[Geoserver-users] ImageMosaic import getotiff with no SRS?
Hello,
is it possible to import a geotiff file with no declared coordinate system into ImageMosaic layer? I can read such a file directly by geotiff reader, but ImageMosaic plugin throws an error:
Caused by: org.opengis.referencing.operation.TransformException: Can't transform envelope.
  at org.geotools.referencing.CRS.transform(CRS.java:1242)
  at org.geoserver.data.util.CoverageStoreUtils.getWGS84LonLatEnvelope(CoverageStoreUtils.java:306)
  at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:917)
  at org.geoserver.catalog.CatalogBuilder.buildCoverage(CatalogBuilder.java:855)
  at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:346)
  ... 109 more
Caused by: org.opengis.referencing.operation.OperationNotFoundException: No transformation available from system "EngineeringCRS[Wildcard 2D cartesian plane in metric unit]" to "GeographicCRS[WGS84(DD)]".
  at org.geotools.referencing.operation.DefaultCoordinateOperationFactory.createOperation(DefaultCoordinateOperationFactory.java:389)
  at org.geotools.referencing.operation.BufferedCoordinateOperationFactory.createOperation(BufferedCoordinateOperationFactory.java:256)
  at org.geotools.referencing.CRS.transform(CRS.java:1240)
Example files are available from:
http://geo.nebula.grid.icm.edu.pl/tmp/wrf_d02_T2_201504040600_001.tiff
http://geo.nebula.grid.icm.edu.pl/tmp/indexer.xml
Regards
Maciej
support for non referenced files has been growing over time, but I’m not sure if it has reached the mosaic
code yet… the exception is strange though, as the wildcard CRS seems to be in use (EPSG:404000).
Out of curiosity, which version of GeoServer are you using?
On Thu, Jul 2, 2015 at 1:21 PM, Maciej Filocha <m.filocha@anonymised.com> wrote:
Hello,
Caused by: org.opengis.referencing.operation.TransformException: Can’t
transform envelope.
at
at
at
at
… 109 more
No transformation available from system “EngineeringCRS[Wildcard 2D
cartesian plane in metric unit]” to “GeographicCRS[WGS84(DD)]”.
at
at
Regards
Maciej
Don’t Limit Your Business. Reach for the Cloud.
GigeNET’s Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ok,
checked locally, indeed it does not work, it’s happening because the “lack of a crs” is
turned into a PRJ file containig:
LOCAL_CS[“Wildcard 2D cartesian plane in metric unit”, LOCAL_DATUM[“Unknown”, 0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“404000”]]
and then parsed back from the prj file. It’s just that as we parse ist, the notion of it being a wildcard one is lost, since we cannot express
that notion in WKT.
Can you open a ticket in Jira with those details?
On Thu, Jul 2, 2015 at 5:58 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hello,
transform envelope.
at
at
at
at
… 109 more
at
at
Regards
Maciej
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
W dniu 2015-07-02 o 18:10, Andrea Aime pisze:
Ticket opened:
https://osgeo-org.atlassian.net/browse/GEOS-7097
Regards
Maciej
