Hi List,
I’m trying to configure an empty imagemosaic and afterwards adding to it geotiff granules by REST calls.
I had succes using postgres, and now I’m trying using spatialite.
First of all: is it supported?
If it is, this is what I did:
A PUT call to create the empty mosaic sending the zip file containing the two files in attachment, and the result was HTTP/1.1 201 Created.
A POST call to add the granules to the mosaic, and the result was HTTP/1.1 500 Internal Server Error: Failed to access the existing reader to check if it can harvest new files* About to connect() to localhost port 8080 (#0)
N.B. the same calls work with postgres.
here are my geoserver build information:
- 2.7.0
- b7cdbf9bbef0c5f88a3d30e132146ac9fa368b4b
- 20-Mar-2015 19:44
- 13.0 (rev 3e400364d95c06a3e449c34dbc3c587a12bbdfb6)
- 1.7.0 (rev 1.7.x/c87a6d54381fd571424095702a43a6fd403e5148)
I’m using tomcat7 on a CentOS release 6.6.
And this is the catalina corrispondig to my PUT and POST calls
21 Apr 09:30:04 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/file.imagemosaic’; to: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/file.imagemosaic’ and httpMethod= PUT
21 Apr 09:30:04 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
21 Apr 09:30:04 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/file.imagemosaic’; antPath is /; matchedPath=true; matchedMethods=false
21 Apr 09:30:04 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= / methodList= [POST, DELETE, PUT]
21 Apr 09:30:04 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/file.imagemosaic’; antPath is /; matchedPath=true; matchedMethods=true
21 Apr 09:30:04 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
21 Apr 09:30:04 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/acs/coveragestores/spatialite_mosaic/file.imagemosaic]
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 43 locking in mode WRITE
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 43 got the lock in mode WRITE
21 Apr 09:30:05 DEBUG [gce.arcgrid] - ArcGridFormatFactory is availaible.
21 Apr 09:30:05 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
21 Apr 09:30:05 INFO [catalog.rest] - PUT file, mimetype: application/zip
21 Apr 09:30:05 INFO [catalog.rest] - Auto-configuring coverage store: spatialite_mosaic
21 Apr 09:30:05 DEBUG [geoserver.config] - Persisting coverage store spatialite_mosaic
21 Apr 09:30:05 DEBUG [geoserver.config] - Persisted com.sun.proxy.$Proxy8 to workspaces/acs/spatialite_mosaic/coveragestore.xml
21 Apr 09:30:05 DEBUG [geoserver.config] - Persisted com.sun.proxy.$Proxy30 to global.xml
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 43 releasing the lock in mode WRITE
21 Apr 09:30:05 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
21 Apr 09:30:05 DEBUG [geoserver.security] - AuthenticationCache found an entry for basic, admin:bfa584f5598433a3c1fe16b00acc9c43
21 Apr 09:30:05 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/external.imagemosaic’; to: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/external.imagemosaic’ and httpMethod= POST
21 Apr 09:30:05 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= / methodList= [GET]
21 Apr 09:30:05 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/external.imagemosaic’; antPath is /; matchedPath=true; matchedMethods=false
21 Apr 09:30:05 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= / methodList= [POST, DELETE, PUT]
21 Apr 09:30:05 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/external.imagemosaic’; antPath is /; matchedPath=true; matchedMethods=true
21 Apr 09:30:05 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
21 Apr 09:30:05 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/rest/workspaces/acs/coveragestores/spatialite_mosaic/external.imagemosaic]
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 41 locking in mode WRITE
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 41 got the lock in mode WRITE
21 Apr 09:30:05 TRACE [geotools.factory] - ENTRY (GridCoverageFactory)
21 Apr 09:30:05 TRACE [geotools.factory] - RETURN (GridCoverageFactory): found implementation GridCoverageFactory.
21 Apr 09:30:05 ERROR [gce.imagemosaic] -
java.io.IOException
at org.geotools.gce.imagemosaic.CatalogManager.createGranuleCatalogFromDatastore(CatalogManager.java:206)
at org.geotools.gce.imagemosaic.CatalogManager.createCatalog(CatalogManager.java:128)
at org.geotools.gce.imagemosaic.ImageMosaicConfigHandler.indexingPreamble(ImageMosaicConfigHandler.java:289)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:109)
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:196)
at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:354)
at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1223)
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:505)
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:457)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:483)
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:103)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1436)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1364)
at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at com.sun.proxy.$Proxy8.getGridCoverageReader(Unknown Source)
at org.geoserver.catalog.rest.CoverageStoreFileResource.allowPost(CoverageStoreFileResource.java:60)
at org.restlet.Finder.allowMethod(Finder.java:104)
at org.restlet.Finder.handle(Finder.java:286)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:931)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.NullPointerException
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:191)
at org.geotools.gce.imagemosaic.CatalogManager.createGranuleCatalogFromDatastore(CatalogManager.java:196)
… 112 more
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 41 releasing the lock in mode WRITE
21 Apr 09:30:05 ERROR [geoserver.rest] - Failed to access the existing reader to check if it can harvest new files
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.CoverageStoreFileResource.allowPost(CoverageStoreFileResource.java:68)
21 Apr 09:30:05 DEBUG [security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/workspaces/acs/coveragestores/spatialite_mosaic/external.imagemosaic’; antPath is /**; matchedPath=true; matchedMethods=true
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 34 locking in mode WRITE
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 34 got the lock in mode WRITE
java.io.IOException
… 112 more
21 Apr 09:30:05 DEBUG [org.geoserver] - Thread 34 releasing the lock in mode WRITE
Thanks in advance for your support.
Serena
datastore.properties (75 Bytes)
indexer.xml (1.21 KB)
