[Geoserver-users] ImageMosaic plugin update
I managed to get the ImageMosaic plugin from the WCS branch to work.
Attached is an image with satellite imagery. Thanks to the mosaicking
plugin, these images are configured as one coverage. For me, the
advantages of this are cleaner catalog and not so many subdirectories
in my data_dir.
Notice the blend between overlapping images--the alpha channel is
respected and any uderlying imagery is visible.
Also, the vector layer on top is reprojected.
Thanks for looking,
Alex
I have only one question: how you did it ?
Today I've downloaded and built latest GeoTools and Geoserver WCS branch, was able to add a coverage store, but not a coverage:
8127049 [INFO] org.vfny.geoserver.servlets.AbstractService - Service handled
  8194669 [CONFIG] org.geotools.factory.FactoryRegistry - Factory implementations for category GridCoverageFactory:
   org.geotools.coverage.grid.GridCoverageFactory
Sep 11, 2006 9:05:16 PM org.apache.struts.action.RequestProcessor processException
WARNING: Unhandled Exception thrown: class java.lang.NullPointerException
21:05:16.096 WARN!! Exception for /geoserver/config/data/coverageNewSubmit.do
         at org.vfny.geoserver.action.data.DataCoveragesNewAction.execute(DataCoveragesNewAction.java:139)
         at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:102)
         at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
         at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
         at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
         at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
    Luca Morandini
www.lucamorandini.it
I suspect that it mught be a missing .properties file for your
ImageMosaic coverage. Check the sample ImageMosaic coverage
(mosaic.properties file) for example:
#Thu Aug 17 14:00:58 CEST 2006
Name=mosaic
Levels=0.057934032977228433,0.04039598061277999
LevelsNum=1
Envelope2D=6.34617490847439,36.4917718219401 20.8296831527815,46.5907669751351
NumFiles=25
Here "Levels" is the cell size in x and y direction, "Envelope2D" is
the bounding box for the coverage, and "NumFiles" is the number of
rasters (tiles) in your Coverage.
Alex
processException
         at
         at
         at
         at
         at
         at
    Luca Morandini
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
The properties file is missing indeed, but setting up one didn't work.
Actually, I've put the following in a file named "tci250.properties" (tci250 being the name of the coveragestore):
Name=tci250
Levels=70000,48000
LevelsNum=1
Envelope2D=162000,4546000 459000,4755000
NumFiles=14
Moreover, shouldn't the plugin write it by itself ?
    Luca Morandini
What is the error this time? The plugin is not (yet) generating the
properties file.
Alex
Name=tci250
Levels=70000,48000
LevelsNum=1
NumFiles=14
    Luca Morandini
Hi Alexander
How do you generate shp index file, using gdalindex?
What means param LevelsNum in .properties file if Levels is x,y resolutions?
properties file.
Alex
Name=tci250
Levels=70000,48000
LevelsNum=1
NumFiles=14
    Luca Morandini
easier
Geronimo
easier
View this message in context: http://www.nabble.com/ImageMosaic-plugin-update-tf2177970.html#a6259659
Sent from the GeoServer - User forum at Nabble.com.
The same:
942815 [CONFIG] org.geotools.factory.FactoryRegistry - Factory implementations for category GridCoverageFactory:
Sep 12, 2006 8:43:11 AM org.apache.struts.action.RequestProcessor processException
08:43:11.891 WARN!! Exception for /geoserver/config/data/coverageNewSubmit.do
    Luca Morandini
Here is a relevant snippet from a previous post:
For example, the following command line will create an index shapefile
for all of your geotiffs:
gdaltindex -tileindex location test *.tif
Here it creates a test.shp with a field named "location" (the exact
name is needed by the Imagemosaic plugin I believe), for all images
with .tif extension in the current directory.
"Levels" in the .properties file represents the cell size in the x and
y directions (in the units of your projection). Maybe a better name
for that parameter would be "CellSize" or something... LevelsNum is
probably picking the appropriate "Levels" index, I am not too sure on
that one.
Alex
On 9/11/06, Alexey Leybman <alexey.leybman@anonymised.com> wrote:
Hi Alexander
> properties file.
> Alex
>> Name=tci250
>> Levels=70000,48000
>> LevelsNum=1
>> NumFiles=14
>> Regards,
>> Luca Morandini
>> easier
>> Geronimo
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> easier
Hi guys, hi lists,
I just committed a couple of tools for coverage preparation and
processing to the GeoTools subversion repository under
spike/coveragetools. They are command line tools, with command line
parsing capabilities built with commons-cli package.
