[Geoserver-users] imports failed to load
Hi list
I’m having various error messages, like this:
http://my_domain/geoserver/my_workspace/rest/imports Failed to load resource: the server responded with a status of 404 (No Encontrado)
Likewise, the layers indicated workspace is loaded on the client.
I’m using geoexplorer as gis client
Where it could be the problem?
Thanks in advanced
Pablo
Hi list
Sorry, I am forwarding the query days ago I did because I could not even solve the problem.
Any hints you can give me?
Thanks in advanced
Pablo J. Zader
Lic. en Cs. de la Computación
pablo.zader@anonymised.com
"Los Grandes Hombres hablan sobre ideas…
Los Hombres Promedio hablan sobre cosas…
Los Hombres Pequeños hablan… de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
Hi Pablo,
this list provides help for the standard GeoServer downladed from geoserver.org,
it does not look like you’re using it.
That said, a normal GeoServer won’t answer workspace specific REST requests.
Not sure if it’s true for what you have too, but try to change your URL:
to:
http://my_domain/geoserver/rest/imports
On Mon, Oct 12, 2015 at 4:15 AM, pablo zader <pzader@anonymised.com> wrote:
Hi list
Thanks in advanced
---------- Forwarded message ----------
Date: 2015-10-04 15:22 GMT-03:00
Subject: imports failed to load
To: “geoserver-users@anonymised.comourceforge.net” <geoserver-users@lists.sourceforge.net>
Hi list
Thanks in advanced
Pablo
Pablo J. Zader
pablo.zader@anonymised.com.
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea
I am using standard GeoServer downladed from geoserver.org, geoserver 2.5.2
GeoExplorer use as a client gis, perhaps it is generating such requests. I will check it.
Thank you
Pablo
2015-10-12 5:04 GMT-03:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Pablo,
to:
Hi list
Thanks in advanced
To: “geoserver-users@lists.sourceforge.net” <geoserver-users@lists.sourceforge.net>
Hi list
Thanks in advanced
Pablo
Pablo J. Zader
Ing. Andrea Aime
@geowolf
Technical Lead
Pablo J. Zader
On Mon, Oct 19, 2015 at 3:23 PM, pablo zader <pzader@anonymised.com> wrote:
Hi Andrea
2.5.2
will check it.
Thank you
Yes, you should check, the URLs used now are not going to work in any
version of GeoServer.
By the way, you're three version behind the current stable, if there is any
issue in GeoServer
it can only be fixed in 2.7.x (maintenance) or 2.8.x (stable)
Ing. Andrea Aime
@geowolf
Technical Lead
