jar
>gt-jdbc-10-RC1.jar
> Raster Data Sources
>information
>data file
> Other Data Sources
>mistake?
> Best Regards
>Frederik
Visit us today!
Hi Frederik
Please stay on the mailing list for discussions.
Go to Global Settings and switch the log level to VERBOSE_LOGGING. Stop GeoServer and remove the log file from the file system. Start geoserver, and zip the new logfile.
Repeat the same procedure with GEOTOOLS_DEVELOPER_LOGGING and GEOSERVER_DEVELOPER_LOGGING.
Sent those 3 zip files to me (private mail, not on the mailing list).
On Tue, Aug 27, 2013 at 5:25 PM, Frederik Haefker <fhaefker@anonymised.com> wrote:
Sorry :slight_smile:
I am not so sure how to answer your last mail … shall I send you the whole log as an attachment or just search for a special error? The geoserver.log is 3.1 mb big and there are 3 more with 10 mb each.
Best Regards
Frederik
On Tue, 27 Aug 2013 17:19:53 +0200
Christian Mueller <christian.mueller@anonymised.comsolutions.at> wrote:
Hi Frederik
Check the log files. Go to “Global Settings” to change the log level if it
is necessary. Maybe we find a hint in log/geoserver.log
On Tue, Aug 27, 2013 at 4:54 PM, Frederik Haefker <fhaefker@anonymised.com>wrote:
Hi Christian,
/var/lib/tomcat7/webapps/**geoserver/WEB-INF/lib/) and restarted tomcat
Best Regards
Frederik
Christian Mueller <christian.mueller@anonymised.com**solutions.at<christian.mueller@anonymised.com.solutions.at>>
wrote:
Hi Frederik
/var/lib/tomcat7/
webapps/geoserver/WEB-INF/lib/**imagemosaich-jdbc-.**jar
the
file.
Summary:
Christian
wrote:
Hello,
fine.
mistake?
Best Regards
Frederik
Hello,
user@anonymised.com:/var/lib/tomcat7/**webapps/geoserver/WEB-INF/lib$
ls -l
total 55928
activation-1.1.jar
gt-imagemosaic-jdbc-10-RC1.**jar
gt-jdbc-10-RC1.jar
Raster Data Sources
information
data file
Other Data Sources
mistake?
Best Regards
Frederik
Visit us today!
/4140/ostg.clktrk<http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk>
_____________**
Geoserver-users@anonymised.com**sourceforge.net<Geoserver-users@lists.sourceforge.net>
https://lists.sourceforge.net/**lists/listinfo/geoserver-users<https://lists.sourceforge.net/lists/listinfo/geoserver-users>
Hi Christian,
I did as you told me, but no new log files was created.
For all 5 logging profiles I used following settings:
Settings that apply to the entire server.
Verbose Messages
Verbose Exception Reporting
Enable Global Service
For restart I used:
user@anonymised.com$ sudo service tomcat7 restart
* Stopping Tomcat servlet engine tomcat7 [ OK ]
* Starting Tomcat servlet engine tomcat7 [ OK ]
I searched in /var/lib/tomcat7/webapps/geoserver/data/logs for the logs. This is the right location regarding the geoserver global setting (logs/geoserver.log)
I will send you some screenshots on your private mail. Hopefully that will help.
Thanks again!
On Wed, 28 Aug 2013 07:46:34 +0200
Hi Frederik
On Tue, Aug 27, 2013 at 5:25 PM, Frederik Haefker <fhaefker@anonymised.com>wrote:
I am not so sure how to answer your last mail ... shall I send you the
Best Regards
Frederik
Christian Mueller <christian.mueller@anonymised.com**solutions.at<christian.mueller@anonymised.com>>
wrote:
Hi Frederik
Check the log files. Go to "Global Settings" to change the log level if it
>wrote:
Hi Christian,
/var/lib/tomcat7/webapps/****geoserver/WEB-INF/lib/) and restarted
tomcat
Best Regards
Frederik
Christian Mueller <christian.mueller@anonymised.com**soluti**ons.at<http://solutions.at>
<christian.mueller@anonymised.com**solutions.at <christian.mueller@anonymised.com>
wrote:
Hi Frederik
/var/lib/tomcat7/
webapps/geoserver/WEB-INF/lib/****imagemosaich-jdbc-<version>.****jar
the
file.
