One last question about the image mosaic. When I remove the geoserver workspace the database tables for the granule index are not removed. Are they supposed to? How do I remove the database tables
Dominique
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Wednesday, June 17, 2015 2:21 AM
To: Bessette-Halsema, Dominique E
Cc: Mike Grogan; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] image mosaic with GeoServerRESTPublisher
Hi Dominique,
I was able to configure an imageMosaic on your sample dataset without changing any line of code.
A couple of notes on the issues you had.
Why are you using both asc and TIFF files on the mosaic?
Note that your ascii files aren’t properly formed. They define a NO_DATA_VALUE field in the header whilst it should be NODATA_VALUE 1.
This results into the reader being unable to parse it. Also note that they don’t have CoordinateReferenceSystem definition so you should consider adding a PRJ beside them.
Once removing them from the mosaic folder, I found the other issue:
Your time regex isn’t matching the times defined in the filename.
If your file name is “133_2015-06-12T03_00_00.000Z.tif”, then the timeregex you specified won’t match that (I’m reporting my notes based on the files you have attached to the email):
regex = [0-9]{8}T[0-9]{9}Z(\?!.\[0-9]{8}T[0-9]{9}Z.\)
I have renamed your files as:
133_20150612T000000Z.tif which contains an ISO8601 time format and specified that regex:
regex=[0-9]{8}T[0-9]{6}Z
Which worked.
Alternatively, if you can’t change your file names, you can instruct the time parser to use a custom format.
As an instance, in order to deal with your attached files: 133_2015-06-12T03_00_00.000Z.tif
you may set this content into the timeregex.properties:
regex=[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}[0-9]{2}[0-9]{2}.[0-9]{3}Z**,format=yyyy-MM-dd’T’HH_mm_ss.SSS’Z’**
Note the regex is containing time split into pieces, due to the presence of dashes and underscores on your file name.
Then, there is a “format=yyyy-MM-dd’T’HH_mm_ss.SSS’Z’” section in order to instruct the parser that the time is formatted that way, so 4 digits for the year, a dash sign, 2 digits for the month, a dash sign… then a T char, 2 digits for the hour, an underscore and so on.
The “format” option can be added to a time regex property to deal with times which aren’t ISO8601 formatted.
Hope this helps.
Please, let us know if you still have issues.
Daniele
On Tue, Jun 16, 2015 at 7:10 PM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
I looked at the geotools code in the gt-imagemosaic module and the GridFormatFinder is reading the indexer.properties file as a NetCDF file. I added the line logExcludes.contains(extension) to the If check in the ImageMosaicWalker class line 156 and that fixed that issue. I also had to use the indexer.xml file instead of the indexer.properties file otherwise the customformat object in the TimestampFileNameExtractor is null and another error was thrown.
ImageMosaicWalker.java
if (logExcludes.contains(extension) || (format instanceof UnknownFormat) || format == null) {
if (!logExcludes.contains(extension)) {
eventHandler.fireFileEvent(Level.INFO, fileBeingProcessed, false, "Skipped file "
- fileBeingProcessed + “: File format is not supported.”,
((fileIndex * 99.0) / numFiles));
return;
I also had to update the org.geotools.data.DataUtilities class createType method because it was parsing my feature name incorrectly, but I am assuming that’s a naming convention I need to fix.
After these simple updates I can now see the correct attributes in the gis table, and the time dimension in the get capabilities document.
Dom
From: dany.geotools@anonymised.com…84… [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Tuesday, June 16, 2015 9:02 AM
Hi Dominique,
I’ll also take a look on this during the week to figure out what is going on.
Anyway, note that if you remove the indexer properties file to let the ImageMosaic work, the TIME dimension won’t be taken into account as expected. There is no way to have the time dimension properly set if the indexer is unavailable since it’s the indexer itself which contains instructions for the imageMosaic on how to retrieve the time values. Wondering if there is any problem in parsing the regexes you have specified.
Hope this helps.
Daniele.
On Tue, Jun 16, 2015 at 5:31 PM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
I’m going through the geotools code to figure it out. If I come up with a solution I’ll post it
Thanks
Dom
From: Mike Grogan [mailto:d.michael.grogan@anonymised.com]
Sent: Tuesday, June 16, 2015 8:04 AM
Dominique,
I’ll do my best to take a look at what you have sent – and see if I can load it on a system – when I can … but I’m just another fellow user.
On Mon, Jun 15, 2015 at 4:32 PM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
Hi Mike
I added the tiff and properties files from the example in the below tutorial onto my machine, and I have the same issue. I can create the database table, and datastore if I remove the indexer.properties file but then I can’t add the time and elevation dimensions. When I add the indexer.properties file I see the errors in the attached log file.
Here’s the table definition
CREATE TABLE products.“temperatureLZWdataset”
fid serial NOT NULL,
location character varying(255),
the_geom geometry,
CONSTRAINT “temperatureLZWdataset_pkey” PRIMARY KEY (fid),
CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = ‘POLYGON’::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 4326)
I attached the properties files.
Also the file names in the tutorial are in the format gfs50kmTemperature20130310T180000000Z_0200.000_.tiff but the tutorial states “Remember that every tif file must follow this naming convention: {coveragename}{timestamp}[{elevation}].tif” Shouldn’t the tiff name be “gfs50kmTemperature_20130310T180000000Z_0200.000_.tiff” ?
Thanks
Dominique
Sent: Monday, June 15, 2015 9:37 AM
Cc: Daniele Romagnoli; geoserver-users@lists.sourceforge.net
Regarding specifically the ImageMosaicDirectoryWalker errors, I am thinking this is an issue with the specification of times in your filenames and the regular expression used against that. I have found that I usually have to more fully specify the time with hours, minutes, seconds after the ‘T’ … as GeoServer is designed to recognize just some specific ISO forms of time, if I recall.
