Hello!
Where it’s possible to download the Image pyramid plugin because I don’t have this possibility in coverages/new.
Thanks
Hello!
Thanks
Try:
http://geoserver.org/display/GEOS/Stable
link Image Pyramid <http://downloads.sourceforge.net/geoserver/geoserver-1.7.3-pyramid-plugin.zip>
Cheers.
Jimmy Aumard escribió:
Hello!
Where it's possible to download the Image pyramid plugin because I don't have this possibility in coverages/new.
Thanks
Stay on top of everything new and different, both inside and around Java (TM) technology - register by April 22, and save
$200 on the JavaOne (SM) conference, June 2-5, 2009, San Francisco.
300 plus technical and hands-on sessions. Register today. Use priority code J9JMT32. http://p.sf.net/sfu/p
------------------------------------------------------------------------_______________________________________________
Geoserver-users mailing list
Thanks!
I put the jar file on WEB-INF\lib but they don’t work do you have an idea?
cheers
jim
2009/4/20 Francisco Luis López <fluis.lopez@anonymised.com>
Try:
Cheers.
Hello!
Thanks
Stay on top of everything new and different, both inside and around Java ™ technology - register by April 22, and save
Ciao Jimmy,
were you able to see any errors in the geoserver log?
Throwing the jar inside the web-inflib should suffice for its
installation. Notice that you need to stop the server first then drop
the jar then restart otherwise the plugin won't be picked up.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Mon, Apr 20, 2009 at 8:31 PM, Jimmy Aumard <jimmy.aumard@anonymised.com> wrote:
Thanks!
I put the jar file on WEB-INF\\lib but they don't work
do you have an
idea?cheers
jim
Try:
link Image Pyramid
<http://downloads.sourceforge.net/geoserver/geoserver-1.7.3-pyramid-plugin.zip>Cheers.
Hello!
have this possibility in coverages/new.Thanks
https://lists.sourceforge.net/lists/listinfo/geoserver-users------------------------------------------------------------------------------
