[Geoserver-users] Image Pyramide mixes map segments
Hello,
I use Image Pyramide to create a data store. It works fine, except it mixes
some segments of the map. For example, I have tiles 1-1, 1-2, 2-1, 2-2. And
tiles 1-2 and 2-1 are displayed vice versa, like on the following figure:
<http://osgeo-org.1560.x6.nabble.com/file/n5066762/1.png&gt;
I have the following data srtucture: folders from 0 to 2 (3 levels) and
inside each folder i have tiff images. All tiffs look correct.
Does enyone have an idea why it happens?
Which property of data source Image Pyramid uses to organized segments in
order? or how Image Pyramid organizes segments order? I tried to analyze
source code by myself, but not sure what I should look at.
Thank you.
Amiala.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Image-Pyramide-mixes-map-segments-tp5066762.html
Ciao Amiala,
please, read below...
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Tue, Jul 16, 2013 at 2:10 PM, Amiala <belka91@anonymised.com> wrote:
Hello,
I guess we'll need to look at some sample data to replicate.
Would it be possible to create a small set of tiles to replicate the
issue that you could share with us?
These are questions for the developers list :slight_smile:
Thank you.
Amiala.
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
