Hello, I am having some troubles with the rest API of importing geojson from Postgres PostGIS database to Geoserver to create layer and register to WFS services.
Are there any ways we can do it?
Thank you
Confusing questions. Please elaborate more on what you want to do…
Samann Long <longsamann16@anonymised.com> escreveu no dia terça, 28/01/2020 à(s) 06:12:
The obvious way to do this is to skip the geojson and just add the PostGIS tables as new layers, you can export them from GeoServer as GeoJSON using WFS if you want.
Ian
Ian Turton
This makes me wonder if it’s more efficient to export geojason from wfs or directly from PG. Currently I’m going to the database for this in my web applications.
Vera
On Wed., Jan. 29, 2020, 3:58 a.m. Ian Turton, <ijturton@anonymised.com> wrote:
Ian
On Wed, 29 Jan 2020 at 09:48, Vitor Fonseca <vfonsecaz@anonymised.com> wrote:
Thank you
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
https://lists.sourceforge.net/lists/listinfo/geoserver-users–
Ian Turton
Yes, you can do that. But then you are responsible for working out the bounding box or any filters that the user would like while if you go via GeoServer you don’t have to write and debug all that code. Also if you stick with an international standard you can switch clients with no effort rather than starting from scratch each time. Remember GeoServer does a lot more for you than just return the data.
Ian
Ian Turton
Sorry…even if we are retreating the data as geojason with the end goal of pushing it back to PG with user edits.
Especially then, that is what WFS-T was designed for. Or are you going to write a state of the art authentication and authorisation system that can interact with active directory or just allow any passing hacker delete your data?
Ian
Ian Turton
Haha…yes the authentication has been…not fun. We are integrating it with active directory.
Thanks, will investigate. Any doc’s you recommend would be appreciated.
V
On Wed., Jan. 29, 2020, 9:24 a.m. Ian Turton, <ijturton@anonymised.com> wrote:
On Wed, 29 Jan 2020 at 16:12, Vera Green <vera.green.ca@anonymised.com> wrote:
Ian
V
On Wed., Jan. 29, 2020, 9:10 a.m. Vera Green, <vera.green.ca@anonymised.com4…> wrote:
Thanks. Even if our end goal is editing the data you would recommend going through WFS?
VOn Wed., Jan. 29, 2020, 9:01 a.m. Ian Turton, <ijturton@anonymised.com> wrote:
Ian
On Wed, 29 Jan 2020 at 15:55, Vera Green <vera.green.ca@anonymised.com> wrote:
VeraOn Wed., Jan. 29, 2020, 3:58 a.m. Ian Turton, <ijturton@anonymised.com> wrote:
Ian
Thank you
Geoserver-users@anonymised.comourceforge.net
Ian Turton
Ian Turton
Ian Turton
There is a full tutorial at https://docs.geoserver.org/latest/en/user/security/tutorials/activedirectory/index.html which gives you an example LDAP set up to work with while you get the hang of it.
Ian
Ian Turton
Oh…yes thank you. We have that part working . But we haven’t used WFS-T. So far we are just using WMS in leaflet.
V
On Wed., Jan. 29, 2020, 10:34 a.m. Ian Turton, <ijturton@anonymised.com> wrote:
Ian
On Wed, 29 Jan 2020 at 17:18, Vera Green <vera.green.ca@anonymised.com> wrote:
VOn Wed., Jan. 29, 2020, 9:24 a.m. Ian Turton, <ijturton@anonymised.com> wrote:
Ian
V
On Wed., Jan. 29, 2020, 9:10 a.m. Vera Green, <vera.green.ca@anonymised.com> wrote:
Ian
Ian
Thank you
Ian Turton
Ian Turton
Ian Turton
Ian Turton
