I have a number of raster tile data (bmp + bmpw) which I would like to use as my base layer. The tiles follows the
So I think that I have to user the ImageMosaic plugin (right?)
I am trying to setup/compile the ImageMosaic by issuing te following commands:
svn checkout http://svn.geotools.org/geotools/trunk/spike/coveragetools
then in coveragetools dir i issue :
mvn install
and i get
[ERROR] BUILD ERROR
[INFO] Cannot execute mojo: resources. It requires a project with an existing pom.xml, but the build is not using one.
[INFO] Total time: 1 second
[INFO] Finished at: Tue Mar 27 14:37:43 EEST 2007
[INFO] Final Memory: 3M/5M
Can someone guide me how I will comile the ImageMosaic ?
Thx
×ñçóéìïðïéåßôå Yahoo!
ÂáñåèÞêáôå ôá åíï÷ëçôéêÜ ìçíý ìáôá (spam); Ôï Yahoo! Mail äéáèÝôåé ôçí êáëýôåñç äõíáôÞ ðñïóôáóßá êáôÜ ôùí åíï÷ëçôéêþí ìçíõìÜôùí
http://login.yahoo.com/config/mail?.intl=gr
Solved!
Just folowed the intstructions for the Image Pyramid
http://docs.codehaus.org/display/GEOSDOC/Image+Pyramid
plus setting the Eclipse
Got to: Windows -> Preferences
In the wondow that pops up click on Java -> Build Path -> Classpath Variables
On the Classpath Variables panel, select New
Define a new variables called M2_REPO and set it to your local maven repository
PS: it would be nice if you will update also the ImageMosaic page
http://docs.codehaus.org/display/GEOSDOC/Using+the+ImageMosaic+plugin
thx
gp
gpio Oxxce gp_io_07@anonymised.com Ýãñáøå:
mvn install
and i get
[ERROR] BUILD ERROR
Thx
http://login.yahoo.com/config/mail?.intl=gr -------------------------------------------------------------------------
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys-and earn cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV_______________________________________________
Geoserver-users mailing list
