Well, decided to do some testing and installed Geoserver under server 2008 and used the war file. Have gdal up and running fine and can look at an individual .jp2 file with no issues.
I run into problems though when trying to use the image mosaic plugin as I always get that it is an invalid URL no matter what I try for the file location.
Using “file:data/doqq” and even the full path from the root of C: drive.
2009-06-25 16:23:24,610 ERROR [imagemosaic.ImageMosaicUtils] - Unable to build mosaic
java.lang.NullPointerException
at com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReader.setInput(J2KImageReader.java:317)
at javax.imageio.ImageReader.reset(Unknown Source)
at com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReader.reset(J2KImageReader.java:542)
at org.geotools.gce.imagemosaic.IndexBuilder$MosaicDirectoryWalker.handleFile(IndexBuilder.java:504)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:367)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335)
at org.geotools.gce.imagemosaic.IndexBuilder$MosaicDirectoryWalker.(IndexBuilder.java:702)
at org.geotools.gce.imagemosaic.IndexBuilder.run(IndexBuilder.java:1009)
at org.geotools.gce.imagemosaic.ImageMosaicUtils.createMosaic(ImageMosaicUtils.java:209)
at org.geotools.gce.imagemosaic.ImageMosaicUtils.checkSource(ImageMosaicUtils.java:306)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.accepts(ImageMosaicFormat.java:197)
at org.vfny.geoserver.form.data.CoverageStoresEditorForm.validate(CoverageStoresEditorForm.java:285)
at org.apache.struts.action.RequestProcessor.processValidate(RequestProcessor.java:950)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:207)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:859)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:574)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2018)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
