[Geoserver-users] Image Mosaic Plugin composing behaviour
Hello,
i have a question concerning the raster data merge behaviour of the image mosaic plugin in combination with temporal wms requests. Here’s my setup:
  • Geoserver 2.6.2 running in a Tomcat 7 container on ubuntu 12 server
  • configured image mosaic plugin with geotiff’s and postgis, as suggested in the tutorial
  • geotiffs are added every 7 minutes and are valid within this interval (i have a datefrom and dateto timestamp in the database)
  • Layer is configured to use time dimension with presentation set to “continuous interval” and default value “Use the biggest domain value”
  • Merge behaviour is set to “FLAT”
The time support docs say that i can plot several measurements (in this case a raster of rain amounts) over a certain time window: “you might have a single dataset with weather observations collected over time and choose to plot a single day’s worth of observations.” http://docs.geoserver.org/latest/en/user/services/wms/time.html
So i expected geoserver to somehow compose a picture of several raster files when i query the wms for an one hour interval. Instead geoserver returns the first geotiff that meets the lower end time of my requested interval.
Is it possible to configure the geoserver in a way, that it will accumulate all raster data for the requested interval within a single layer, or did i missunderstand the capabilities of time support and the image mosaic plugin? And are there other Merge behaviours than FLAT?
Thanks in advance,
Marc Schenke
Hi Marc,
quick question:
are these GeoTiffs scattered “around the world” or are all of them covering the same exact Bounding Box instead, where the only difference is the 7 minutes validity time?
Daniele
On Mon, Mar 2, 2015 at 9:13 AM, Marc Schenke <mschenke@anonymised.com> wrote:
Hello,
Thanks in advance,
Marc Schenke
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Daniele,
the only difference is the validity time, all raster files cover the exact same area. However after checking the corresponding geometry column i noticed that sometimes the bounding box declaration varies. It is always in the same geographic location (when i look at them on the map) but the order of points within the polygon differs. I am not sure if this is an issue, since it is always the same set of coordinates.
Marc
Date: Mon, 2 Mar 2015 10:17:04 +0100
Subject: Re: [Geoserver-users] Image Mosaic Plugin composing behaviour
To: mschenke@anonymised.com
CC: geoserver-users@anonymised.comforge.net
Hi Marc,
quick question:
Daniele
Hello,
Thanks in advance,
Marc Schenke
Hi Marc,
In that case, the “FLAT” merge behaviour does what its name suggests:
It takes all the matching inputs and FLAT them all together to a single image.
Next questions then:
  • Which datatypes of images are you merging? (Byte RGB/Byte Gray/Real measurements (temperature/humidity/…)/…?)
  • Since all the input images cover the same area, what kind of visual output are you expecting from a set of them?
I mean… if you are mosaicking images covering different locations, you may want to get back a single image made of all those scattered pieces. In this case, you will populate instead the same geographic area with data coming from different times. Are you looking for a multibands image where each band is made of data coming from a different time of the same region? Or are you looking instead for a 3D output (lat/lon+time) to be used into another client? (I’m thinking about setting a NetCDF output with a time dimension to be view in Panoply, ToolsUI, …).
Please, let us know what is your intended usage.
Daniele
On Mon, Mar 2, 2015 at 10:37 AM, Marc Schenke <mschenke@anonymised.com> wrote:
Hi Daniele,
Marc
CC: geoserver-users@lists.sourceforge.net
Hi Marc,
quick question:
Daniele
On Mon, Mar 2, 2015 at 9:13 AM, Marc Schenke <mschenke@anonymised.com…> wrote:
Hello,
Thanks in advance,
Marc Schenke
Hello Daniele,
the GeoTiffs contain real measurement of rain in milimeters per m² per hour. Basically every cell in the raster contains floating point numbers. I have hoped to receive an accumulated raster as response, when querying with a time interval. The task is to display the amount of rain for a user defined time interval. For example if the interval encloses ten files, the result should contain the accumulated rain amount for every cell from the matching files.
The client is a web interface based on Open Layers 2.
Flattening in the sense that all files are combined into a single image/band is what i am looking for. How are cell values ( colors or measurements ) computed when two images overlap each other?
Marc
Date: Mon, 2 Mar 2015 11:06:19 +0100
Hi Marc,
Daniele
Hi Daniele,
Marc
Hi Marc,
quick question:
Daniele
Hello,
Thanks in advance,
Marc Schenke
Hi Marc,
nope… The ImageMosaic is “simply” an image collector which returns back a mosaic of data from a set of available rasters. You can perform filtering on some area/dimensions/attributes; you can flat all the pieces of the mosaic to a single image or stack them into different bands but you can’t get math computations results (as sum, average, std_dev) from them.
