[Geoserver-users] ImageMosaic drop bbox table
Hello,
I'm working with ImageMosaics layers with multiple timesteps.
I knew that when creating such an ImageMosaics layer, a specific table is
always created in the PostGIS database to hold on the bounding boxes of each
timestep.
But I just realized that this table is not dropped when I remove the
ImageMosaic layer from GeoServer.
Is this a normal behaviour ?
Is there a way to force GeoServer to remove the table it created when
dropping the layer ?
Thanks for you consideration,
Cyril
View this message in context: http://osgeo-org.1560.x6.nabble.com/ImageMosaic-drop-bbox-table-tp5271113.html
On Fri, Jun 10, 2016 at 4:53 PM, CGA <cgallay.artal@anonymised.com> wrote:
Hello,
each
timestep.
Hi Cyril,
right now removing the geoserver store from the GUI won't also remove the
database tables.
You can use the REST interface to perform a coverageStore delete using the
purge parameter. (=metadata).
http://docs.geoserver
.org/stable/en/user/rest/api/coveragestores.html#rest-api-coveragestores-
purge
Please, let me know if that satisfies your needs.
Daniele
Cyril
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Hello,
each
timestep.
It is, nothing In the GeoServer UI drops the data or metadata when a layer
is dropped. Once upon a time we just did not have the tools.
Now we have some of the tools, but we lack the time to implement such an
option
in the UI (deletion is generic, and can cascade from containers to
contained objects, so should be the deletion of metadata and data, generic,
not available only for a specific format).
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Daniele,
I am already working with the REST API with OWSLib.
I tried using purge='all' and recurse=True and here is the output I get in
GeoServer logs :
The thing is that the table is apparently removed so I don't see why
GeoServer is complaining.
But the purge = 'all' does no do exactely as I expected : it removed all the
granules and the table, but the directory that was holding the granules
still exists after the purge and contains datastore.properties,
indexer.properties, timeregex.properties and sample_image. I was expecting
this folder and all its content to disappear.
Cyril
View this message in context: http://osgeo-org.1560.x6.nabble.com/ImageMosaic-drop-bbox-table-tp5271113p5271810.html
