If that TUR_us-florida016040_EOMAP_20140210T155619_LSAT8_m0030_32bit_cut.tif allows to create an imageMosaic which raises that issue, you could create a JIRA and attach both the sld, as well as that file so we can replicate the problem, locally.
(in case more files are needed to replicate the issue, you could add a zip files with them).
Hope this helps.
Daniele
On Thu, Feb 12, 2015 at 10:38 AM, Sabine Ohlendorf <sabine.ohlendorf@anonymised.com> wrote:
Hi Daniele,
Thank you for your answer!
I tried to send you a sample image as email attachment but it failed. How can I provide you the data?
Here is the coverage.xml and the output of gdalinfo:
CoverageInfoImpl--2eeda304:14ae451008d:-7ec6
florida
florida
NamespaceInfoImpl--33ad4a0f:13bb2c9158c:-7fff
florida
Generated from ImageMosaic
WCS
ImageMosaic
florida
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]]
EPSG:4326
-82.0241060990124
-80.474928725694
28.2391995705372
29.372215031235
EPSG:4326
-82.0241060990124
-80.474928725694
28.2391995705372
29.372215031235
GEOGCS["WGS84(DD)",
DATUM["WGS84",
SPHEROID["WGS84", 6378137.0, 298.257223563]],
PRIMEM["Greenwich", 0.0],
AXIS["Geodetic latitude", NORTH]]
REPROJECT_TO_DECLARED
true
true
LIST
ISO8601
false
false
florida_florida
CoverageStoreInfoImpl--2eeda304:14ae451008d:-7ec9
ImageMosaic
0 0
5286 3865
2.930717694510686E-4
-2.930717694510686E-4
0.0
0.0
-82.02395956312768
29.372068495350277
EPSG:4326
GEOTIFF
GIF
PNG
JPEG
TIFF
bilinear
bicubic
nearest neighbour
GRAY_INDEX
GridSampleDimension[-Infinity,Infinity]
-inf
inf
REAL_32BITS
FootprintBehavior
None
MergeBehavior
FLAT
AllowMultithreading
false
Filter
MaxAllowedTiles
-1
SORTING
OutputTransparentColor
InputTransparentColor
SUGGESTED_TILE_SIZE
512,512
Accurate resolution computation
false
BackgroundValues
USE_JAI_IMAGEREAD
true
florida
GDALINFO:
Driver: GTiff/GeoTIFF
Files: TUR_us-florida016040_EOMAP_20140210T155619_LSAT8_m0030_32bit_cut.tif
Size is 5286, 3866
Coordinate System is:
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Origin = (-82.024106099012357,29.372215031234983)
Pixel Size = (0.000293071769451,-0.000293071769451)
Metadata:
TIFFTAG_SOFTWARE=EWS Version 2.2.2 MIP: 2.2.328
TIFFTAG_DATETIME=2014:10:28 17:59:39
EOMAP_UUID=ce0b805c-5ec3-11e4-868a-4c72b9272832
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -82.0241061, 29.3722150) ( 82d 1’26.78"W, 29d22’19.97"N)
Lower Left ( -82.0241061, 28.2391996) ( 82d 1’26.78"W, 28d14’21.12"N)
Upper Right ( -80.4749287, 29.3722150) ( 80d28’29.74"W, 29d22’19.97"N)
Lower Right ( -80.4749287, 28.2391996) ( 80d28’29.74"W, 28d14’21.12"N)
Center ( -81.2495174, 28.8057073) ( 81d14’58.26"W, 28d48’20.55"N)
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
Kind regards,
Sabine
Gesendet: Donnerstag, 12. Februar 2015 um 10:04 Uhr
Von: “Daniele Romagnoli” <daniele.romagnoli@anonymised.com>
An: “Sabine Ohlendorf” <sabine.ohlendorf@anonymised.com>
Cc: “Geoserver Mailinglist” <geoserver-users@anonymised.com.sourceforge.net>
Betreff: Re: [Geoserver-users] Imagemosaic with SLD not fully displayed
Hi Sabine,
do you have any chance to share a minimal set of data to replicate the issue for debugging?
