Do you have any chance to share the full geoserver LOG (with logging set to VERBOSE) and a sample ECW replicating the issue (in case the data you are using can be shared)?
On Fri, Jan 9, 2015 at 8:18 PM, Giuseppe Falcone <falcone.giuseppe@anonymised.com> wrote:
Hi Daniele,
thanks a lot for the response.
I have tried to create a layer with a single ecw and it’s working in geoserver preview.
The layer created with the image mosaic plugin working if I doing a getMap request; don’t working (blank images) from geoserver preview.
Best regards.
Giuseppe
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
2015-01-09 14:13 GMT+01:00 Daniele Romagnoli <daniele.romagnoli@anonymised.com.1107…>:
Hi Giuseppe,
We didn’t try with the latest ECW SDK yet.
Do you have any chance to setup an ECW CoverageStore (instead of the ImageMosaic one) on top of a single ECW file and check it on the layer preview?
This will allow us to understand if is it a problem at ImageMosaic side or if the underlying reader which doesn’t work, in order to isolate the issue.
Please, let us know.
Best Regards,
Daniele
On Fri, Jan 9, 2015 at 12:10 PM, Giuseppe Falcone <falcone.giuseppe@anonymised.com> wrote:
add other information. I have installed native JAI but the behaviour is the same.
This is the log on a getMap request:
2015-01-09 12:05:04,122 INFO [geoserver.wms] -
Request: getMap
Width = 1512
Height = 603
Palette = null
Tiled = false
SRS = EPSG:26592
FeatureVersion = null
Styles = [StyleImpl[ name=raster]]
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Crs = PROJCS[“Monte Mario (Rome) / Italy zone 2”,
GEOGCS[“Monte Mario (Rome)”,
DATUM[“Monte Mario (Rome)”,
SPHEROID[“International 1924”, 6378388.0, 297.0, AUTHORITY[“EPSG”,“7022”]],
AUTHORITY[“EPSG”,“6806”]],
PRIMEM[“Rome”, 12.452333333333332, AUTHORITY[“EPSG”,“8906”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4806”]],
PROJECTION[“Transverse_Mercator”, AUTHORITY[“EPSG”,“9807”]],
PARAMETER[“central_meridian”, 15.0],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“scale_factor”, 0.9996],
PARAMETER[“false_easting”, 2520000.0],
PARAMETER[“false_northing”, 0.0],
UNIT[“m”, 1.0],
AXIS[“Easting”, EAST],
AXIS[“Northing”, NORTH],
AUTHORITY[“EPSG”,“26592”]]
Bbox = SRSEnvelope[2456504.6459961 : 2463685.3540039, 4512498.1326294 : 4515361.8673706]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = true
StyleFormat = sld
SldBody = null
ValidateSchema = false
Sld = null
StyleUrl = null
TilesOrigin = null
Exceptions = SE_XML
StyleBody = null
SldVersion = null
StyleVersion = null
Format = image/png
Buffer = 0
Time =
Filter = null
Filters = null
Get = true
RawKvp = {TRANSPARENT=TRUE, BBOX=2456504.6459961,4512498.1326294,2463685.3540039,4515361.8673706, VERSION=1.1.1, FORMAT=image/png, SERVICE=WMS, HEIGHT=603, LAYERS=topp:Napoli, REQUEST=GetMap, STYLES=, SRS=EPSG:26592, WIDTH=1512}
BaseUrl = http://192.168.11.16:8080/geoserver/
RequestCharset = UTF-8
Version = 1.1.1
Request = GetMap
2015-01-09 12:05:04,123 DEBUG [wms.map] - Writing png image …
2015-01-09 12:05:04,135 DEBUG [geotools.styling] - number of fts set 1
2015-01-09 12:05:04,247 DEBUG [wms.map] - Writing png image … done!
2015-01-09 12:05:04,247 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
2015-01-09 12:05:04,247 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
I noticed that in mosaic properties file missing envelope 2D params. It’s normal? Anyone has some ideas?
Thanks again.
Giuseppe
Dive into the World of Parallel Programming! The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net
Geoserver-users mailing list
2015-01-08 17:23 GMT+01:00 Giuseppe Falcone <falcone.giuseppe@anonymised.com>:
I have some problem with my geoserver installation.
I have installed geoserver 2.6.1 on an Ubuntu server x64 14.04 LTS.
I have installed also gdal with ecw support from ECW SDK 5.1.
I create an image mosaic from a folder with some ecw images.
Geoserver create the shapefile index and the properties file correctly, but in the layer preview i see only blank images.
I have tried to change some attributes (tile size, output format, wms version, …) but the result not change.
I see that the properties file has attributes different from those on geoserver documentation. This is my properties file:
#-Automagically created from GeoTools-
#Thu Jan 08 15:49:51 CET 2015
Levels=0.5,0.5
Heterogeneous=false
AbsolutePath=false
Name=Napoli
TypeName=Napoli
Caching=false
ExpandToRGB=false
LocationAttribute=location
SuggestedSPI=it.geosolutions.imageio.plugins.ecw.ECWImageReaderSpi
CheckAuxiliaryMetadata=false
LevelsNum=1
Anyone has some ideas? Thanks a lot.
Giuseppe
