Hi Daniele,
After turning on verbose logging, I did see that those black images are coming back black as it think they are “No Data” values. I’m running GeoServer on SuSE Linux with 32 cores and 128GB of RAM. My image mosaic layer is configured with USE_JAIR_IMAGEREAD=false and allowMultithreading=true. Since in the log I saw “No Data”, I turned on input and output transparency in the layer configuration and now my world image seems to show up fine. It was a bit misleading because the world image tiles weren’t supposed to overlap each other and the fact that it only happened in one side of the world was misleading too.
Is the default stacking order of the image mosaic layer by fid?
Danny
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Tuesday, February 03, 2015 1:12 AM
To: Danny Cheng
Subject: Re: [Geoserver-users] Image Mosaic w/ Large Amount of Granules
Hi Danny,
A couple of questions to better understand your issue:
When you do very zoomed out request (as you want to see the whole word in a single view) the imageMosaic have to read all the granules involved at that level (so it has to read 2100 files). If your layer is configured to use JAI imageRead (USE_JAI_IMAGEREAD = true), then it may run out of file descriptors. Indeed, JAI ImageRead may keeps a lot of files open due to its deferred execution loading. Switching this parameter to false will let the ImageMosaic use immediate (in memory) read operations which means: open the file → read what it needs → close the file. You may also consider set allowMultithreading = true, which performs those read operations concurrently, using the configured Thread pool executor (see the Settings → Coverage Access configuration page).
However, since your mosaic is made of a big number of files you may also consider setting up an Image Pyramid on top of it.
Please, let us know.
Best regards,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Tue, Feb 3, 2015 at 12:33 AM, Danny Cheng <dcheng@anonymised.com> wrote:
I have an image mosaic layer with around 2100 granules that covers the whole world. Through testing, I realized that not all of my granules being displayed properly. The granules that aren’t displayed properly are returned from GeoServer as black images. If I make a smaller image mosaic layer with 30 granules in the region that was returning black images by GeoServer, this time around GeoServer is sending back the actual images correctly. Is there a recommended image mosaic configuration for large amount of granules? I tried setting the MaxAllowedTiles in the layer configuration, but that didn’t seem to fix my problem.
Danny
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
