[Geoserver-users] ImageMosaic force PALETTE_INDEX
Hello all,
We recently upgraded from GeoServer 2.3.5 to version 2.5.0 and are experiencing some issues with our ImageMosaic layers. Previously, the data was exposed as PALETTE_INDEX values which allowed us to style the data on the fly using custom SLDs. After upgrading, however, GeoServer identifies this data as RGBA which prevents our custom styling. The coverageDimension is defined as a PALETTE_INDEX, but GeoServer appears to ignore this. Is there any way to force the PALETTE_INDEX on the existing data or do we need to re-encode the rasters somehow?
The rasters are stored as single band 8-bit png files. Here is a snippet from the gdalinfo:
Coordinate System is `’
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 2859.0)
Upper Right ( 4944.0, 0.0)
Lower Right ( 4944.0, 2859.0)
Center ( 2472.0, 1429.5)
Band 1 Block=4944x1 Type=Byte, ColorInterp=Palette
NoData Value=0
Color Table (RGB with 256 entries)
0: 0,0,0,0
1: 0,240,240,255
2: 0,144,144,255
Any help would be appreciated.
Kevin M. Weiss
Software Engineer
HARRIS IT Services
