[Geoserver-users] implementing CAS in Geoserver
Hello all,
I am trying to implement CAS authentication in GeoServer and would appreciate if anyone having expertise in it could guide me. Following are the steps I already tried, but with no success. FYI I am still relatively a beginner for spring security and geoserver.
I have tried inserting CAS authentication, but was unsuccessful. I might be wrong in my approach, but I was trying to implement a CAS authentication wrapper around geoserver. I also tried modifying aplicationSecurityContext to insert CAS, but that also failed due to conflicts with current authentication (usernamepassword) mechanism. It seems that other services (catalog, wms etc.) are tightly coupled with previous authentication mechanism and my insertion of CAS relevant code breaks the previous authentication, thereby failing to get these other services up.
Let me know if you have any thoughts about the possible path of implementation. I highly appreciate your help. FYI, I am using a slightly different implementation of geoserver from http://3dwebgis.di.uminho.pt/sources/. Additionally I have also seen similar efforts in progress from Christian Mueller, but since it is yet to finish, I am giving it a shot myself.
Thanks
Sachin
Hi Sachin
I am the developer of the CAS module. First the bad news. The CAS module never should have been on the download page, this was an "accident". You can stop your efforts here, it will not work.
First I have to apply the patch for
http://geoserver.org/display/GEOS/GSIP+82+-+Reworking+security+filter+chains
The new CAS module is based on this patch. Unfortunately, this patch requires migration code and it is not possible to apply it to 2.2.x series. CAS will work starting with Geoserver 2.3.0. The release schedule is here
http://geoserver.org/display/GEOS/GeoTools+and+GeoServer+release+schedule
The good news: I hope to get finished soon and you can try CAS using a nightly build. I will send an information mail on the user list.
Sorry for your inconvenience
Christian
Zitat von Sachin Hirve <shirve.csu@anonymised.com>:
Hello all,
Thanks
Sachin
This message was sent using IMP, the Internet Messaging Program.
Hi Christian,
Thank you for sharing this information. I am not using the CAS related code of geoserver which was on geoserver. Rather I was planning to start from the beginning, but it seems to involve a huge effort. Therefore I am looking forward to your CAS extension implementation.
If you can let me know the estimated time of sharing the nightly build (CAS extension), that would be a big help. I am looking to include your CAS implementation in my work as soon as possible due to an upcoming demo deadline.
Thank you for your help.
regards
Sachin
On Fri, Dec 7, 2012 at 4:12 AM, <christian.mueller@anonymised.com> wrote:
Hi Sachin
I am the developer of the CAS module. First the bad news. The CAS module never should have been on the download page, this was an “accident”. You can stop your efforts here, it will not work.
http://geoserver.org/display/GEOS/GSIP+82±+Reworking+security+filter+chains
Christian
Hello all,
Thanks
Sachin
Hi Sachin
What is your deadline. Please let me know ?
Christian
Hi Christian,
deadline.
regards
Sachin
Hi Sachin
http://geoserver.org/display/**GEOS/GSIP+82+-+Reworking+**
security+filter+chains<http://geoserver.org/display/GEOS/GSIP+82+-+Reworking+security+filter+chains&gt;
http://geoserver.org/display/**GEOS/GeoTools+and+GeoServer+**
release+schedule<http://geoserver.org/display/GEOS/GeoTools+and+GeoServer+release+schedule&gt;
Christian
Hello all,
a
be
http://3dwebgis.di.uminho.pt/**sources/&lt;http://3dwebgis.di.uminho.pt/sources/&gt;\.
Thanks
Sachin
I'm also interested in using CAS in geoserver. But I don't have any specific deadline.
best regards,
Premysl
On St 12. prosinec 2012, 14:37:15 CET, christian.mueller@anonymised.com wrote:
Hi Sachin
Christian
Hi Christian,
deadline.
regards
Sachin
Hi Sachin
Christian
  Hello all,
a
be
Thanks
Sachin
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-users mailing list
Hi Christian,
I had a deadline of December 25, 2012 to show CAS working with few more features dependent on CAS which looks difficult now. I will also need time to integrate your code into my working branch. Code integration will include migration code and CAS extension, since I am using another geoserver version (based on 2.2.x) for some specific services (which are not part of current geoserver development). So in all whenever earliest possible I could get the nightly build with instructions to merge the code, that would be a big help.
Thank you for your help. I highly appreciate it.
regards,
Sachin
On Wed, Dec 12, 2012 at 8:37 AM, <christian.mueller@anonymised.com> wrote:
Hi Sachin
Christian
Hi Christian,
deadline.
regards
Sachin
Hi Sachin
security+filter+chains<http://geoserver.org/display/GEOS/GSIP+82±+Reworking+security+filter+chains>
release+schedule<http://geoserver.org/display/GEOS/GeoTools+and+GeoServer+release+schedule>
Christian
Hello all,
a
be
http://3dwebgis.di.uminho.pt/**sources/<http://3dwebgis.di.uminho.pt/sources/>.
Thanks
Sachin
Hi Sachin
My plan is to have one commit for GSIP-82 and one for CAS.
The CAS merge is simple because CAS is an extension. The merge of GSIP-82 is more tricky, but you can see all changes online on github.
I will try to hurry up.
Hi Christian,
regards,
Sachin
Hi Sachin
Christian
Hi Christian,
code
(CAS
deadline.
regards
Sachin
Hi Sachin
http://geoserver.org/display/****GEOS/GSIP+82+-+Reworking+**&lt;http://geoserver.org/display/**GEOS/GSIP+82+-+Reworking+**&gt;
security+filter+chains<http://**geoserver.org/display/GEOS/**
GSIP+82+-+Reworking+security+**filter+chains<http://geoserver.org/display/GEOS/GSIP+82+-+Reworking+security+filter+chains&gt;
series.
http://geoserver.org/display/****GEOS/GeoTools+and+GeoServer+****&lt;http://geoserver.org/display/**GEOS/GeoTools+and+GeoServer+**&gt;
release+schedule<http://**geoserver.org/display/GEOS/**
GeoTools+and+GeoServer+**release+schedule<http://geoserver.org/display/GEOS/GeoTools+and+GeoServer+release+schedule&gt;
Christian
Hello all,
are
relatively
a
be
services
slightly
http://3dwebgis.di.uminho.pt/****sources/&lt;http://3dwebgis.di.uminho.pt/**sources/&gt;
<http://3dwebgis.di.**uminho.pt/sources/<http://3dwebgis.di.uminho.pt/sources/>
to
Thanks
Sachin
