Is this possible? I have a mosaic that I have built utilizing a modified version of the MosaicIndexBuilder utility that basically ignores the resolution checking, color model checking, etc... The images are all in the same projection, but their size and pixel densities will vary. When I generated the shapefile, I was unsure of what values to put in the Levels property because of the non uniformity. Resizing the images is not completely out of the question, but it would be quite a task as these images are in both TIF and PNG format; vary in size from 1MB to 50 MB; vary in color model; and theres roughly 180K of them. So, is it feasible to define a shapefile and have Geoserver morph the image accordingly by reading the image's world file?
__________________________________
Jeremy Nix
Senior Application Developer
Southwest Financial Services, Ltd.
(513) 621-6699
