[Geoserver-users] ImageMosaic problem when updating the store
Dear list,
I discovered a strange behavior using the ImageMosaic Plugin. I could successfully create the imagemosaic stores using the REST interface. But when extending the store with new data using the external.imagemosaic function, some mosaic stores were not updated.
I could identify some difference in the data: If I want to use data that are converted before with the gdal_translate -co NBITS=1 command, the geoserver throws an error: WARN [gce.imagemosaic] - Failure occurred while collecting the granules. See error message below. It works fine when I do not convert the data! The imagemosaic store creation works fine for both. Just updating is not possible when data are converted before.
The relevant gdalinfo differences are listed here (first file the not converted data, second file the NBITS=1 converted data):
< Band 1 Block=17393x1 Type=Byte, ColorInterp=Gray
Band 1 Block=17393x3 Type=Byte, ColorInterp=Palette
32a34,38
Image Structure Metadata:
NBITS=1
Color Table (RGB with 2 entries)
0: 0,0,0,255
1: 255,255,255,255
Is this a known problem or can you provide any quick solution for that?
Jonas
26 Apr 18:15:43 WARN [gce.imagemosaic] - Failure occurred while collecting the granules
org.apache.commons.io.DirectoryWalker$CancelException: Operation Cancelled
at org.apache.commons.io.DirectoryWalker.checkIfCancelled(DirectoryWalker.java:395)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:368)
at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:114)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196)
at org.geotools.gce.imagemosaic.ImageMosaicReader$HarvestedResource.harvestCalculation(ImageMosaicReader.java:405)
at org.geotools.gce.imagemosaic.ImageMosaicReader$HarvestedResource.access$100(ImageMosaicReader.java:187)
at org.geotools.gce.imagemosaic.ImageMosaicReader$HarvestedResource$1.harvest(ImageMosaicReader.java:202)
at org.geotools.gce.imagemosaic.ImageMosaicReader.harvest(ImageMosaicReader.java:1250)
at org.geoserver.catalog.CoverageDimensionCustomizerReader$CoverageDimensionCustomizerStructuredReader.harvest(CoverageDimensionCustomizerReader.java:128)
at org.geoserver.catalog.rest.CoverageStoreFileResource.handlePost(CoverageStoreFileResource.java:90)
at org.restlet.Finder.handle(Finder.java:296)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
Dear Jonas,
I’m not sure to have fully understood your use case.
However, please note that ImageMosaic doesn’t allow to have granules with different sampleModel/colorModel within the same mosaic.
Therefore:
A) - If you are creating an ImageMosaic on a Gray dataset and then you are afterwards harvesting 1-bit paletted granules into the same mosaic, that update won’t work (by design).
B) - If you are creating an ImageMosaic on a paletted 1-bit dataset and then you are afterwards harvesting Gray Byte granules into the same mosaic, that update won’t work (by design).
C) - If you are creating an ImageMosaic on a paletted 1-bit dataset and then you are afterwards harvesting paletted 1-bit granules into the same mosaic, it should work.
D) - If you are creating an ImageMosaic on a gray dataset and then you are afterwards harvesting gray granules into the same mosaic, it should work.
If your case is one of A or B, then that it’s the expected behaviour.
If your case is one of C or D and it doesn’t work, then we should investigate on this. In that case you could open a JIRA with sample data to replicate the issue.
Please, let us know.
Hope this helps.
Daniele
On Sun, Apr 26, 2015 at 7:13 PM, Jonas Eberle <jonas.eberle@anonymised.com> wrote:
Dear list,
32a34,38
NBITS=1
0: 0,0,0,255
1: 255,255,255,255
Jonas
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Daniele,
thanks for your response. Unfortunately C is the case. It works fine on gray datasets. I will open an issue with a sample dataset.
Jonas
----- Am 27. Apr 2015 um 12:17 schrieb Daniele Romagnoli daniele.romagnoli@anonymised.com:
Dear Jonas,
Therefore:
Hope this helps.
Daniele
Dear list,
32a34,38
NBITS=1
0: 0,0,0,255
1: 255,255,255,255
Jonas
Hi Daniele,
I created an account (username jeberle) on xircles.codehaus.org as stated on the GeoServer JIRA site and logged in afterwards on https://jira.codehaus.org/browse/GEOS.
I see the button “Create issue” on the top. But I cannot select GeoServer or GEOS as a project for the issue. Any hint or do I need further permissions?
Jonas
----- Am 27. Apr 2015 um 12:55 schrieb jonas eberle jonas.eberle@anonymised.com:
Hi Daniele,
Jonas
Dear Jonas,
Therefore:
Hope this helps.
Daniele
Dear list,
32a34,38
NBITS=1
0: 0,0,0,255
1: 255,255,255,255
Jonas
Geoserver-users@anonymised.comeforge.net
On Mon, Apr 27, 2015 at 1:39 PM, Jonas Eberle <jonas.eberle@anonymised.com> wrote:
Hi Daniele,
The jira server has been moved to
https://osgeo-org.atlassian.net/projects/GEOS since Codehaus is shutting
down.
Did you follow a link in the official documentation that got you to
jira.codehaus.org?
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
The jira server has been moved to https://osgeo-org.atlassian.net/projects/GEOS
since Codehaus is shutting down.
jira.codehaus.org ?
I found the link in the Readme ("Bugs" section) of the GitHub page:
https://github.com/geoserver/geoserver
Jonas
On Mon, Apr 27, 2015 at 2:11 PM, Jonas Eberle <jonas.eberle@anonymised.com> wrote:
Ah, thanks for that, fixed it now
Ing. Andrea Aime
@geowolf
Technical Lead