A thing which may work is playing with renderingTransformations (which are operations performed on the fly on the data, configured through a style applied to the layer) to do what you need.
I’m wondering if using a STACK mergeBehaviour (which stacks different pieces of the mosaic to different bands) and applying a renderingTransformation doing sum of the bands will do the trick. I’m also wondering if we need to know in advance the number of output bands in order to setup the required computation.
More info or samples on renderingTransformation are here:
http://docs.geoserver.org/stable/en/user/styling/sld-extensions/rendering-transform.html
http://geoserver.geo-solutions.it/edu/en/wps/rendering_tx.html#point-extraction
The latest one also contains a “wind arrows” paragraph where it uses a style containing ogc:Add operation which could be used to compose additions of bands.
Hopefully, other developers may also add their feedbacks on the topic.
Daniele
On Mon, Mar 2, 2015 at 11:49 AM, Marc Schenke <mschenke@anonymised.com> wrote:
Hello Daniele,
Marc
Hi Marc,
Daniele
On Mon, Mar 2, 2015 at 10:37 AM, Marc Schenke <mschenke@anonymised.com…> wrote:
Hi Daniele,
Marc
Hi Marc,
quick question:
Daniele
Hello,
Thanks in advance,
Marc Schenke
Hi Daniele,
currently it looks like the plugin is not merging several images at all. When i query rain data within range of a day i just receive the first geotiff image. I would have expected to see at least the several different rain locations of a day within my bounding box in one picture, while overlaying rain locations are not summarized.
Using the STACK mode resulted again in a single image with a single band. As long as i cannot fix this issue, i cannot test the renderingTransformation methods suggested by you.
I attached a piece of the geoserver.log that shows how all relevant files are selected, but somewhere on the way they are lost.
Then i had closer look to the image merging code and found out that the actual pixel value calculation is handled by JAI as described in the MosaicDescriptor Class → http://docs.oracle.com/cd/E17802_01/products/products/java-media/jai/forDevelopers/jai-apidocs/javax/media/jai/operator/MosaicDescriptor.html
There are two modes, BLEND and OVERLAY. Blend does look a bit like it could be useful for me. In the geotools plugin this mode seems to be controlled by a blend parameter (RasterLayerRequest.java, member: blend). However i was not able to figure out where this parameter is initially set to a value or how i can change this parameter in geoserver. I tried to add it to the layers xml configuration but that did not change the current behaviour.
I am not sure if this discussion belongs to geoserver or geotools mailing lists.
Marc
Date: Mon, 2 Mar 2015 13:07:40 +0100
Hi Marc,
Daniele
Hello Daniele,
Marc
Hi Marc,
Daniele
Hi Daniele,
Marc
Hi Marc,
quick question:
Daniele
Hello,
Thanks in advance,
Marc Schenke
geoserver.log (38.5 KB)
Hi Marc,
do you have any chance to share a subset of your dataset? If you have a couple of granules ad different times (such as T0, T0+7minutes, T0+14minutes) to replicate the issue, I would like to take a look at the STACKING mergeBehaviour with your sample case.
Please, let us know.
Daniele
On Tue, Mar 3, 2015 at 5:32 PM, Marc Schenke <mschenke@anonymised.com> wrote:
Hi Daniele,
Marc
To: mschenke@anonymised.com…5777…
Hi Marc,
Daniele
On Mon, Mar 2, 2015 at 11:49 AM, Marc Schenke <mschenke@anonymised.com…> wrote:
Hello Daniele,
Marc
To: mschenke@anonymised.com77…
Hi Marc,
Daniele
Hi Daniele,
Marc
Hi Marc,
quick question:
Daniele
Hello,
Thanks in advance,
Marc Schenke
Hi Marc,
I did a very quick look at the code and it seems that the STACK behaviour does stacking only in case additional dimensions have been specified.
We may consider extending its capabilities in order to do stacking “in general” (although that need some thinking in order to avoid stacking when granules are displaced at different bboxes, which is one of the more common use cases)
Cold you please open a JIRA for an improvement?
Daniele
On Fri, Mar 13, 2015 at 2:52 PM, Marc Schenke <mschenke@anonymised.com> wrote:
Hi Daniele,
thank you for your all your efforts concerning this issue. I attached two hours of data and the configuration files for the image mosaic plugin to this mail. The OpenLayers client i use, always sends requests with a from/to Time-interval to quey the data. As i mentioned the first file matching the interval is always delivered. Maybe it is because the mosaic plugin merges the first file at last and in FLAT mode it overwrites the other pictures?
