(GeoServer 2.6.2, Postgres 9.3.6; Ubuntu 14.04; JNDI pools via Tomcat)
I am experiencing another hard to track down issue with harvesting / creating new image mosaics via REST … that seems to be occurring after time passes.
What I mean is that harvesting & creating new mosaics works fine most of the time. However, it seems to fail after some amount of time passes. For instance, if I have not created a new mosaic via REST for a day or 2, and I try to create one, it will fail. If I then try to create several more via REST, again, they all fail.
If I restart Tomcat or postgres and then run the very same REST call (via gsconfig in python) against the very same data, voila, it is successful. After restart, I can then go on creating multiple new mosaics via REST over the course of many hours.
Let some time pass, though, and I’ll start seeing failures again.
Yes, this is a troubleshooting nightmare.
My initial thoughts have been this has something to do with stale connections via JNDI … but I have validation turned on, both in JNDI Tomcat Resource and in datastore.properties. I have tried leaving in the eviction settings (shown in some of the JNDI Image Mosaic examples) and removing them … but this still doesn’t help.
What’s odd is that I have no problems accessing existing mosaic indexes backed via JNDI. It just seems the ability to create new ones goes bad after some time passes (usually 24 hours or so).
Again, JNDI has been a suspicion. I kind of also am asking myself if something is somehow getting garbage collected that shouldn’t be (I know that sounds strange) … or something else is somehow disappearing over time that would prevent successful mosaic creation via REST.
Does this sound familiar to anyone? Any pointers?
The stack trace from when this happens is below.
Thanks!
30 Apr 19:02:45 INFO [catalog.rest] - PUT file, mimetype: application/zip
30 Apr 19:02:45 INFO [catalog.rest] - Auto-configuring coverage store: sppub–mikegtest20150430–gust
Apr 30, 2015 7:02:45 PM org.geotools.jdbc.JDBCJNDIDataStoreFactory createDataSource
WARNING: Using java:comp/env/jdbc/stormprint instead of jdbc/stormprint would avoid an unnecessary JNDI lookup
30 Apr 19:02:45 WARN [geotools.jdbc] - Failure occurred while looking up the primary key with finder: org.geotools.jdbc.HeuristicPrimaryKeyFinder@anonymised.com
org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:252)
at org.postgresql.jdbc2.AbstractJdbc2DatabaseMetaData.getPrimaryKeys(AbstractJdbc2DatabaseMetaData.java:3057)
at org.geotools.jdbc.HeuristicPrimaryKeyFinder.getPrimaryKey(HeuristicPrimaryKeyFinder.java:49)
at org.geotools.jdbc.CompositePrimaryKeyFinder.getPrimaryKey(CompositePrimaryKeyFinder.java:52)
at org.geotools.jdbc.JDBCDataStore.getPrimaryKey(JDBCDataStore.java:1066)
at org.geotools.jdbc.JDBCFeatureSource.(JDBCFeatureSource.java:94)
at org.geotools.jdbc.JDBCDataStore.createFeatureSource(JDBCDataStore.java:910)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:388)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:353)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:103)
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.extractBasicProperties(GTDataStoreGranuleCatalog.java:258)
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.createType(GTDataStoreGranuleCatalog.java:559)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.createType(CachingDataStoreGranuleCatalog.java:103)
at org.geotools.gce.imagemosaic.RasterManager.createStore(RasterManager.java:1263)
at org.geotools.gce.imagemosaic.ImageMosaicReader.createCoverage(ImageMosaicReader.java:1114)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.updateConfiguration(ImageMosaicConfigHandler.java:845)
at org.geotools.gce.imagemosaic.ImageMosaicWalker.handleFile(ImageMosaicWalker.java:210)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.handleFile(ImageMosaicDirectoryWalker.java:98)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:367)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:114)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196)
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:354)
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1223)
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:505)
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:457)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:483)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:212)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:103)
at org.geoserver.catalog.rest.CoverageStoreFileResource.handlePut(CoverageStoreFileResource.java:208)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:800)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:649)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
30 Apr 19:02:45 ERROR [imagemosaic.catalog] - org.geotools.jdbc.JDBCFeatureSource cannot be cast to org.geotools.data.simple.SimpleFeatureStore
java.lang.ClassCastException: org.geotools.jdbc.JDBCFeatureSource cannot be cast to org.geotools.data.simple.SimpleFeatureStore
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.removeGranules(GTDataStoreGranuleCatalog.java:319)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.removeGranules(CachingDataStoreGranuleCatalog.java:233)
at org.geotools.gce.imagemosaic.catalog.GranuleCatalogStore.removeGranules(GranuleCatalogStore.java:88)
at org.geotools.gce.imagemosaic.CatalogManager.updateCatalog(CatalogManager.java:406)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.updateConfiguration(ImageMosaicConfigHandler.java:937)
30 Apr 19:02:45 ERROR [imagemosaic.Utils] - org.geotools.jdbc.JDBCFeatureSource cannot be cast to org.geotools.data.simple.SimpleFeatureStore
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.addGranules(GTDataStoreGranuleCatalog.java:350)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.addGranules(CachingDataStoreGranuleCatalog.java:85)
at org.geotools.gce.imagemosaic.catalog.GranuleCatalog.addGranule(GranuleCatalog.java:55)
at org.geotools.gce.imagemosaic.catalog.GranuleCatalogStore.addGranules(GranuleCatalogStore.java:56)
at org.geotools.gce.imagemosaic.CatalogManager.updateCatalog(CatalogManager.java:409)
30 Apr 19:02:45 WARN [gce.imagemosaic] - Failure occurred while collecting the granules
org.apache.commons.io.DirectoryWalker$CancelException: Operation Cancelled
at org.apache.commons.io.DirectoryWalker.checkIfCancelled(DirectoryWalker.java:395)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:368)
30 Apr 19:02:45 ERROR [geoserver.rest] - Could not aquire reader for coverage.
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.CoverageStoreFileResource.handlePut(CoverageStoreFileResource.java:211)