Summary:
Christian
>wrote:
Hello,
fine.
mistake?
Best Regards
Frederik
> Hello,
> user@anonymised.com:/var/lib/tomcat7/****webapps/geoserver/WEB-INF/**lib$
>ls -l
> total 55928
>activation-1.1.jar
>gt-imagemosaic-jdbc-10-RC1.****jar
>gt-jdbc-10-RC1.jar
> Raster Data Sources
>information
>data file
> Other Data Sources
>mistake?
> Best Regards
>Frederik
Management.
Visit us today!
http://pubads.g.doubleclick.****net/gampad/clk?id=48897511&iu=****
/4140/ostg.clktrk<http://**pubads.g.doubleclick.net/**
gampad/clk?id=48897511&iu=/**4140/ostg.clktrk<http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk&gt;
______________________________****_________________
Geoserver-users@anonymised.com**source**forge.net <http://sourceforge.net><
Geoserver-users@**lists.sourceforge.net<Geoserver-users@lists.sourceforge.net>
https://lists.sourceforge.net/****lists/listinfo/geoserver-**users&lt;https://lists.sourceforge.net/**lists/listinfo/geoserver-users&gt;
<https://lists.**sourceforge.net/lists/**listinfo/geoserver-users<https://lists.sourceforge.net/lists/listinfo/geoserver-users>
Hi erveryone,
the Image Mosaic JDBC works fine and I could publish a png as shown in the tutorial:
http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html
However, when I try to publish my own geotiff I get an error message:
"Oops, something went wrong...
Sorry, something unexpected happened on the server.
Here's an error report you can include in a JIRA bug report about this issue: "
Sadly I am not able to register a JIRA.
Error
It seems that you have tried to perform an operation that is not allowed in the current JIRA mode.
If you think this message is wrong, please contact your JIRA administrators.
Here an extract from the geoserver-error:
java.lang.RuntimeException: Error occurred while building the resources for the configuration page at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:307) at org.geoserver.web.data.layer.NewLayerPage$6.onClick(NewLayerPage.java:242) at org.geoserver.web.wicket.SimpleAjaxLink$1.onClick(SimpleAjaxLink.java:45) at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:68) at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177) at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300) at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119) at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
Best Regards
Frederik
On Wed, 28 Aug 2013 16:39:07 +0200
Never mind, I hope you will have success with your configuration.
Christian
Hi Christan,
thanks again for the help.
Sadly I don't understand what you mean by writing a simple test program. Regarding the geoserver status page JAI is working fine:
Native JAI true
Native JAI ImageIO true
I will send you the log-files and screenshots separately.
Gdalinfo doesn't work directly due to the storage location of the geotiff - its in a Postgis database.
However, before uploading the geotiff gives following informations:
user@anonymised.com:$ gdalinfo 1.tif
Driver: GTiff/GeoTIFF
Files: 1.tif
Size is 740, 731
Coordinate System is `'
Origin = (-19.000000763971848,38.099999237060544)
Pixel Size = (0.100000002064789,-0.100000000000000)
Metadata:
   lat#axis=Y
   lat#long_name=latitude
   lat#standard_name=latitude
   lat#units=degrees_north
   lon#axis=X
   lon#long_name=longitude
   lon#standard_name=longitude
   lon#units=degrees_east
   NC_GLOBAL#CDI=Climate Data Interface version 1.5.8 (http://code.zmaw.de/projects/cdi)
   NC_GLOBAL#CDO=Climate Data Operators version 1.5.8 (http://code.zmaw.de/projects/cdo)
   NC_GLOBAL#Conventions=COARDS
   NC_GLOBAL#FilePath=//scratch/output/WASCAL-DOMAIN-TRMM-6min2010.nc
