[Geoserver-users] ImageIO-ext help?
I’m trying to read some mrsid images, and thought I’d use ImageIO-ext
The instructions seem simple enough, but no luck. Just to warn you, I’ve rarely used any Java apps, so I know nothing! Even worse, I’m using Vista.
First question:
"To use these libs, be sure your JAVA_HOME environment variable is properly configured. "
What exactly does this mean? I assume this means to setup a Windows Environment variable like this, which I did in the Advanced System Settings, then got this in a command window with SET:
JAVA_HOME=C:\Program Files\Java\jdk1.6.0_10
"On Windows: copy the downloaded DLLs to your $JAVA_HOME/bin
  • Extract gdal_data.zip somewhere on your machine (as an instance C:/gdal_data).
  • Set a GDAL_DATA environment variable linking to the directory where you have stored data contained in gdal_data.zip, making sure the web container running GeoServer will pick it up.
Ok, did this
have: GDAL_DATA=c:\gdal_data
restarted GS, didn’t work. Still just getting the usual 5 coverage plugins. What am I doing wrong?
ImageMosaic / 1.0 Image mosaicking plugin
GeoTIFF / 1.1 Tagged Image File Format with Geographic information
WorldImage / 1.0 A raster file accompanied by a spatial data file
ArcGrid / 1.0 Arc Grid Coverage Format
Gtopo30 / 1.0 Gtopo30 Coverage Format
Roger
Dedar Roger,
please read below..
On Thu, Oct 23, 2008 at 5:09 AM, Sylvan Ascent Inc.
<sylvanascent@anonymised.com> wrote:
I'm trying to read some mrsid images, and thought I'd use ImageIO-ext
That's the only way you can achieve that.
The instructions seem simple enough, but no luck. Just to warn you, I've
rarely used any Java apps, so I know nothing! Even worse, I'm using Vista.
I love Vista! (Ok, that was a joke :slight_smile: ).
First question:
configured. "
That is not entirely correct. You need to set the env var system wise,
otherwise it will be not picked up all the time.
I would also add the bin directory to the PETH env var, which means
that in Advanced System Settings you need to:
1> create and env var for JAVA_HOME as you did
2> add %Java_HOME%\bin to the PATH var (this is to have Java get the
dll from there)
You can do it bi the concatenation char which on windows is semicolo (
; ). Something like
current_path;%JAVA_HOME%\bin
C:/gdal_data).
Ok, did this
Same as above, you need to do that from the ASS.
restarted GS, didn't work. Still just getting the usual 5 coverage plugins.
I think you are using the standard geoserver. As of now (gs 1.7.0)
support for gdal through imageio-ext is still an extension since we
(imageio-ext) were waiting on gdal 1.5.3 to be released (which just
happened :slight_smile: ) to start with our release train. This means that soon
we will have an imageio-ext official release and that will be the
trigger to get gdal support shipped by default with GeoServer.
Now what does all this mean to you? It means that you might be using a
standard version of GeoServer which does not contains the Java
counterparts for the dll you installed, hence no gdal based plugin for
you!
Tell me what version of GeoServer you are using and I'll bundle up a
GeoServer for you.
Simone.
Roger
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
you!
GeoServer for you.
No need to, the extensions package contains also the needed jars,
maybe Sylvan forgot to copy them into WEB-INF/lib?
Andrea Aime
OpenGeo - http://opengeo.org
you!
GeoServer for you.
Ops, yeah, I aleays forgot about the extension package, my bad.
Btw, if you send us the server log after startup, we will be able to
tell you if you have installed them correctly or not.
Simone.
Andrea Aime
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Sylvan Ascent Inc. ha scritto:
The instructions do not mention copying any jars to web-inf/lib. Also, there are no Jars in the windows-gdal-mrsid_1.7.0_onwards.zip . Where do I find such these?
Sorry, which instructions where you following?
The drill is:
* download the GDAL extension here: http://geoserver.org/display/GEOS/Latest
* unpack and follow instructions
* the instructions will lead you to a page that contains the pointers
   to a binary download for your platform that completes the installation
I guess you went straight to step 3?
Andrea Aime
