following steps i had done:
gdal_retile for image pyramids of my GeoTIFF
gdaltindex for shape file of bounding box of each pyramid step inclusive the absolute path on file system
Create Table for mosaic-table and fill information of my geotiff:
CREATE TABLE mosaic_geom
name character varying(254) NOT NULL,
spatialtable character varying(254) NOT NULL,
minx double precision,
miny double precision,
maxx double precision,
maxy double precision,
resx double precision,
resy double precision,
CONSTRAINT rmosaic_geom_pkey PRIMARY KEY (name, spatialtable)
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_1”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_2”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_3”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_4”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_5”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_6”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_7”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_8”;;;;;;
“dop2014rgb_5000_path”;“dop2014rgb_5000_path_0”;;;;;;
- Create Tables for each pyramid step und insert to shape file and absolute path:
For example:
CREATE TABLE dop2014rgb_5000_path_0
location character(64) NOT NULL,
geom geometry(MultiPolygon,25833)
"D:\Datenimport\DOP2014RGB5000\0\dop20c_33298_5610_01_37.tif ";“0106000020E9640000010000000103000000010000000500000000000000C06214410000000070935541000000006072144100000000709355410000000060721441000000007692554100000000C0621441000000007692554100000000C06214410000000070935541”
"D:\Datenimport\DOP2014RGB5000\0\dop20c_33298_5610_01_38.tif ";“0106000020E964000001000000010300000001000000050000000000000060721441000000007093554100000000008214410000000070935541000000000082144100000000769255410000000060721441000000007692554100000000607214410000000070935541”
- Create XML-Files for ImageMosaicJDBC-Plugin in GeoServer:
dop2014rgb_5000_path.postgis.xml
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <!DOCTYPE ImageMosaicJDBCConfig [ ]>&mapping;
&connect;
mapping_path.postgis.xml
Now comes a error when I add a data store using this xml-files:
2015-04-30 12:46:52,415 ERROR [imagemosaic.jdbc] - No level available for dop2014rgb_5000_path
2015-04-30 12:46:52,415 WARN [imagemosaic.jdbc] - java.io.IOException: No level available for dop2014rgb_5000_path
java.io.IOException: java.io.IOException: No level available for dop2014rgb_5000_path
at org.geotools.gce.imagemosaic.jdbc.ImageMosaicJDBCReader.(ImageMosaicJDBCReader.java:163)
at org.geotools.gce.imagemosaic.jdbc.ImageMosaicJDBCFormat.getReader(ImageMosaicJDBCFormat.java:226)
at org.geotools.gce.imagemosaic.jdbc.ImageMosaicJDBCFormat.getReader(ImageMosaicJDBCFormat.java:68)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1436)
What is the mistake?
Greets,
André Mende