When i use STACK mode the delivered file is still way too small to contain all the different bands. As soon as i have a little bit more time i’ll try to look at the ImageMosaic code again to figure out what i am doing wrong.
Marc
Date: Mon, 9 Mar 2015 17:09:53 +0100
Hi Marc,
Daniele
On Tue, Mar 3, 2015 at 5:32 PM, Marc Schenke <mschenke@anonymised.com…> wrote:
Hi Daniele,
Marc
Hi Marc,
Daniele
Hello Daniele,
Marc
Hi Marc,
Daniele
Hi Daniele,
Marc
Hi Marc,
quick question:
Daniele
Hello,
Thanks in advance,
Marc Schenke
Ciao,
chiming in to clarify (hopefully>).
The use case for which I implemented Stacking in the past was the
ability to support requests a-la WMS-EO where you manage multiple
dimensions (e.g. wavelenght or polarization) as separate files inside
an image mosaic.
As such when you mosaick with this data you really want to access the
individual bands separately rather flattening them onto a single band.
As daniele said we could extend this functionality to work even
without taking multiple dimensions into account, but that requires
some coding.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Mar 13, 2015 at 4:50 PM, Daniele Romagnoli
<daniele.romagnoli@anonymised.com> wrote:
Hi Marc,
We may consider extending its capabilities in order to do stacking "in
general" (although that need some thinking in order to avoid stacking when
use cases)
Daniele
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Hi Daniele,
all the different bands. As soon as i have a little bit more time i'll try
Marc
Hi Marc,
Daniele
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
Hi Daniele,
MosaicDescriptor Class ->
behaviour.
lists.
Marc
Hi Marc,
nope... The ImageMosaic is "simply" an image collector which returns back
mosaic to a single image or stack them into different bands but you can't
I'm wondering if using a STACK mergeBehaviour (which stacks different
renderingTransformation doing sum of the bands will do the trick. I'm also
The latest one also contains a "wind arrows" paragraph where it uses a
of bands.
Daniele
wrote:
Hello Daniele,
matching files.
Marc
Hi Marc,
In that case, the "FLAT" merge behaviour does what its name suggests:
image.
- Which datatypes of images are you merging? (Byte RGB/Byte Gray/Real
measurements (temperature/humidity/...)/...?)
- Since all the input images cover the same area, what kind of visual
I mean... if you are mosaicking images covering different locations, you
another client? (I'm thinking about setting a NetCDF output with a time
dimension to be view in Panoply, ToolsUI, ...).
Daniele
wrote:
Hi Daniele,
Marc
Hi Marc,
quick question:
are these GeoTiffs scattered "around the world" or are all of them
Daniele
Hello,
mosaic plugin in combination with temporal wms requests. Here's my setup:
configured image mosaic plugin with geotiff's and postgis, as suggested in
the tutorial
"continuous interval" and default value "Use the biggest domain value"
Merge behaviour is set to "FLAT"
case a raster of rain amounts) over a certain time window: "you might have a
plot a single day’s worth of observations."
interval.
Thanks in advance,
Marc Schenke
sponsored
all
to
sponsored
all
to
Hi Simone, hi Daniele,
with the test files i configured another ImageMosaic store and raster layer with “STACK” merge behaviour and i could again verify that the result always represents the first file, that was collected from the mosaic plugin. A look at the geotools logging suggests, that the order in which the plugin collects files seems to follow no specific rule:
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T163000_20150301T163729.tif
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T163730_20150301T164459.tif
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T164500_20150301T165229.tif
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T160000_20150301T160729.tif
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T162230_20150301T162959.tif
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T160730_20150301T161459.tif
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T165230_20150301T165959.tif
  • Adding to mosaic granule file:/local/geoserver-data/rain_sum/rain_20150301T161500_20150301T162229.tif
You mentioned that STACKing only works for different dimensions. Would that rule out any chance to create the desired effect with render transformations, as Daniele suggested? I really need to get this working and i am willing to do some coding for it, though i would prefer another configurable solution if possible (render transformation). Please point me to the direction which is more likely to result in the desired effect. When there is no way around modifying the code, i will open the requested Improvement Issue in JIRA and try to throw some effort to it.
