[Geoserver-users] image pyramid - failed to create reader from file
Hello list,
I’m having trouble using the image pyramid extension.
I’ve been following this tutorial:
http://docs.geoserver.org/stable/en/user/tutorials/imagepyramid/imagepyramid.html?highlight=bluemarble
I used the blue marble tiff from the tutorial and retiled it using the instructions in the tutorial-
mkdir bmpyramid gdal_retile.py -v -r bilinear -levels 4 -ps 2048 2048
-co “TILED=YES” -co “COMPRESS=JPEG” -targetDir bmpyramid
bmreduced.tiff
I used sftp to transfer the bmpyramid directory to the server, then tried to build a store with the imagepyramid plugin.
I get this message:
Could not list layers for this store, an error occurred retrieving
them: Failed to create reader from
file:/data/bmpyramid/ and hints null
Here are some of the error messages from the log:
29 May 11:59:41 ERROR [gce.imagepyramid] - impossible to get a reader for the provided source. The error is This plugin accepts only a URL, a File or a String pointing to a directory with a structure similar to the one of gdal_retile!
29 May 11:59:41 INFO [geoserver.web] - Getting list of coverages for saved store /data/bmpyramid/
java.lang.RuntimeException: Could not list layers for this store, an error occurred retrieving them: Failed to create reader from /data/bmpyramid/ and hints null
I see that GeoServer is able to create the 0 directory and move the images inside, but no auxiliary files are created. The user tomcat owns all the directories: bmpyramid, 0, and 1-4
I get a similar error if I try to use the Image mosaicking plugin.
I’m using GeoServer 2.6.0 and the Image pyramid plugin is the same version.
Any guidance would be greatly appreciated.
Amanda Henley
Ciao Amanda,
can you give us a large portion of the logs? You may also use verbose
level for the logging.
This sounds like a permission problem but it's worth checking anyway.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Jun 1, 2015 at 1:31 PM, Henley, Amanda Clarke
<amanda.henley@anonymised.com> wrote:
Hello list,
I'm having trouble using the image pyramid extension.
I've been following this tutorial:
-co "TILED=YES" -co "COMPRESS=JPEG" -targetDir bmpyramid
bmreduced.tiff
I get this message:
gdal_retile!
hints null
I'm using GeoServer 2.6.0 and the Image pyramid plugin is the same version.
Amanda Henley
Geoserver-users mailing list