   NC_GLOBAL#history=Mon Jan 07 13:32:51 2013: cdo div /scratch/output/WASCAL-DOMAIN-TRMM-6min2010-YEARSUM-Runoff.nc /scratch/output/WASCAL-DOMAIN-TRMM-6min2010-YEARSUM-Precip.nc /scratch/output/WASCAL-DOMAIN-TRMM-6min2010-YEARSUM-RunoffCoeff.nc
Mon Jan 07 13:32:51 2013: cdo selname,precip /scratch/output/WASCAL-DOMAIN-TRMM-6min2010-YEARSUM.nc /scratch/output/WASCAL-DOMAIN-TRMM-6min2010-YEARSUM-Precip.nc
Mon Jan 07 13:31:57 2013: cdo yearsum /scratch/output/WASCAL-DOMAIN-TRMM-6min2010.nc /scratch/output/WASCAL-DOMAIN-TRMM-6min2010-YEARSUM.nc
Created on 2013-01-02 by Alex Prusevich (alex.proussevitch@anonymised.com)
   NC_GLOBAL#institution=Water Systems Analysis Group (WSAG), the University of New Hampshire (UNH)
   NC_GLOBAL#NetCDF_version=netCDF.3.5.1
   NC_GLOBAL#projection=epsg:4326
   NC_GLOBAL#references=http://www.wsag.unh.edu
   NC_GLOBAL#Temporal_Res.=Daily
   NC_GLOBAL#title=PDL/WBM data
   runoff#_FillValue=-9999
   runoff#long_name=Runoff
   runoff#units=mm/day
   time#calendar=standard
   time#standard_name=time
   time#units=days since 1900-01-01 00:00:00
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -19.0000008, 38.0999992)
Lower Left ( -19.0000008, -35.0000008)
Upper Right ( 55.0000008, 38.0999992)
Lower Right ( 55.0000008, -35.0000008)
Center ( 18.0000000, 1.5499992)
Band 1 Block=740x2 Type=Float32, ColorInterp=Gray
   NoData Value=-9999
   Metadata:
     _FillValue=-9999
     long_name=Runoff
     NETCDF_DIMENSION_time=40541
     NETCDF_time_units=days since 1900-01-01 00:00:00
     NETCDF_VARNAME=runoff
     units=mm/day
On Sun, 1 Sep 2013 09:18:44 +0200
Hi Frederik
The first question is if JAI (Java advanced Imaging) is able to read your
image. Can make a simple test program and reading and writing your image
(compare the results).
You can switch the log level on "Global settings" page to
GEOTOOLS-DEVELOPER and look into the log file.
What is the output of gdalinfo <yourimage>
Christian
On Fri, Aug 30, 2013 at 11:18 AM, Frederik Haefker <fhaefker@anonymised.com>wrote:
Hi erveryone,
error message:
Error
at
at
at
at
at
at
at
at
at
Best Regards
Frederik
>configuration.
> Christian
Learn the latest--Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58040911&iu=/4140/ostg.clktrk
Hi Frederik
This is strange. In the file geoserver_aftererror.log I see
2013-09-03 13:35:57,116 INFO [org.geotools.gce.imagemosaic.jdbc] - Using 8 CPU(s)
2013-09-03 13:35:57,129 INFO [org.geotools.gce.imagemosaic.jdbc] - Getting 1 Tiles needs 13 millisecs
2013-09-03 13:35:57,134 INFO [org.geotools.gce.imagemosaic.jdbc] - Getting and decoding 1 Tiles needs 18 millisecs
2013-09-03 13:35:57,160 INFO [org.geotools.gce.imagemosaic.jdbc] - Mosaic Reader needs : 48 millisecs
The imagemosaic JDBC module finished its job and returns an image to GeoServer. Unfortunately, I cannot see the exception causing this error.
Without the the data I cannot debug. (Do you have the possibility to start a debug session).
If not, I would need your configuration xml files, the image and all the scripts for importing the image data into postgres.
Christian
On Tue, Sep 3, 2013 at 1:42 PM, Frederik Haefker <fhaefker@anonymised.com> wrote:
Hello Christan,
thanks for your help!!!
The screenshots and log-files are attached. I made a log-file before and after the error while trying to add a postgis-raster-layer.
Best Regards Frederik
Hi Christian,
I have full control of the geoserver (sudo etc.). So I think I can start a debug session. Sadly I don't know what to do :slight_smile: (sorry)
In my last message I sent you a file called error-log.txt which included a copy of the full error message. Maybe we can find a hint there?
