[Geoserver-users] image mosaic with GeoServerRESTPublisher
I got the imagemosaic to work if I didn’t include the indexer.properties and datastore.properties files and only had the geoTiffs. I can render the layer in the layer preview, and see it in the get capabilities document. The problem is the necessary Time dimension is not included in the get capabilities document, and I cant enable it in the geoserver console. I’m assuming that’s because I didn’t include the indexer.properties file.
All the documentation states that the ImageMosaic needs the indexer.properties file but why does geoserver 2.7 break when I include it?
My indexer.properties file:
TimeAttribute = validtime
Schema = *the_geom:Polygon,location:String,validtime:java.util.Date
PropertyCollectors = TimestampFileNameExtractorSPItimeregex
After the Imagemosaic is complete I see the .properties file created from GeoTools.
#-Automagically created from GeoTools-
#Fri Jun 12 21:56:26 UTC 2015
Levels=0.21573153409091006,0.21573153409091006
Heterogeneous=false
AbsolutePath=false
Name=ThresholdID-133
TypeName=ThresholdID-133
Caching=false
ExpandToRGB=false
LocationAttribute=location
SuggestedSPI=it.geosolutions.imageioimpl.plugins.tiff.TIFFImageReaderSpi
CheckAuxiliaryMetadata=false
LevelsNum=1
Thanks for your help
Dom
Sent: Thursday, June 11, 2015 5:47 PM
Subject: image mosaic with GeoServerRESTPublisher
Is the image mosaic the best way to add TIME and ELEVATION dimensions to a layer in geoserver?
If so, I’m having an issues creating an image mosaic with the GeoServerRESTPublisher API in GeoServer 2.7.
I create several geotiffs to a file directory within the GEOSERVER_DATA_DIR/data/. with the name structure ID_TIME.tiff (133_2015-06-11T03.tif)
I then create the indexer, timeregex and datastore properties files.
Using the GeoServerRESTPublisher I try to post the mosaic to geoserver publishExternalMosaic(workspace, storename, new File(path), coverageEnc, encoder)
It creates the ImageMosaic Store but fails when it creates the layer
I get the following error:
00:19:40,009 INFO [org.geoserver.catalog.rest] (http-/0.0.0.0:8080-2) Using existing coverage store: COA_ID_1.RULE_ID_5.THRESHOLD_ID_133
ERROR 4: `/gis/geoserver/external/data/dynamic/missionthresholding/THRESHOLDING_MISSION_ID_1/COA_ID_1/RULE_ID_5/THRESHOLD_ID_133/indexer.properties’ not recognised as a supported file format.
00:19:40,063 ERROR [class org.geotools.gce.imagemosaic.Utils] (http-/0.0.0.0:8080-2) For input string: “E”: java.lang.NumberFormatException: For input string: “E”
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1250) [rt.jar:1.7.0_72]
at java.lang.Double.parseDouble(Double.java:540) [rt.jar:1.7.0_72]
at it.geosolutions.imageio.utilities.StringToDouble.compute(StringToDouble.java:272) [imageio-ext-utilities-1.1.10.jar:]
at it.geosolutions.imageio.plugins.arcgrid.raster.AsciiGridRaster.getValue(AsciiGridRaster.java:1154) [imageio-ext-arcgrid-1.1.10.jar:]
at it.geosolutions.imageio.plugins.arcgrid.raster.EsriAsciiGridRaster.parseHeader(EsriAsciiGridRaster.java:161) [imageio-ext-arcgrid-1.1.10.jar:]
at it.geosolutions.imageio.plugins.arcgrid.spi.AsciiGridsImageReaderSpi.canDecodeInput(AsciiGridsImageReaderSpi.java:217) [imageio-ext-arcgrid-1.1.10.jar:]
00:29:08,039 WARN [org.geotools.gce.imagemosaic] (http-/0.0.0.0:8080-2) Failure occurred while collecting the granules: org.apache.commons.io.DirectoryWalker$CancelException: Operation Cancelled
at org.apache.commons.io.DirectoryWalker.checkIfCancelled(DirectoryWalker.java:395) [commons-io-2.1.jar:2.1]
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:368) [commons-io-2.1.jar:2.1]
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335) [commons-io-2.1.jar:2.1]
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:114) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:354) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1223) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:516) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:468) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:483) [gt-imagemosaic-13.1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:103) [gt-imagemosaic-13.1.jar:
more INFO:
MOSAIC_DATA_DIR contents:
133_2015-06-11T00.asc
133_2015-06-11T01.asc
133_2015-06-11T02.asc
133_2015-06-11T03.asc
133_2015-06-11T00.tif
133_2015-06-11T01.tif
133_2015-06-11T02.tif
indexer.properties
timeregex.properties
schema = geoimpact
preparedStatements = true
SPI = org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
jndiReferenceName = java:jboss/datasources/gisDB
indexer.properties:
AdditionalDomainAttributes = analysis_time
Schema = *the_geom:Polygon,location:String,validtime:java.util.Date,analysis_time:java.util.Date
PropertyCollectors = TimestampFileNameExtractorSPItimeregex,TimestampFileNameExtractorSPItimeregex
Timeregex.properties
regex = [0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}
Thanks for you help
Dom
