[Geoserver-users] Image Pyramide mixes segments of the map
Hello,
I use Image Pyramide to create a data store. It works fine, except it mixes
some segments of the map. For example, I have tiles 1-1, 1-2, 2-1, 2-2. And
tiles 1-2 and 2-1 are displayed vice versa, like on the following figure:
<http://osgeo-org.1560.x6.nabble.com/file/n5066767/1.png&gt;
I have the following data srtucture: folders from 0 to 2 (3 levels) and
inside each folder i have tiff images. All tiffs look correct.
Does enyone have an idea why it happens?
Which property of data source Image Pyramid uses to organized segments in
order? or how Image Pyramid organizes segments order? I tried to analyze
source code by myself, but not sure what I should look at.
Thank you.
Amiala.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Image-Pyramide-mixes-segments-of-the-map-tp5066767.html