Marc
Date: Fri, 13 Mar 2015 17:14:47 +0100
To: daniele.romagnoli@anonymised.com
CC: mschenke@anonymised.com; geoserver-users@lists.sourceforge.net
Ciao,
an image mosaic.
some coding.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
daniele.romagnoli@anonymised.com wrote:
Hi Marc,
use cases)
Daniele
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
On Fri, Mar 13, 2015 at 2:52 PM, Marc Schenke mschenke@anonymised.com wrote:
Hi Daniele,
Marc
Hi Marc,
Daniele
On Tue, Mar 3, 2015 at 5:32 PM, Marc Schenke mschenke@anonymised.com wrote:
Hi Daniele,
behaviour.
lists.
Marc
CC: geoserver-users@anonymised.comrge.net
Hi Marc,
of bands.
Daniele
On Mon, Mar 2, 2015 at 11:49 AM, Marc Schenke mschenke@anonymised.com
wrote:
Hello Daniele,
matching files.
Marc
Hi Marc,
image.
Daniele
On Mon, Mar 2, 2015 at 10:37 AM, Marc Schenke mschenke@anonymised.com
wrote:
Hi Daniele,
Marc
Hi Marc,
quick question:
Daniele
On Mon, Mar 2, 2015 at 9:13 AM, Marc Schenke mschenke@anonymised.com wrote:
Hello,
the tutorial
interval.
Thanks in advance,
Marc Schenke
sponsored
all
to
sponsored
all
to
Hi Daniele, hi Simone,
another question i completely forgot: can i create accumulated rasters, when i put the data into a postgis database, instead of using tif files?
Marc
To: daniele.romagnoli@anonymised.com; simone.giannecchini@anonymised.com
Date: Wed, 18 Mar 2015 15:53:21 +0100
Marc
CC: mschenke@anonymised.com5777…; geoserver-users@lists.sourceforge.net
Ciao,
an image mosaic.
some coding.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Marc,
use cases)
Daniele
Hi Daniele,
Marc
Hi Marc,
Daniele
Hi Daniele,
behaviour.
lists.
Marc
Hi Marc,
of bands.
Daniele
wrote:
Hello Daniele,
matching files.
Marc
CC: geoserver-users@anonymised.comet
Hi Marc,
image.
Daniele
wrote:
Hi Daniele,
Marc
Hi Marc,
quick question:
Daniele
Hello,
the tutorial
interval.
Thanks in advance,
Marc Schenke
sponsored
all
to
sponsored
all
to
------------------------------------------------------------------------------ Dive into the World of Parallel Programming The Go Parallel Website, sponsored by Intel and developed in partnership with Slashdot Media, is your hub for all things parallel software development, from weekly thought leadership blogs to news, videos, case studies, tutorials and more. Take a look and join the conversation now. http://goparallel.sourceforge.net/
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Hi Marc,
please, read below…
On Wed, Mar 18, 2015 at 3:53 PM, Marc Schenke <mschenke@anonymised.com> wrote:
As reported by Simone, when he developed the STACKING logic, he did that for a specific use case. So the behaviour you are reporting is expected.
The logging you see is reporting the granules found on the folder, which are added to the mosaic index.
This order depends on how the File.list method returns files after scanning the folder.
A different thing is the order the granules are returned from the index when you do a query (as when performing a read operation on a time range). As an instance, in case granules cover the same region at different times, you may impose a “sort by time, in descending order” policy in order to get the youngest granule. You may configure the mosaic layer by setting the SORTING parameter.
As an instance: time D
to ask for queries returning granules sorted by the value of the “time” attribute of the schema, in _D_escending order
My suggestion was based on the assumption that the STACKing behave differently. I wasn’t aware of/I didn’t remember the underlying logic before checking the code. Therefore, I don’t think there is currently a way to achieve that without doing any code.
Since we are talking about development, an alternative way you may also consider is developing a process which takes granules from the structured reader 1 (note the ImageMosaic implements the StructuredGridCoverageReader) and does the sum you need.
Daniele
Marc
CC: mschenke@anonymised.com; geoserver-users@anonymised.comsourceforge.net
Ciao,
an image mosaic.
some coding.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hi Marc,
use cases)
Daniele
Hi Daniele,
Marc
Hi Marc,
Daniele
Hi Daniele,
behaviour.
lists.
Marc
CC: geoserver-users@anonymised.comists.sourceforge.net
Hi Marc,
of bands.
Daniele
wrote:
Hello Daniele,
matching files.
Marc
Hi Marc,
image.
Daniele
wrote:
Hi Daniele,
Marc
To: mschenke@anonymised.com7…
Hi Marc,
quick question:
Daniele
Hello,
the tutorial
interval.
Thanks in advance,
Marc Schenke
sponsored
all
to
sponsored
all
to
Geoserver-users@anonymised.comrge.net
