I have just installed geoserver and follow the import shapefile tutorial:
http://geoserver.org/display/GEOSDOC/User+Tutorial+Shapefile
Quite straightforward, nice to follow and everything was working fine until
the end: I am unable to find my data (so a shapefile) in demo -> mqp
preview. All defaut dataset are listed but not mine
Don't see what I made wrong because I have follow strictly the tutorial and
all what I got was making sense. And I don't know is missing and how to
check...in brief I am lost
Any clue?
thanks
View this message in context: http://www.nabble.com/Import-Shapefile-tutorial-tp22857223p22857223.html
Did you "Apply" and "Save" at the end of the new data layer creation ?
The two buttons are on the upper-left corner of the Config Area of the Geoserver Web Interface.
Marco Foi
At 23:16 02/04/2009, darrepac wrote:
Any clue?
thanks
Geoserver-users mailing list
Yes I did it and I can see my data in the datastore...
Marco Foi
until
and
Any clue?
thanks
View this message in context: http://www.nabble.com/Import-Shapefile-tutorial-tp22857223p22863154.html
darrepac ha scritto:
Besides the apply/save thing, did you choose a style which is compatible
with your data? For example, if your SLD contains only points and you chose a polygon style nothing will be drawn.
Another option is that yours is a "sparse" shapefile, in which ESRI
tools have poked holes, areas in which there is no data.
GeoServer 1.7.3 cannot read them, we're working on a fix right now.
Actually, if you pick a April 3 build from here:
http://gridlock.openplans.org/geoserver/1.7.x/
(still not available at the time of writing) you'll get one that
should be able to read that kind of shapefiles too.
Andrea Aime
OpenGeo - http://opengeo.org
I think I did it correct but here I would prefer to check. Can you tell me
how to check this?
I have used mostly gdaltindex to generate the shp and GlobalMapper to add an
attribute to it.
View this message in context: http://www.nabble.com/Import-Shapefile-tutorial-tp22857223p22863329.html
how to check this?
Well... look at your data attributes, bottom of the page, if it says
"multipolygon" use the "polygon" style and so on for the other
geometry types.
attribute to it.
Oh, strange. Well, if nothing works send me the file, zipped, by private
mail and I'll have a quick look.
Andrea Aime
Thanks to Andrea I found the problem...nothing was present in my feature
types so by recreating it again it has worked
thanks to all
View this message in context: http://www.nabble.com/Import-Shapefile-tutorial-tp22857223p22868424.html
