[Geoserver-users] Image Mosaic Plugin - Index Table - ORACLE
Hello,
On my current project we are using an ImageMosaic to display aerial photography for England. We are also working to enable the TIME attribute on the layer so that we can display historic imagery.
Working in test environment I used postGIS to successfully generate the index table following the instructions here:
http://docs.geoserver.org/latest/en/user/tutorials/imagemosaic_timeseries/imagemosaic_timeseries.html
However, as our production environment is Oracle based, I have had to try and replicate the indexer.properties file, but to be compatible with Oracle spatial. I believe I am having trouble passing the geometry to table as an SDO_GEOMETRY type, I have been unable to find any Oracle support on this aspect of the properties file.
My indexer.properties file is as follows
TimeAttribute=flownDate Schema=*Geometry:POLYGON,location:VARCHAR2,flownDate:java.util.Date,current:VARCHAR2 PropertyCollectors=TimestampFileNameExtractorSPI[timeregex](flownDate)
Connection to the DB works fine, I can tell this as a new table does get created in my DB but with what I believe to be a default schema:
FID Number(38,0)
LOCATION Varchar2(255)
THE_GEOM SDO_GEOMETRY
Does anybody have experience with this and could shed any light on my issue? Your help is greatly appreciated.
Regards, Gavin
View this message in context: Image Mosaic Plugin - Index Table - ORACLE
All, No response so far - has anybody used Oracle for Image Mosaic??
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Image-Mosaic-Plugin-Index-Table-ORACLE-tp5169346p5169690.html
On Mon, Oct 27, 2014 at 10:57 AM, gavin.montgomery <
We did some time ago, it was working (well, we had to make some
improvements to the
code, to handle some Oracle oddities, but they were contributed to
GeoServer).
Which version of GeoServer are you using?
Can you share your mosaic config files?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea, Thanks for your response.
Slightly complicated, in test we are using 2.4.4 - I have suggested we
upgrade in production which we will do at a later date to 2.4.8 (appreciate
not the most recent but we have had efficiency issues with our aerial
photoraphy on 2.5.x using JPEG compressed images).
Using a 2.4.4 test on my machine postGIS has no issues, if you believe it
was corrected by 2.4.8 I may have to press the environment team to upgrade
our geoserver sooner!
Files attached - FYI we use the imagery tile name and a year in the regex
expression. i.e. SY0204_2014.tiff
mosaics.zip <http://osgeo-org.1560.x6.nabble.com/file/n5169711/mosaics.zip&gt;
Regards
Gavin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Image-Mosaic-Plugin-Index-Table-ORACLE-tp5169346p5169711.html
On Mon, Oct 27, 2014 at 1:19 PM, gavin.montgomery <gavin.montgomery@anonymised.com...
Please do report them with an reproducable test case, the 2.4.x series is
dead, there won't be any more releases out of it. The current stable is
2.6.x,
2.5.x already got in maintenance mode (mostly bug fixes)
I don't know exactly which version would be working, but found something odd
in your schema definition:
Schema=SDO_GEOMETRY:POLYGON,location:VARCHAR2,flownDate:java.util.Date,current:VARCHAR2
SDO_GEOMETRY is a type name in oracle, I believe the above won't work, nor
will using
VARCHAR2, the schema is not a SQL one, it's a java one, the data store will
decide
which native sql type to use for you.
How comes you decided to use SQL types, is there some misleanding
documentation around?
Could you try this one?
Schema=geom:Polygon,location:String,flownDate:java.util.Date,current:String
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
Thank you again for your comments, unfortunately your suggestion has not
worked. Considering your suggestion regarding GeoServer versions, I will
endeavour to update the server on our development environment. It may
perhaps solve the problem.
In response to your statement regarding documentation, the only
documentation I can find is PostGIS based, in the geoserver docs, it may be
helpful if the documentation in this area could be expanded. The I sent you
had been through many different iterations in the attempt to get a positive
result, admittedly the one I sent you was not sure to work! :slight_smile:
Thank you for your help, I will further my efforts in this and update the
forum if I have any success. If anybody else has come across this I would
appreciate your comments.
Regards
Gavin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Image-Mosaic-Plugin-Index-Table-ORACLE-tp5169346p5169742.html
