[Geoserver-users] Image Mosaicking Plugin and UNC paths
Thanks jukka,
It must have access since the UNC paths in the shp dbf work fine. I think it might be a bug.
Roger Bedell, President Sylvan Ascent Inc.
roger@anonymised.com
+34 626 855 662
-----Original Message-----
From: Rahkonen Jukka <Jukka.Rahkonen@anonymised.com>
Sent: 24 February 2009 00:58
To: geoserver-users@lists.sourceforge.net <geoserver-users@anonymised.come.net>
Subject: Re: [Geoserver-users] Image Mosaicking Plugin and UNC paths
I just wonder if this could have something in common with standard MapServer installation, that behaves so that Apache server cannot be run as a Windows service if there are network drives included in the configuration. Reason is in Windows user rights management system. Excerpt from Apache documentation:
"By default, all Apache services are registered to run as the system user (the LocalSystem account). The LocalSystem account has no privileges to your network via any Windows-secured mechanism, including the file system, named pipes, DCOM, or secure RPC. It has, however, wide privileges locally."
What account Geoserver is using if installed as Windows service?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Andrea Aime [mailto:aaime@anonymised.com]
Lähetetty: ti 24.2.2009 1:15
Vastaanottaja: Roger Bedell
Kopio: Todd Fagin; Dave Lowther; geoserver-users@lists.sourceforge.net; Nick Huber
Aihe: Re: [Geoserver-users] Image Mosaicking Plugin and UNC paths
Roger Bedell wrote:
By accident, I learned another fact about this problem. While playing
around with things, I made the paths within the Mosaic DBF-SHP use UNC
paths to the network drive, but put the DBF, SHP, Properties, PRJ file
on a local drive, and it works. So, it isn't as big a problem as I first
thought. Still, it would be nice if it gets fixed properly sometime.
Mumble, it might just be the UI checking the .shp path exists and doing
that in a way that does not allow for UNC paths.
Mind to add a fix request on jira.codehaus.org? Otherwise we're going
to forget.
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Ciao Roger,
sorry to chime in late, but I have been having close-to-zero time these days.
Let me see if I got this right, you are saying that if you place the
index shapefile on a remote machine the index stop working but if the
UNC path are inside a local shape index then everything works.
Am i right? Moreover, do you have a stacktrace for your problem (you
might have to change the logging level to geoserver devel).
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Tue, Feb 24, 2009 at 8:06 PM, Sylvan Ascent Inc.
<sylvanascent@anonymised.com> wrote:
Thanks jukka,
+34 626 855 662
To: geoserver-users@lists.sourceforge.net <geoserver-users@anonymised.comrge.net>
-Jukka Rahkonen-
to forget.