Where you have 133_2015-06-11T03.tif, you might try 133_2015-06-11T030000Z.tif and a regex of regex = _[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{6}Z, or something similar to the filename and regex patterns given in http://docs.geoserver.org/latest/en/user/tutorials/imagemosaic_timeseries/imagemosaic_time-elevationseries.html.
Whenever I hit a ImageMosaicDirectoryWalker error, it seems like it has usually been due to my definition of time in the filename and regex.
If the .asc files are giving other errors, you might try this out with just the .tif files first and see if it works when expanding the definition of time in the filename and the regex.
On Mon, Jun 15, 2015 at 11:54 AM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
Thanks for the reply. The image mosaic does not work in the console either. I see the following error.
Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file:data/dynamic/isisgridcoverage/ThresholdingMissionID-2/coaID-4/RuleID-5/ThresholdID-133 and hints null
I did reply to my original email stating that I could get the Image Mosaic to work if I remove the indexer.properties file but I can’t get the TIME dimension to work. I attached the email. Please review it.
Thank you
Dominique
Sent: Monday, June 15, 2015 1:05 AM
Hi Dominique,
a couple of feedbacks for your logs.
Please, read below…
On Fri, Jun 12, 2015 at 2:46 AM, Bessette-Halsema, Dominique E <Dominique.Bessette@anonymised.com> wrote:
Is the image mosaic the best way to add TIME and ELEVATION dimensions to a layer in geoserver?
If so, I’m having an issues creating an image mosaic with the GeoServerRESTPublisher API in GeoServer 2.7.
I create several geotiffs to a file directory within the GEOSERVER_DATA_DIR/data/. with the name structure ID_TIME.tiff (133_2015-06-11T03.tif)
I then create the indexer, timeregex and datastore properties files.
Using the GeoServerRESTPublisher I try to post the mosaic to geoserver publishExternalMosaic(workspace, storename, new File(path), coverageEnc, encoder)
It creates the ImageMosaic Store but fails when it creates the layer
I get the following error:
00:19:40,009 INFO [org.geoserver.catalog.rest] (http-/0.0.0.0:8080-2) Using existing coverage store: COA_ID_1.RULE_ID_5.THRESHOLD_ID_133
ERROR 4: `/gis/geoserver/external/data/dynamic/missionthresholding/THRESHOLDING_MISSION_ID_1/COA_ID_1/RULE_ID_5/THRESHOLD_ID_133/indexer.properties’ not recognised as a supported file format.
Not real errors… they are INFO messages. The GDAL machinery is reporting that it’s unable to open the indexer.properties file using a
GDAL driver.
00:19:40,063 ERROR [class org.geotools.gce.imagemosaic.Utils] (http-/0.0.0.0:8080-2) For input string: “E”: java.lang.NumberFormatException: For input string: “E”
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1250) [rt.jar:1.7.0_72]
at java.lang.Double.parseDouble(Double.java:540) [rt.jar:1.7.0_72]
at it.geosolutions.imageio.utilities.StringToDouble.compute(StringToDouble.java:272) [imageio-ext-utilities-1.1.10.jar:]
at it.geosolutions.imageio.plugins.arcgrid.raster.AsciiGridRaster.getValue(AsciiGridRaster.java:1154) [imageio-ext-arcgrid-1.1.10.jar:]
at it.geosolutions.imageio.plugins.arcgrid.raster.EsriAsciiGridRaster.parseHeader(EsriAsciiGridRaster.java:161) [imageio-ext-arcgrid-1.1.10.jar:]
at it.geosolutions.imageio.plugins.arcgrid.spi.AsciiGridsImageReaderSpi.canDecodeInput(AsciiGridsImageReaderSpi.java:217) [imageio-ext-arcgrid-1.1.10.jar:]
It seems some errors occurred on parsing the ASCii file’s headers. Do you have any chance to share one of these files? I’m wondering whether their Headers are properly formed.
00:29:08,039 WARN [org.geotools.gce.imagemosaic] (http-/0.0.0.0:8080-2) Failure occurred while collecting the granules: org.apache.commons.io.DirectoryWalker$CancelException: Operation Cancelled
at org.apache.commons.io.DirectoryWalker.checkIfCancelled(DirectoryWalker.java:395) [commons-io-2.1.jar:2.1]
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:368) [commons-io-2.1.jar:2.1]
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335) [commons-io-2.1.jar:2.1]
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:114) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:354) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1223) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:516) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:468) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:483) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:103) [gt-imagemosaic-13.1.jar:
As suggested by Mike, could you also check if you are able to configure it through the GeoServer GUI by simply configuring an ImageMosaic store pointing to that MOSAIC_DATA_DIR folder?
Please, let us know.
Best Regards,
Daniele
more INFO:
MOSAIC_DATA_DIR contents:
133_2015-06-11T00.asc
133_2015-06-11T01.asc
133_2015-06-11T02.asc
133_2015-06-11T03.asc
133_2015-06-11T00.tif
133_2015-06-11T01.tif
133_2015-06-11T02.tif
indexer.properties
datastore.properties
schema = geoimpact
preparedStatements = true
SPI = org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
jndiReferenceName = java:jboss/datasources/gisDB
indexer.properties:
TimeAttribute = validtime
AdditionalDomainAttributes = analysis_time
Schema = *the_geom:Polygon,location:String,validtime:java.util.Date,analysis_time:java.util.Date
PropertyCollectors = TimestampFileNameExtractorSPItimeregex,TimestampFileNameExtractorSPItimeregex
Timeregex.properties
regex = [0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}
Thanks for you help
Dom
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