These tools are:
1> mosaicindexbuilder tool which can be used to generate the shapefile
index and the other appropriate files for the image mosaic plugin.
2>pyramidbuilder that can be used to build a pyraimd starting from a
mosaic (the pyramid plugin will be released next week).
3>Coveragetiler that can be used to tile a very large coverage into a
mosaic of geotiffs (new formats will come soon).
Just to let you know, this week me and Alex Petkov should start with
writing some documentantion for the various coverage plugins,
including the image mosaic one.
Ciao,
   Simone.
that one.
Alex
> Hi Alexander
> > properties file.
> > Alex
> >> Name=tci250
> >> Levels=70000,48000
> >> LevelsNum=1
> >> NumFiles=14
> >> Regards,
> >> Luca Morandini
> >> easier
> >> Geronimo
> > easier
Eng. Simone Giannecchini
President /CEO GeoSolutions
Great tools. Thank you!
But i have a suggestion. Sometimes my image mosaic files are not all in one
directory but in directory tree, like:
DOF1
|-DOF11: raster here
|-DOF12: raster here
|-DOF13: raster here
| |-DOF131: raster here
| |-DOF132: raster here
|-DOF1n: raster here
So it would be great if MosaicIndexBuilder would recurse through all the
directories.
View this message in context: http://www.nabble.com/ImageMosaic-plugin-update-tf2177970.html#a6360176
It is a very good idea, indeed. I am going to investigate a bit to
understand how it would impact the imagemosaic and the imagepyramid
plugin.
Btw, how it going with your mosaic?
SImone.
DOF1
|-DOF11: raster here
|-DOF12: raster here
|-DOF13: raster here
|-DOF1n: raster here
directories.
If you feel like you can even go ahead and implement such capabilty
yourself. Afterwards we can commit it to the codebase.
Simone.
DOF1
|-DOF11: raster here
|-DOF12: raster here
|-DOF13: raster here
|-DOF1n: raster here
directories.
really well ( if i exclude the java crashes).
The mosaic operations are really fast and i have no trouble displaying large
amount of data in mapbuilder.
Example:
I have one mosaic that contains 10 TIFs, each 80MB.
I setup the bounding box so that all rasters fall in.
Then i execute the WMS query that returns png 500x250.
This usually takes under second or two.
Like i said, very fast.
I have a question. Are this image transformations (scale, clipping...)
executed only on CPU?
Anyway. I wrote a simple SDL that hides mosaic until i get close enough. i
probably won't have to use that anymore since you introduced pyramids. i'll
be testing that next week when you release the pyramid plugin.
bye.
View this message in context: http://www.nabble.com/ImageMosaic-plugin-update-tf2177970.html#a6362865
if you say i can then i will :slight_smile:
Simone.
one
DOF1
|-DOF11: raster here
|-DOF12: raster here
|-DOF13: raster here
|-DOF1n: raster here
directories.
easier
Geronimo
easier
View this message in context: http://www.nabble.com/ImageMosaic-plugin-update-tf2177970.html#a6362948
Answers and advices inlined...
Example:
Mmmmh, let me ask a few questions in order to speed up even more:
1>Are your tiff tiled?
2>Did you embed overviews into them?
I do not clearly see the point of this question (please explain :slight_smile: ).
If i can I would suggest you doing as follows:
1>using the coveragetiler, split each raster in a series of tiles
let's say of size 1 mb each
2>use the pyramid plugin once it is released (it could even be
tomorrow, anyway next week is reasable enough I hope). Use the
pyramidbuilder tool to build the pyramid for you, level by level.
Simone.
bye.
Well, I encourage you to do so. This is the essence of the open
source. I am putting there tools that are not yet completely finished
because I hope that someone else will grab them, use them and
hopefully contribute.
No one can do it all by himself but if we share the load the overall
quality and capabilities will increase quickly.
Play with the tools, modify them, let me review the changes once you
feel comfortable with them in order to commit them. You might even ask
for commit access to the geotools codebase just to enhance the tools.
Simone.
> Simone.
>> one
>> DOF1
>> |-DOF11: raster here
>> |-DOF12: raster here
>> |-DOF13: raster here
>> |-DOF1n: raster here
>> directories.
