Hello.
I’m using Image Pyramid on Geoserver 2.7.1. I am using two image layers: one at the bottom (img2.png) and one on top with transparency (img1.png). I need to make transparent the background of img1.pg to show in these areas img2.png.
I am having problems with transparency. Sometimes the background of the top image is transparent and sometimes black.
The accompanying pictures show the problem: coloured base raster layer (img2.png ) is overlaid with a second layer (img1.png) with areas of empty background. The value of background pixels is white (#FFFFFF or RGB: 255,255,255).
In some of the tiles the background is transparent and base layer is visible with the foreground layer superimposed (img3.png), in some of the tiles the background is back and the base layer is not visible (img4.png).
Any suggestion?
Regards
Un saludo.
Pedro Briones Garcia
JGAP Sist Inform Geográfica
S.Información Geográfica / G.Sist.Inf. Geografica
Grupo Tragsa - SEPI
Calle Julián Camarillo 6 B - 28037 Madrid
Tel.: 913226489 - 88216 - Fax: 913226005
pbg@anonymised.com
www.tragsa.es
En beneficio del medio ambiente, imprime este e-mail sólo si realmente es necesario
For the benefit of the environment, print this e-mail only if you really need to