I can send you the scripts (which one do you need?). However I can't send any data itself (due to restriction of my working group).
Thanks again
Best Regards
Frederik
On Tue, 3 Sep 2013 17:00:55 +0200
Hi Frederik
CPU(s)
a debug session).
Christian
On Tue, Sep 3, 2013 at 1:42 PM, Frederik Haefker <fhaefker@anonymised.com>wrote:
Hello Christan,
Good Morning,
I just tried following idea:
first I converted the geotiff to png
Then I followed the instruction of the tutorial.
I didn't get the error message when I published the layer.
The layer can be loaded to the main map and uses the correct style information.
However I see gaps inside the raster and a huge black boarder. This must have happened during the transformation from geotiff to png. It is visible in a desktop image viewer too.
So, how to translate geotiff into png probably?
And still, png is not a good solution for raster data ... what to do about the geoserver error?
On Tue, 03 Sep 2013 17:07:33 +0200
Hi Christian,
Thanks again
Best Regards
Frederik
Hi Frederik
CPU(s)
a debug session).
Christian
About the geoserver error
No chance without a debug session, I cannot see anything from the log files.
Have a look at the supported formats
http://www.oracle.com/technetwork/java/iio-141084.html
On Wed, Sep 4, 2013 at 10:05 AM, Frederik Haefker <fhaefker@anonymised.com> wrote:
Good Morning,
I didn’t get the error message when I published the layer.
And still, png is not a good solution for raster data … what to do about the geoserver error?
Hi Christian,
I have full control of the geoserver (sudo etc.). So I think I can start a debug session. Sadly I don’t know what to do :slight_smile: (sorry)
I can send you the scripts (which one do you need?). However I can’t send any data itself (due to restriction of my working group).
Thanks again
Best Regards
Frederik
Hi Frederik
CPU(s)
a debug session).
Christian
Thanks a lot for your effort and help!!!
Do you have any idea why I can't create an account at http://jira.codehaus.org/browse/GEOS/ To create a new issue?
It is recommended in the error message of geoserver:
"Here's an error report you can include in a JIRA bug report about this issue:"
Best Regards
Frederik
On Wed, 4 Sep 2013 10:51:39 +0200
files.
On Wed, Sep 4, 2013 at 10:05 AM, Frederik Haefker <fhaefker@anonymised.com>wrote:
Good Morning,
information.
Hi Christian,
Thanks again
Best Regards
Frederik
wrote:
Hi Frederik
2013-09-03 13:35:57,116 INFO [org.geotools.gce.imagemosaic.**jdbc] -
Using 8
CPU(s)
2013-09-03 13:35:57,129 INFO [org.geotools.gce.imagemosaic.**jdbc] -
Getting
2013-09-03 13:35:57,134 INFO [org.geotools.gce.imagemosaic.**jdbc] -
Getting
2013-09-03 13:35:57,160 INFO [org.geotools.gce.imagemosaic.**jdbc] -
Mosaic
start
a debug session).
Christian
Hmmm, No idea how create an account, I did this a long time ago.
Can you open a new thread on the user list asking how to get a JIRA account. I can remember some people having the same problem but I forgot the solution.
On Wed, Sep 4, 2013 at 10:59 AM, Frederik Haefker <fhaefker@anonymised.com> wrote:
Do you have any idea why I can’t create an account at http://jira.codehaus.org/browse/GEOS/ To create a new issue?
“Here’s an error report you can include in a JIRA bug report about this issue:”
Best Regards
Frederik
files.
Good Morning,
information.
Hi Christian,
Thanks again
Best Regards
Frederik
wrote:
Hi Frederik
Using 8
CPU(s)
Getting
Getting
Mosaic
start
a debug session).
Christian
Hi Frederik
During the last weekend I fixed a problem
https://jira.codehaus.org/browse/GEOT-4561
Maybe this will fix your issue too.
You can test with a nightly build or I can send you a jar file.
Christian
On Wed, Sep 4, 2013 at 11:41 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Best Regards
Frederik
files.
Good Morning,
information.
Hi Christian,
Thanks again
Best Regards
Frederik
wrote:
Hi Frederik
Using 8
CPU(s)
Getting
Getting
Mosaic
start
a debug session).
Christian
