[Geoserver-users] Image Pyramids and Too many open files
Dear GeoServer'ers,
Firstly I'd like to express my gratitude to the developers for such
great software. It is great to be able to access such software for
'nics.
I have a rather large tiled Image Pyramid of 80GB that I am using as a
test case for GeoServer 1.6.4a on a 32 bit Linux(Ubuntu) platform with
JDK 1.6.0.
I used GDAL to create the Image Tiles and a bit of extra mucking around
to get it to work.
I am curious why GeoServer suddenly (and inexplicably) refuses to serve
up images when I access the WMS layers from an ArcGIS 9.2 client. I get
a "Too Many files open" error, and the server shuts down. I have
allocated 2GB (half the systems real memory) to the JDK when GeoServer
starts up. I also bumped up the ulimit of files to 4096.
The Image Pyramid has the following number of files -
Level 0 - 73149
Level 1 - 19428
Level 2 - 4641
Level 3 - 1184
Level 4 - 310
Level 5 - 86
Level 6 - 26
Level 7 - 12
Level 8 - 7
Am I being a little too optimistic here and possibly expecting too much
or are there other areas I should look at before accusing GeoServer ?
FWIW here is the component of the error log -
java.io.FileNotFoundException:
/tmp/Jetty_0_0_0_0_9999__geoserver_/jsp/org/apache/jsp/WEB_002dINF/pages
/layouts/mainLayout_jsp.java (Too many open files)
        at java.io.FileOutputStream.open(Native Method)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
        at java.io.FileOutputStream.<init>(FileOutputStream.java:70)
        at
org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:140)
        at
org.apache.jasper.compiler.Compiler.compile(Compiler.java:295)
        at
org.apache.jasper.compiler.Compiler.compile(Compiler.java:276)
        at
org.apache.jasper.compiler.Compiler.compile(Compiler.java:264)
        at
org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.ja
va:563)
        at
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.ja
va:303)
        at
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
        at
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
        at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:459)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
        at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:231)
        at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:629)
        at
org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:453)
        at
org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
        at
org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
        at
org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProces
sor.doForward(MultipleDelegatingTilesRequestProcessor.java:346)
        at
sor.processTilesDefinition(MultipleDelegatingTilesRequestProcessor.java:
212)
        at
sor.processForwardConfig(MultipleDelegatingTilesRequestProcessor.java:81
        at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:
241)
        at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
        at
org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
        at
        at
        at
        at
        at
        at
        at
        at
        at
org.apache.struts.action.RequestProcessor.processForwardConfig(RequestPr
ocessor.java:398)
        at
org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(Tiles
RequestProcessor.java:318)
        at
sor.processForwardConfig(MultipleDelegatingTilesRequestProcessor.java:95
        at
241)
        at
        at
        at
        at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:1054)
        at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharac
terEncodingFilter.java:108)
        at
dler.java:1045)
        at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.jav
a:170)
        at
dler.java:1045)
        at
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at
dler.java:1045)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
        at
dler.java:1045)
        at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(Filt
erChainProxy.java:264)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterS
ecurityInterceptor.java:107)
        at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(Filte
rSecurityInterceptor.java:72)
        at
erChainProxy.java:274)
        at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTransl
ationFilter.java:110)
        at
        at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter
(AnonymousProcessingFilter.java:125)
        at
        at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(Reme
mberMeProcessingFilter.java:142)
        at
        at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilt
er(SecurityContextHolderAwareRequestFilter.java:81)
        at
        at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessin
gFilter.java:217)
        at
        at
org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
        at
        at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(H
ttpSessionContextIntegrationFilter.java:229)
        at
        at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:1
48)
        at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java
:98)
        at
dler.java:1045)
        at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:358)
        at
        at
        at
        at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandler
Collection.java:149)
        at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.jav
a:123)
        at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
        at org.mortbay.jetty.Server.handle(Server.java:303)
        at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:452)
        at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConne
ction.java:721)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:509)
        at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:209)
        at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:349)
        at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:
320)
        at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.ja
va:475)
TIA
Shaun Kolomeitz,
Senior Technical Officer
Business and Asset Services
Queensland Parks and Wildlife Division
Environmental Protection Agency
Think B4U Print
1 ream of paper = 6% of a tree and 5.4kg CO2 in the atmosphere
3 sheets of A4 paper = 1 litre of water
_________________________
Disclaimer
WARNING: This e-mail (including any attachments) has originated from a Queensland Government department and may contain information that is confidential, private, or covered by legal professional privilege, and may be protected by copyright.
You may use this e-mail only if you are the person(s) it was intended to be sent to and if you use it in an authorised way. No one is allowed to use, review, alter, transmit, disclose, distribute, print or copy this e-mail without appropriate authority. If you have received this e-mail in error, please inform the sender immediately by phone or e-mail and delete this e-mail, including any copies, from your computer system network and destroy any hardcopies.
Unless otherwise stated, this e-mail represents the views of the sender and not the views of the Environmental Protection Agency.
Although this e-mail has been checked for the presence of computer viruses, the Environmental Protection Agency provides no warranty that all viruses have been detected and cleaned. Any use of this e-mail could harm your computer system. It is your responsibility to ensure that this e-mail does not contain and is not affected by computer viruses, defects or interference by third parties or replication problems (including incompatibility with your computer system).
E-mails sent to and from the Environmental Protection Agency will be electronically stored, managed and may be audited, in accordance with the law and Queensland Government Information Standards (IS31, IS38, IS40, IS41 and IS42) to the extent they are consistent with the law.
___________________________
!DEPTSTAMP1!
Shaun Kolomeitz ha scritto:
Dear GeoServer'ers,
'nics.
JDK 1.6.0.
to get it to work.
Level 0 - 73149
Level 1 - 19428
Level 2 - 4641
Level 3 - 1184
Level 4 - 310
Level 5 - 86
Level 6 - 26
Level 7 - 12
Level 8 - 7
Hum, it may be it's the pyramid plugin itself that is keeping all
those file open as an attempt to improve performance, since opening
a reader against a geotiff file can take its time.
If you manage to spot again that error and are under a unix system,
can you use one of the techniques described here:
http://www.cyberciti.biz/faq/howto-linux-get-list-of-open-files/
to get a list of the files that GeoServer is keeping open?