Side questions:
- Can you run a gdalinfo on one of your samples and provide us the output?
- Can you also provide us the coverage configuration? (the coverage.xml. You can find it in the GEOSERVER_DATA_DIR/workspaces/yourworkspace/yourcoveragestore/yourcoverage/coverage.xml)
Please, let us know.
Best Regards,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Wed, Feb 11, 2015 at 2:16 PM, Sabine Ohlendorf <sabine.ohlendorf@anonymised.com> wrote:
I am using geoserver 2.6.1 and have a problem with SLDs:
I created a new style as SLD (see below). Furthermore I have an imagemosaic layer with 32bit geotiffs where I put the created style as default style in the WMS settings.
When I start the OpenLayers LayerPreview the style is used in general but the problem is that values smaller 1 within the image are not displayed at first. It is necessary to zoom in until a scale of 1:150K. Then the values are displayed in the appropriate colors of the style.
Before I used geoserver 2.2.5 with the same setting and the same style and it was workling without problems.
Kinrd regards,
Sabine
SLD:
<sld:StyledLayerDescriptor xmlns:ogc=“http://www.opengis.net/ogc” xmlns:xlink=“http://www.w3.org/1999/xlink” xmlns:sld=“http://www.opengis.net/sld” xmlns:gml=“http://www.opengis.net/gml” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd”>
<sld:NamedLayer xmlns=“http://www.opengis.net/sld”>sld:Name4db8e899a3a245588c282af02e849433</sld:Name>
sld:UserStylesld:NameStyle1</sld:Name>
sld:TitleWater Mask</sld:Title>
sld:Abstract/
sld:FeatureTypeStylesld:NameTurbidity</sld:Name>
sld:TitleTurbidity</sld:Title>
sld:Abstract;</sld:Abstract>
sld:SemanticTypeIdentifiergeneric:geometry</sld:SemanticTypeIdentifier>
sld:Rulesld:NameWater Mask - </sld:Name>
sld:TitleWater Mask - </sld:Title>
sld:RasterSymbolizersld:ColorMap
<sld:ColorMapEntry color=“#808080” quantity=“-6” opacity=“0.0” label=“”/>
<sld:ColorMapEntry color=“#808080” quantity=“-5” opacity=“0.0” label=“”/>
<sld:ColorMapEntry color=“#808080” quantity=“-4” opacity=“0.0” label=“”/>
<sld:ColorMapEntry color=“#808080” quantity=“-3” opacity=“0.0” label=“”/>
<sld:ColorMapEntry color=“#808080” quantity=“-2” opacity=“0.0” label=“”/>
<sld:ColorMapEntry color=“#808080” quantity=“-1” opacity=“0.0” label=“”/>
<sld:ColorMapEntry color=“#808080” quantity=“0” opacity=“0.0” label=“”/>
<sld:ColorMapEntry color=“#190019” quantity=“0.001” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#190019” quantity=“0.1” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#100059” quantity=“0.124” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#0600A1” quantity=“0.169” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#002ED2” quantity=“0.229” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#0080E4” quantity=“0.311” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#00B3EF” quantity=“0.423” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#00E6FA” quantity=“0.575” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#00F4CC” quantity=“0.782” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#00DE66” quantity=“1.063” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#00C800” quantity=“1.445” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#66DE00” quantity=“1.965” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#CCF400” quantity=“2.671” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FFCC00” quantity=“3.631” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FF6600” quantity=“4.936” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FF0000” quantity=“6.709” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#CC0033” quantity=“9.12” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#990066” quantity=“12.397” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#990099” quantity=“16.853” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#CC00CC” quantity=“22.909” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FF00FF” quantity=“31.141” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FF26FF” quantity=“42.332” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FF49FF” quantity=“57.544” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FF6AFF” quantity=“78.223” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FF8EFF” quantity=“106.333” opacity=“1.0” label=“”/>
<sld:ColorMapEntry color=“#FFAFFF” quantity=“144.544” opacity=“1.0” label=“”/>
</sld:ColorMap>
</sld:RasterSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
