[Geoserver-users] Image Mosaic Plugin with PostGIS index produces no maps in KML
Hi everybody.
I am using the ImageMosaic plugin to publish several images stored on the file system but using the PostGIS index.
I use the Postgis index because I upload new images quite often and I use SQL commands to update the index rather than updating the local shapefile.
This solution using the plugin and CQL_FILTER works fine for WMS, but once I try to preview the layer as a KMZ and use CQL filters, It simply doesn’t work.
With no CQL FILTER, using the KML throws a big bunch of exceptions (All images are Geotiff’s, created using the GeoTIFF writer), while the second including a CQL filter throws the a Class cast Exception between ‘S’ and ‘B’(literally).
I tried also using the Image Mosaic plugins but with a shapefile index with the same results!! WMS works but the KML doesnt, producing the same exceptions.
Any idea??
Josafat
The first Set of exceptions are:
09 Dec 01:17:12 INFO [geoserver.wms] -
Request: getMap
Time =
Format = application/vnd.google-earth.kmz
Buffer = 0
Filters = [[ obra = 1812A ]]
Filter = [[ obra = 1812A ]]
Width = 1024
Height = 1024
Tiled = false
Palette = null
SRS = EPSG:4326
FeatureVersion = null
Legend = false
Styles = [StyleImpl[ name=raster]]
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Bbox = ReferencedEnvelope[-93.91304957604716 : -91.19681347301871, 17.50472513959039 : 19.19687393788794]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
FormatOptions = {=true, SUPEROVERLAY=false, KMPLACEMARK=false, KMSCORE=40, KMATTR=true}
Angle = 0.0
CQLFilter = [[ obra = 1812A ]]
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Crs = GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]]
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = false
SldBody = null
ValidateSchema = false
Sld = null
SldVersion = null
TilesOrigin = null
Exceptions = SE_XML
KMScore = 40
KMattr = true
Version = 1.1.1
Request = GetMap
RawKvp = {BBOX=-93.91304957604716,17.50472513959039,-91.19681347301871,19.19687393788794, SERVICE=wms, HEIGHT=1024, REQUEST=GetMap, STYLES=raster, WIDTH=1024, CQL_FILTER=(obra=‘1812A’), TRANSPARENT=false, VERSION=1.1.1, FORMAT=application/vnd.google-earth.kmz, FORMAT_OPTIONS=SUPEROVERLAY:false;KMPLACEMARK:false;KMSCORE:40;KMATTR:true;, LAYERS=FAV:fav2, SRS=EPSG:4326}
Get = true
BaseUrl = http://localhost:8080/geoserver/
RequestCharset = UTF-8
Error: One factory fails for the operation “Mosaic”
Occurs in: org.geoserver.jai.ConcurrentOperationRegistry
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor97.invoke(Unknown Source)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:130)
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1679)
at org.geoserver.jai.ConcurrentOperationRegistry.invokeFactory(ConcurrentOperationRegistry.java:412)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:340)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:830)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:878)
at javax.media.jai.RenderedOp.getWidth(RenderedOp.java:2190)
at org.geotools.image.ImageWorker.affine(ImageWorker.java:2806)
at org.geotools.gce.imagemosaic.RasterLayerResponse.postProcessRaster(RasterLayerResponse.java:762)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:703)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:661)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:339)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:617)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.readBestCoverage(RenderedImageMapOutputFormat.java:1314)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:855)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:332)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:254)
at org.geoserver.kml.KMZMapResponse.write(KMZMapResponse.java:129)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:912)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:97)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.IllegalArgumentException: All source images must have the same data type.
at com.sun.media.jai.opimage.MosaicOpImage.getLayout(MosaicOpImage.java:127)
at com.sun.media.jai.opimage.MosaicOpImage.(MosaicOpImage.java:208)
at com.sun.media.jai.opimage.MosaicRIF.create(MosaicRIF.java:47)
… 94 more
09 Dec 01:17:14 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:334)
Caused by: org.geoserver.platform.ServiceException: java.lang.RuntimeException: - Unable to render RenderedOp for this operation.
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:915)
… 75 more
Caused by: java.lang.RuntimeException: - Unable to render RenderedOp for this operation.
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:838)
… 76 more
The second exception are occurs when using CQL filters, and just dumps a Error for Class cast Exception between ‘B’ and ‘S’
Ir. Josafat Guerrero
MSc Geomatics
55-3973-2346