>> easier
>> Geronimo
> easier
1. no the TIF is one big picture
2. i don't understand. How do i embed the overview?
Forget about it :slight_smile: It was just something stupid.
i
i'll
I can not tile tifs. Their original size must remain unchanged.
View this message in context: http://www.nabble.com/ImageMosaic-plugin-update-tf2177970.html#a6363127
For the moment, until they fix an annoying bug in JAI so that i canj
commit other tools, use the gdaladdo tool from the gdal utilities. You
can download them from maptool.org. This utility is pretty
straightforward. You should write something like
gdaladdo -r average 2 4 8 16 32 64 -co "TILED=YES" sourcefile
and it will embedde din the same tiff overviews with resolution
decreasing bya power two at each level. 6 levels should be enough.
The geotools plugin I wrote for tiff will automagically recognize the
presence of the overviews and select the right one.
Once you do this you will see REAL speed, believe me.
>> i
>> i'll
The original size will not change. The difference will be that instead
of having a single image of 80 mb (which is not THAT big btw) you will
have let's say 80 images of 1 mb and the result will be much faster.
However if each image is only 80 mb using gdaladdo with the parameters
I gave you above is more than enough. Try that out with the same
parameters on each image, rerun the mosaicindexbuilder and then tell
me if things are faster or not, if not you made a mistake somewhere
Simone.
thanks!
i will try: gdaladdo -r average 2 4 8 16 32 64 -co "TILED=YES" sourcefile
View this message in context: http://www.nabble.com/ImageMosaic-plugin-update-tf2177970.html#a6363406
i made a little change to MosaicIndexBuilder
Tell me if the results are correct:
my mosaic files are stored in directories like this:
Dof_77: 4 rasters
|-dof00: 1 raster
|-dof01: 1 raster
|-dof02: 1 raster
After runing the MosaicIndexBuilder i got this result:
18.9.2006 15:57:39 it.geosolutions.utils.imagemosaic.MosaicIndexBuilder
getNotification
INFO: Progress is at 0.0
attached message is: Now indexing file C272161.tif
getNotification
INFO: Progress is at 14.142857142857142
attached message is: Done with file D:\Dof_77\C272161.tif
getNotification
INFO: Progress is at 14.285714285714286
attached message is: Now indexing file C272261.tif
getNotification
INFO: Progress is at 28.285714285714285
attached message is: Done with file D:\Dof_77\C272261.tif
getNotification
INFO: Progress is at 28.571428571428573
attached message is: Now indexing file C272361.tif
getNotification
INFO: Progress is at 42.42857142857143
attached message is: Done with file D:\Dof_77\C272361.tif
getNotification
INFO: Progress is at 42.857142857142854
attached message is: Now indexing file C272461.tif
18.9.2006 15:57:40 it.geosolutions.utils.imagemosaic.MosaicIndexBuilder
getNotification
INFO: Progress is at 56.57142857142857
attached message is: Done with file D:\Dof_77\C272461.tif
getNotification
INFO: Progress is at 57.142857142857146
attached message is: Now indexing file dof00\eC272161.tif
getNotification
INFO: Progress is at 70.71428571428571
attached message is: Done with file D:\Dof_77\dof00\eC272161.tif
getNotification
INFO: Progress is at 71.42857142857143
attached message is: Now indexing file dof01\C_272161.tif
getNotification
INFO: Progress is at 84.85714285714286
attached message is: Done with file D:\Dof_77\dof01\C_272161.tif
getNotification
INFO: Progress is at 85.71428571428571
attached message is: Now indexing file dof02\qqC272261.tif
getNotification
INFO: Progress is at 99.0
attached message is: Done with file D:\Dof_77\dof02\qqC272261.tif
getNotification
INFO: Progress is at 99.9
attached message is: Creating final properties file
getNotification
INFO: Progress is at 100.0
attached message is: Done!!!
the dbf file looks like this:
location
C272161.tif
C272261.tif
C272361.tif
C272461.tif
dof00\eC272161.tif
dof01\C_272161.tif
dof02\qqC272261.tif
properties like this:
#Mon Sep 18 15:57:40 CEST 2006
Name=index
Levels=0.5,0.5
LevelsNum=1
Envelope2D=410000.0,5151000.0 419000.0,5154000.0
NumFiles=7
then i loaded the data into geoserver and it works/displays perfectly
View this message in context: http://www.nabble.com/ImageMosaic-plugin-update-tf2177970.html#a6364452
